| #define | __THREAD_DO_NOT_INLINE_ENABLE_DISPATCH__ |
| Constants and Structures Related with Thread Dispatch. | |
| RTEMS_INLINE_ROUTINE bool | _Thread_Dispatch_is_enabled (void) |
| Indicates if the executing thread is inside a thread dispatch critical section. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _Thread_Dispatch_get_disable_level (void) |
| Gets thread dispatch disable level. More... | |
| RTEMS_INLINE_ROUTINE void | _Thread_Dispatch_initialization (void) |
| Thread dispatch initialization. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _Thread_Dispatch_increment_disable_level (void) |
| Increase thread dispatch disable level. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _Thread_Dispatch_decrement_disable_level (void) |
| Decrease thread dispatch disable level. More... | |
| RTEMS_INLINE_ROUTINE void | _Giant_Acquire (Per_CPU_Control *cpu_self) |
| RTEMS_INLINE_ROUTINE void | _Giant_Release (Per_CPU_Control *cpu_self) |
| void | _Thread_Dispatch (void) |
| Performs a thread dispatch if necessary. More... | |
| void | _Thread_Do_dispatch (Per_CPU_Control *cpu_self, ISR_Level level) |
| Performs a thread dispatch on the current processor. More... | |
| RTEMS_INLINE_ROUTINE Per_CPU_Control * | _Thread_Dispatch_disable_critical (const ISR_lock_Context *lock_context) |
| Disables thread dispatching inside a critical section (interrupts disabled). More... | |
| RTEMS_INLINE_ROUTINE Per_CPU_Control * | _Thread_Dispatch_disable (void) |
| Disables thread dispatching. More... | |
| RTEMS_INLINE_ROUTINE void | _Thread_Dispatch_enable (Per_CPU_Control *cpu_self) |
| Enables thread dispatching. More... | |
| RTEMS_INLINE_ROUTINE void | _Thread_Disable_dispatch (void) |
| Disables thread dispatching and acquires the Giant lock. | |
| RTEMS_INLINE_ROUTINE void | _Thread_Enable_dispatch_body (void) |
| void | _Thread_Enable_dispatch (void) |
| Enables thread dispatching and releases the Giant lock. More... | |
| RTEMS_INLINE_ROUTINE void | _Thread_Unnest_dispatch (void) |
