The following records define the control block used to manage each timer. More...
#include <timer.h>
Data Fields | |
| Objects_Control | Object |
| This field is the object management portion of a Timer instance. More... | |
| Watchdog_Control | Ticker |
| This field is the Watchdog instance which will be the scheduled. More... | |
| Timer_Classes | the_class |
| This field indicates what type of timer this currently is. More... | |
| Objects_Control Timer_Control::Object |
Referenced by _Timer_Free(), and rtems_timer_create().
| Timer_Classes Timer_Control::the_class |
Referenced by rtems_timer_create().
| Watchdog_Control Timer_Control::Ticker |
