Fatal API. More...
| struct | rtems_assert_context |
| Assert context. More... | |
Typedefs | |
| typedef CPU_Exception_frame | rtems_exception_frame |
| Exception frame. | |
| void | rtems_fatal_error_occurred (uint32_t the_error) |
| Invokes the internal error handler with a source of INTERNAL_ERROR_RTEMS_API and is internal set to false. More... | |
| void | rtems_fatal (rtems_fatal_source source, rtems_fatal_code error) |
| Invokes the internal error handler with is internal set to false. More... | |
| const char * | rtems_fatal_source_text (rtems_fatal_source source) |
| Returns a text for a fatal source. More... | |
| const char * | rtems_internal_error_text (rtems_fatal_code error) |
| Returns a text for an internal error code. More... | |
Fatal API.
