Information Related to the Debug Support Within RTEMS. More...
| #define | RTEMS_DEBUG_ALL_MASK 0xffffffff |
| Macro which indicates that all debugging modes are enabled. | |
| #define | RTEMS_DEBUG_REGION 0x00000001 |
| Macro which indicates that debugging for heaps/regions is enabled. | |
Typedefs | |
| typedef uint32_t | rtems_debug_control |
| The following type is used to manage the debug mask. | |
| void | _Debug_Manager_initialization (void) |
| Initialize debug manager. | |
| void | rtems_debug_enable (rtems_debug_control to_be_enabled) |
| Enable debugging. | |
| void | rtems_debug_disable (rtems_debug_control to_be_disabled) |
| Disable debugging. | |
| bool | rtems_debug_is_enabled (rtems_debug_control level) |
| Check if debug is enabled. More... | |
| SCORE_EXTERN rtems_debug_control | _Debug_Level |
| This variable contains the current debug level. | |
This include file contains the information pertaining to the debug support within RTEMS. It is currently cast in the form of a Manager since it is externally accessible.
