#include <rtems.h>#include <drvmgr/drvmgr_list.h>#include <stdint.h>#include <rtems/score/basedefs.h>
| struct | drvmgr_bus_params |
| Bus parameters used by driver interface functions to aquire information about bus. More... | |
| struct | drvmgr_bus_ops |
| Bus operations. More... | |
| struct | drvmgr_func |
| union | drvmgr_key_value |
| Union of different values. More... | |
| struct | drvmgr_key |
| struct | drvmgr_drv_res |
| Driver resource entry, Driver resources for a certain device instance, containing a number of keys where each key hold the data of interest. More... | |
| struct | drvmgr_bus_res |
| Bus resource list node. More... | |
| struct | drvmgr_map_entry |
| MAP entry. More... | |
| struct | drvmgr_bus |
| Bus information. More... | |
| struct | drvmgr_dev |
| Device information. More... | |
| struct | drvmgr_drv_ops |
| Driver operations, function pointers. More... | |
| struct | drvmgr_drv |
| Device driver description. More... | |
| struct | drvmgr_rw_arg |
| #define | DRVMGR_LEVEL_MAX 4 |
| #define | DRVMGR_USE_LOCKS 1 |
| #define | BUS_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_bus) |
| #define | BUS_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_bus) |
| #define | DEV_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_dev) |
| #define | DEV_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_dev) |
| #define | DRV_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_drv) |
| #define | DRV_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_drv) |
| #define | DRVMGR_BUS_TYPE_NONE 0 /* Not a valid bus */ |
| #define | DRVMGR_BUS_TYPE_ROOT 1 /* Hard coded bus */ |
| #define | DRVMGR_BUS_TYPE_PCI 2 /* PCI bus */ |
| #define | DRVMGR_BUS_TYPE_AMBAPP 3 /* AMBA Plug & Play bus */ |
| #define | DRVMGR_BUS_TYPE_LEON2_AMBA 4 /* LEON2 hardcoded bus */ |
| #define | DRVMGR_BUS_TYPE_AMBAPP_DIST 5 /* Distibuted AMBA Plug & Play bus accessed using a communication interface */ |
| #define | DRVMGR_BUS_TYPE_SPW_RMAP 6 /* SpaceWire Network bus */ |
| #define | DRVMGR_BUS_TYPE_AMBAPP_RMAP 7 /* SpaceWire RMAP accessed AMBA Plug & Play bus */ |
| #define | DRIVER_ID_BUS_MASK 0x00000000000000FFULL |
| #define | DRIVER_ID_RSV_MASK 0xFF00000000000000ULL |
| #define | DRIVER_ID_DEV_MASK 0x00FFFFFFFFFFFF00ULL |
| #define | DRIVER_ID(busid, devid) |
| #define | DRIVER_BUSID_GET(id) ((unsigned long long)(id) & DRIVER_ID_BUS_MASK) |
| #define | DRIVER_DEVID_GET(id) (((unsigned long long)(id) & DRIVER_ID_DEV_MASK) >> 8) |
| #define | DRIVER_ROOTBUS_ID(bus_type) DRIVER_ID(bus_type, 0) |
| #define | DRIVER_ROOT_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_ROOT) |
| #define | DRIVER_PCIBUS_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_PCI) |
| #define | DRIVER_GRLIB_AMBAPP_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_AMBAPP) |
| #define | DRIVER_LEON2_AMBA_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_LEON2_AMBA) |
| #define | DRIVER_AMBAPP_DIST_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_AMBAPP_DIST) |
| #define | BUS_OPS_NUM (sizeof(struct drvmgr_bus_ops)/sizeof(void (*)(void))) |
| #define | DRVMGR_FUNC(_ID_, _FUNC_) {(int)(_ID_), (void *)(_FUNC_)} |
| #define | DRVMGR_FUNC_END {0, NULL} |
| #define | DRVMGR_KEY_EMPTY {NULL, DRVMGR_KT_NONE, {0}} |
| #define | DRVMGR_RES_EMPTY {0, 0, NULL} |
| #define | MMAP_EMPTY {0, 0, 0} |
| #define | DRVMGR_TRANSLATE_ONE2ONE NULL |
| #define | DRVMGR_TRANSLATE_NO_BRIDGE ((void *)1) /* No bridge, error */ |
| #define | BUS_STATE_INIT_FAILED 0x00000001 /* Initialization Failed */ |
| #define | BUS_STATE_LIST_INACTIVE 0x00001000 /* In inactive bus list */ |
| #define | BUS_STATE_DEPEND_FAILED 0x00000004 /* Device init failed */ |
| #define | DEV_STATE_INIT_FAILED 0x00000001 /* Initialization Failed */ |
| #define | DEV_STATE_INIT_DONE 0x00000002 /* All init levels completed */ |
| #define | DEV_STATE_DEPEND_FAILED 0x00000004 /* Parent Bus init failed */ |
| #define | DEV_STATE_UNITED 0x00000100 /* Device United with Device Driver */ |
| #define | DEV_STATE_REMOVED 0x00000200 /* Device has been removed (unregistered) */ |
| #define | DEV_STATE_IGNORED |
| #define | DEV_STATE_LIST_INACTIVE 0x00001000 /* In inactive device list */ |
| #define | DRVMGR_OPS_NUM(x) (sizeof(x)/sizeof(void (*)(void))) |
| #define | DRVMGR_FED_BF 1 /* Breadth-first search */ |
| Calls func() for every device found in the device tree, regardless of device state or if a driver is assigned. More... | |
| #define | DRVMGR_FED_DF 0 /* Depth first search */ |
| #define | DRVMGR_TR_REVERSE 0x1 /* do reverse translation direction order */ |
| #define | DRVMGR_TR_PATH 0x2 /* 0x0=down-stream 0x2=up-stream address path */ |
| #define | DRVMGR_FUNCID(major, minor) ((((major) & 0xfff) << 20) | ((minor) & 0xfffff)) |
| #define | DRVMGR_FUNCID_NONE 0 |
| #define | DRVMGR_FUNCID_END DRVMGR_FUNCID(DRVMGR_FUNCID_NONE, 0) |
| #define | RW_SIZE_1 0x00001 /* Access Size */ |
| #define | RW_SIZE_2 0x00002 |
| #define | RW_SIZE_4 0x00004 |
| #define | RW_SIZE_8 0x00008 |
| #define | RW_SIZE_ANY 0x00000 |
| #define | RW_SIZE(id) ((unsigned int)(id) & 0xf) |
| #define | RW_DIR_ANY 0x00000 /* Access Direction */ |
| #define | RW_READ 0x00000 /* Read */ |
| #define | RW_WRITE 0x00010 /* Write */ |
| #define | RW_SET 0x00020 /* Write with same value (memset) */ |
| #define | RW_DIR(id) (((unsigned int)(id) >> 4) & 0x3) |
| #define | RW_RAW 0x00000 /* Raw access - no swapping (machine default) */ |
| #define | RW_LITTLE 0x00040 /* Little Endian */ |
| #define | RW_BIG 0x00080 /* Big Endian */ |
| #define | RW_ENDIAN(id) (((unsigned int)(id) >> 6) & 0x3) |
| #define | RW_TYPE_ANY 0x00000 /* Access type */ |
| #define | RW_REG 0x00100 |
| #define | RW_MEM 0x00200 |
| #define | RW_MEMREG 0x00300 |
| #define | RW_CFG 0x00400 |
| #define | RW_TYPE(id) (((unsigned int)(id) >> 8) & 0xf) |
| #define | RW_ARG 0x01000 /* Optional Argument */ |
| #define | RW_ERR 0x02000 /* Optional Error Handler */ |
| #define | DRVMGR_RWFUNC(minor) DRVMGR_FUNCID(FUNCID_RW, minor) |
| #define | PRINT_DEVS_FAILED 0x01 /* Failed during initialization */ |
| #define | PRINT_DEVS_ASSIGNED 0x02 /* Driver assigned */ |
| #define | PRINT_DEVS_UNASSIGNED 0x04 /* Driver not assigned */ |
| #define | PRINT_DEVS_IGNORED 0x08 /* Device ignored on user's request */ |
| #define | PRINT_DEVS_ALL |
| #define | OPTION_DEV_GENINFO 0x00000001 |
| #define | OPTION_DEV_BUSINFO 0x00000002 |
| #define | OPTION_DEV_DRVINFO 0x00000004 |
| #define | OPTION_DRV_DEVS 0x00000100 |
| #define | OPTION_BUS_DEVS 0x00010000 |
| #define | OPTION_RECURSIVE 0x01000000 |
| #define | OPTION_INFO_ALL 0xffffffff |
Typedefs | |
| typedef void(* | drvmgr_isr) (void *arg) |
| typedef void(* | drvmgr_drv_reg_func) (void) |
| Structure defines a function pointer called when driver manager is ready for drivers to register themselfs. More... | |
| typedef uint8_t(* | drvmgr_r8) (uint8_t *srcadr) |
| typedef uint16_t(* | drvmgr_r16) (uint16_t *srcadr) |
| typedef uint32_t(* | drvmgr_r32) (uint32_t *srcadr) |
| typedef uint64_t(* | drvmgr_r64) (uint64_t *srcadr) |
| typedef void(* | drvmgr_w8) (uint8_t *dstadr, uint8_t data) |
| typedef void(* | drvmgr_w16) (uint16_t *dstadr, uint16_t data) |
| typedef void(* | drvmgr_w32) (uint32_t *dstadr, uint32_t data) |
| typedef void(* | drvmgr_w64) (uint64_t *dstadr, uint64_t data) |
| typedef int(* | drvmgr_rmem) (void *dest, const void *src, int n) |
| typedef int(* | drvmgr_wmem) (void *dest, const void *src, int n) |
| typedef int(* | drvmgr_memset) (void *dstadr, int c, size_t n) |
| typedef uint8_t(* | drvmgr_r8_arg) (uint8_t *srcadr, void *a) |
| typedef uint16_t(* | drvmgr_r16_arg) (uint16_t *srcadr, void *a) |
| typedef uint32_t(* | drvmgr_r32_arg) (uint32_t *srcadr, void *a) |
| typedef uint64_t(* | drvmgr_r64_arg) (uint64_t *srcadr, void *a) |
| typedef void(* | drvmgr_w8_arg) (uint8_t *dstadr, uint8_t data, void *a) |
| typedef void(* | drvmgr_w16_arg) (uint16_t *dstadr, uint16_t data, void *a) |
| typedef void(* | drvmgr_w32_arg) (uint32_t *dstadr, uint32_t data, void *a) |
| typedef void(* | drvmgr_w64_arg) (uint64_t *dstadr, uint64_t data, void *a) |
| typedef int(* | drvmgr_rmem_arg) (void *dest, const void *src, int n, void *a) |
| typedef int(* | drvmgr_wmem_arg) (void *dest, const void *src, int n, void *a) |
| typedef int(* | drvmgr_memset_arg) (void *dstadr, int c, size_t n, void *a) |
| typedef void(* | drvmgr_rw_err) (struct drvmgr_rw_arg *a, struct drvmgr_bus *bus, int funcid, void *adr) |
Enumerations | |
| enum | { DRVMGR_OBJ_NONE = 0, DRVMGR_OBJ_DRV = 1, DRVMGR_OBJ_BUS = 2, DRVMGR_OBJ_DEV = 3 } |
| enum | drvmgr_kt { DRVMGR_KT_ANY = -1, DRVMGR_KT_NONE = 0, DRVMGR_KT_INT = 1, DRVMGR_KT_STRING = 2, DRVMGR_KT_POINTER = 3 } |
| enum | { DRVMGR_OK = 0, DRVMGR_NOMEM = 1, DRVMGR_EIO = 2, DRVMGR_EINVAL = 3, DRVMGR_ENOSYS = 4, DRVMGR_TIMEDOUT = 5, DRVMGR_EBUSY = 6, DRVMGR_ENORES = 7, DRVMGR_FAIL = -1 } |
| enum | drvmgr_tr_opts { CPUMEM_TO_DMA = 0x0, CPUMEM_FROM_DMA = 0x1, DMAMEM_TO_CPU = 0x2, DMAMEM_FROM_CPU = 0x3 } |
| drvmgr_translate() translation options | |
| enum | { FUNCID_NONE = 0x000, FUNCID_RW = 0x001 } |
| void | _DRV_Manager_initialization (void) |
| Initialize data structures of the driver management system. More... | |
| void | _DRV_Manager_init_level (int level) |
| Take all devices into init level 'level', all devices registered later will directly be taken into this level as well, ensuring that all registerd devices has been taken into the level. | |
| void | bsp_driver_level_hook (int level) |
| This function must be defined by the BSP when the driver manager is enabled and initialized during BSP initialization. More... | |
| int | drvmgr_init (void) |
| Init driver manager all in one go, will call _DRV_Manager_initialization(), then _DRV_Manager_init_level([1..DRVMGR_LEVEL_MAX]). More... | |
| void | drvmgr_init_update (void) |
| int | drvmgr_root_drv_register (struct drvmgr_drv *drv) |
| Register Root Bus device driver. | |
| int | drvmgr_drv_register (struct drvmgr_drv *drv) |
| Register a driver. | |
| int | drvmgr_dev_register (struct drvmgr_dev *dev) |
| Register a device. | |
| int | drvmgr_dev_unregister (struct drvmgr_dev *dev) |
| Remove a device, and all its children devices if device is a bus device. More... | |
| int | drvmgr_bus_register (struct drvmgr_bus *bus) |
| Register a bus. | |
| int | drvmgr_bus_unregister (struct drvmgr_bus *bus) |
| Unregister a bus. | |
| int | drvmgr_children_unregister (struct drvmgr_bus *bus) |
| Unregister all child devices of a bus. More... | |
| int | drvmgr_dev_drv_separate (struct drvmgr_dev *dev) |
| int | drvmgr_alloc_dev (struct drvmgr_dev **pdev, int extra) |
| Allocate a device structure, if no memory available rtems_error_fatal_occurred is called. More... | |
| int | drvmgr_alloc_bus (struct drvmgr_bus **pbus, int extra) |
| Allocate a bus structure, if no memory available rtems_error_fatal_occurred is called. More... | |
| void | drvmgr_bus_res_add (struct drvmgr_bus *bus, struct drvmgr_bus_res *bres) |
| Add resources to a bus, typically used by a bus driver. More... | |
| int | drvmgr_keys_get (struct drvmgr_dev *dev, struct drvmgr_key **keys) |
| Find all the resource keys for a device among all driver resources on a bus. More... | |
| struct drvmgr_key * | drvmgr_key_get (struct drvmgr_key *keys, char *key_name) |
| Return the one key that matches key name from a driver keys array. More... | |
| union drvmgr_key_value * | drvmgr_key_val_get (struct drvmgr_key *keys, char *key_name, enum drvmgr_kt key_type) |
| Extract key value from the key in the keys array matching name and type. More... | |
| union drvmgr_key_value * | drvmgr_dev_key_get (struct drvmgr_dev *dev, char *key_name, enum drvmgr_kt key_type) |
| Get key value from the bus resources matching [device, key name, key type] if no matching key is found NULL is returned. More... | |
| RTEMS_INLINE_ROUTINE struct drvmgr_bus * | drvmgr_get_parent (struct drvmgr_dev *dev) |
| Get parent bus. | |
| RTEMS_INLINE_ROUTINE struct drvmgr_drv * | drvmgr_get_drv (struct drvmgr_dev *dev) |
| Get Driver of device. | |
| int | drvmgr_for_each_dev (int(*func)(struct drvmgr_dev *dev, void *arg), void *arg, int options) |
| int | drvmgr_get_dev (struct drvmgr_drv *drv, int minor, struct drvmgr_dev **pdev) |
| Get Device pointer from Driver and Driver minor number. More... | |
| int | drvmgr_freq_get (struct drvmgr_dev *dev, int options, unsigned int *freq_hz) |
| Get Bus frequency in Hertz. More... | |
| int | drvmgr_on_rootbus (struct drvmgr_dev *dev) |
| Return 0 if dev is not located on the root bus, 1 if on root bus. | |
| int | drvmgr_get_dev_prefix (struct drvmgr_dev *dev, char *dev_prefix) |
| Get device name prefix, this name can be used to register a unique name in the bus->error filesystem or to get an idea where the device is located. More... | |
| int | drvmgr_interrupt_register (struct drvmgr_dev *dev, int index, const char *info, drvmgr_isr isr, void *arg) |
| Register a shared interrupt handler. More... | |
| int | drvmgr_interrupt_unregister (struct drvmgr_dev *dev, int index, drvmgr_isr isr, void *arg) |
| Unregister an interrupt handler. More... | |
| int | drvmgr_interrupt_clear (struct drvmgr_dev *dev, int index) |
| Clear (ACK) pending interrupt. More... | |
| int | drvmgr_interrupt_unmask (struct drvmgr_dev *dev, int index) |
| Force unmasking/enableing an interrupt on the interrupt controller, this is not normally used, if used the caller has masked/disabled the interrupt just before. More... | |
| int | drvmgr_interrupt_mask (struct drvmgr_dev *dev, int index) |
| Force masking/disable an interrupt on the interrupt controller, this is not normally performed since this will stop all other (shared) ISRs to be disabled until _unmask() is called. More... | |
| unsigned int | drvmgr_translate (struct drvmgr_dev *dev, unsigned int options, void *src_address, void **dst_address) |
| Translate an address on one bus to an address on another bus. More... | |
| unsigned int | drvmgr_translate_bus (struct drvmgr_bus *from, struct drvmgr_bus *to, int reverse, void *src_address, void **dst_address) |
| int | drvmgr_translate_check (struct drvmgr_dev *dev, unsigned int options, void *src_address, void **dst_address, unsigned int size) |
| int | drvmgr_func_get (void *obj, int funcid, void **func) |
| Get function pointer from Device Driver or Bus Driver. More... | |
| int | drvmgr_func_call (void *obj, int funcid, void *a, void *b, void *c, void *d) |
| Lookup function and call it directly with the four optional arguments. | |
| void | drvmgr_rw_memset (void *dstadr, int c, size_t n, void *a, drvmgr_wmem_arg wmem) |
| int | drvmgr_for_each_listdev (struct drvmgr_list *devlist, unsigned int state_set_mask, unsigned int state_clr_mask, int(*func)(struct drvmgr_dev *dev, void *arg), void *arg) |
| Calls func() for every device found matching the search requirements of set_mask and clr_mask. More... | |
| void | drvmgr_summary (void) |
| Print number of devices, buses and drivers. | |
| void | drvmgr_print_devs (unsigned int options) |
| Print devices with certain condictions met according to 'options'. | |
| void | drvmgr_print_topo (void) |
| Print device/bus topology. | |
| void | drvmgr_print_mem (void) |
| Print the memory usage Only accounts for data structures. More... | |
| void | drvmgr_info (void *id, unsigned int options) |
| Print information about a driver manager object (device, driver, bus) | |
| void | drvmgr_info_dev (struct drvmgr_dev *dev, unsigned int options) |
| Get information about a device. | |
| void | drvmgr_info_bus (struct drvmgr_bus *bus, unsigned int options) |
| Get information about a bus. | |
| void | drvmgr_info_drv (struct drvmgr_drv *drv, unsigned int options) |
| Get information about a driver. | |
| void | drvmgr_info_devs_on_bus (struct drvmgr_bus *bus, unsigned int options) |
| Get information about all devices on a bus. | |
| void | drvmgr_info_devs (unsigned int options) |
| Get information about all devices in the system (on all buses) | |
| void | drvmgr_info_drvs (unsigned int options) |
| Get information about all drivers in the system. | |
| void | drvmgr_info_buses (unsigned int options) |
| Get information about all buses in the system. | |
| struct drvmgr_drv * | drvmgr_drv_by_id (uint64_t id) |
| Get Driver by Driver ID. | |
| struct drvmgr_drv * | drvmgr_drv_by_name (const char *name) |
| Get Driver by Driver Name. | |
| struct drvmgr_dev * | drvmgr_dev_by_name (const char *name) |
| Get Device by Device Name. | |
| #define DEV_STATE_IGNORED |
| #define DRIVER_ID | ( | busid, | |
| devid | |||
| #define DRVMGR_FED_BF 1 /* Breadth-first search */ |
With the options argument the user can decide to do either a depth-first or a breadth-first search.
If the function func() returns a non-zero value then for_each_dev will return imediatly with the same return value as func() returned.
| func | Function called on each device |
| arg | Custom function argument |
| options | Search Options, see DRVMGR_FED_* |
| #define PRINT_DEVS_ALL |
| typedef void(* drvmgr_drv_reg_func) (void) |
Used to select drivers available to the driver manager.
| void _DRV_Manager_initialization | ( | void | ) |
Calls predefined register driver functions so that drivers can register themselves.
Referenced by drvmgr_init(), and rtems_initialize_before_drivers().
| void bsp_driver_level_hook | ( | int | level | ) |
The function is called after a init level is reached the first time by the driver manager.
Referenced by rtems_initialize_device_drivers().
| int drvmgr_alloc_bus | ( | struct drvmgr_bus ** | pbus, |
| int | extra | ||
The 'extra' argment tells how many bytes extra space is to be allocated after the device structure, this is typically used for "businfo" structures. The extra space is always aligned to a 4-byte boundary.
| int drvmgr_alloc_dev | ( | struct drvmgr_dev ** | pdev, |
| int | extra | ||
| void drvmgr_bus_res_add | ( | struct drvmgr_bus * | bus, |
| struct drvmgr_bus_res * | bres | ||
| bus | The Bus to add the resources to. |
| res | An array with Driver resources, all together are called bus resources. |
References drvmgr_bus_res::next, and drvmgr_bus::reslist.
| int drvmgr_children_unregister | ( | struct drvmgr_bus * | bus | ) |
This function is called from the bus driver, from a "safe" state where devices will not be added or removed on this particular bus at this time
| union drvmgr_key_value* drvmgr_dev_key_get | ( | struct drvmgr_dev * | dev, |
| char * | key_name, | ||
| enum drvmgr_kt | key_type | ||
This is typically used by device drivers to find a particular device resource.
| dev | The device to search resource for. |
| key_name | The key name to search for |
| key_type | The key type expected. |
References drvmgr_key_val_get(), and drvmgr_keys_get().
| int drvmgr_dev_unregister | ( | struct drvmgr_dev * | dev | ) |
The device driver will be requested to remove the device and once gone from bus, device and driver list the device is put into a inactive list for debugging (this is optional by using remove argument).
Removing the Root Bus Device is not supported.
| remove | If non-zero the device will be deallocated, and not put into the inacitve list. |
| int drvmgr_for_each_listdev | ( | struct drvmgr_list * | devlist, |
| unsigned int | state_set_mask, | ||
| unsigned int | state_clr_mask, | ||
| int(*)(struct drvmgr_dev *dev, void *arg) | func, | ||
| void * | arg | ||
Each bit set in set_mask must be set in the device state bit mask (dev->state), and Each bit in the clr_mask must be cleared in the device state bit mask (dev->state). There are three special cases:
| devlist | The list to iterate though searching for devices. |
| state_set_mask | Defines the bits that must be set in dev->state |
| state_clr_mask | Defines the bits that must be cleared in dev->state |
| func | Function called on each |
| int drvmgr_freq_get | ( | struct drvmgr_dev * | dev, |
| int | options, | ||
| unsigned int * | freq_hz | ||
Frequency is stored into address of freq_hz.
| dev | The Device to get Bus frequency for. |
| options | Bus-type specific options |
| freq_hz | Location where Bus Frequency will be stored. |
| int drvmgr_func_get | ( | void * | obj, |
| int | funcid, | ||
| void ** | func | ||
Returns 0 if function is available
Referenced by drvmgr_func_call().
| int drvmgr_get_dev | ( | struct drvmgr_drv * | drv, |
| int | minor, | ||
| struct drvmgr_dev ** | pdev | ||
| drv | Driver the device is united with. |
| minor | Driver minor number assigned to device. |
| pdev | Location where the Device point will be stored. |
| int drvmgr_get_dev_prefix | ( | struct drvmgr_dev * | dev, |
| char * | dev_prefix | ||
| dev | The Device to get the device Prefix for. |
| dev_prefix | Location where the prefix will be stored. |
References drvmgr_bus_params::dev_prefix, drvmgr_bus::ops, and drvmgr_dev::parent.
| int drvmgr_init | ( | void | ) |
Typically called from Init task when user wants to initilize driver manager after startup, otherwise not used.
References _DRV_Manager_initialization().
| int drvmgr_interrupt_clear | ( | struct drvmgr_dev * | dev, |
| int | index | ||
| dev | Device to clear interrupt for. |
| index | Index is used to identify the IRQ number if hardware has multiple IRQ sources. Normally Index is set to 0 to indicated the first and only IRQ source. A negative index is interpreted as a absolute bus IRQ number. |
| isr | Interrupt Service Routine, previously registered. |
| arg | Optional ISR argument, previously registered. |
| int drvmgr_interrupt_mask | ( | struct drvmgr_dev * | dev, |
| int | index | ||
| dev | Device to mask interrupt for. |
| int drvmgr_interrupt_register | ( | struct drvmgr_dev * | dev, |
| int | index, | ||
| const char * | info, | ||
| drvmgr_isr | isr, | ||
| void * | arg | ||
Since this service is shared among interrupt drivers/handlers the handler[arg] must be installed before the interrupt can be cleared or disabled. The handler is by default disabled after registration.
| isr | Interrupt Service Routine. |
| arg | Optional ISR argument. |
| int drvmgr_interrupt_unmask | ( | struct drvmgr_dev * | dev, |
| int | index | ||
| int drvmgr_interrupt_unregister | ( | struct drvmgr_dev * | dev, |
| int | index, | ||
| void * | arg | ||
This also disables the interrupt before unregistering the interrupt handler.
| struct drvmgr_key* drvmgr_key_get | ( | struct drvmgr_key * | keys, |
| char * | key_name | ||
The keys can be obtained using drvmgr_keys_get().
| keys | An array of keys ended with DRVMGR_KEY_EMPTY to search among. |
| key_name | Name of key to search for among the keys. |
Referenced by drvmgr_key_val_get(), and drvmgr_keys_get().
| union drvmgr_key_value* drvmgr_key_val_get | ( | struct drvmgr_key * | keys, |
This function calls drvmgr_keys_get to get the key requested (from key name), then determines if the type is correct. A pointer to the key value is returned.
| key_type | Data Type of value. INTEGER, ADDRESS, STRING. |
References drvmgr_key_get().
Referenced by drvmgr_dev_key_get().
| int drvmgr_keys_get | ( | struct drvmgr_dev * | dev, |
| struct drvmgr_key ** | keys | ||
Typically used by a device driver to get configuration options.
| dev | Device to find resources for |
| key | Location where the pointer to the driver resource array (drvmgr_drv_res->keys) is stored. |
References drvmgr_dev::drv, drvmgr_drv_res::drv_id, drvmgr_drv::drv_id, drvmgr_key_get(), drvmgr_drv_res::keys, drvmgr_drv_res::minor_bus, drvmgr_dev::minor_bus, drvmgr_bus_res::next, drvmgr_dev::parent, drvmgr_bus::reslist, and drvmgr_bus_res::resource.
| void drvmgr_print_mem | ( | void | ) |
Not for the text size.
| unsigned int drvmgr_translate | ( | struct drvmgr_dev * | dev, |
| unsigned int | options, | ||
| void * | src_address, | ||
| void ** | dst_address | ||
The device determines source or destination bus, the root bus is always the other bus. It is assumed that the CPU is located on the root bus or that it can access it without address translation (mapped 1:1). The CPU is thus assumed to be located on level 0 top most in the bus hierarchy.
If no map is present in the bus driver src_address is translated 1:1 (just copied).
Addresses are typically converted up-streams from the DMA unit towards the CPU (DMAMEM_TO_CPU) or down-streams towards DMA hardware from the CPU (CPUMEM_TO_DMA) over one or multiple bridges depending on bus architecture. See 'enum drvmgr_tr_opts' for other translation direction options. For example: Two common operations is to translate a CPU accessible RAM address to an address that DMA units can access (dev=DMA-unit, CPUMEM_TO_DMA, src_address=CPU-RAM-ADR) and to translate an address of a PCI resource for example RAM mapped into a PCI BAR to an CPU accessible address (dev=PCI-device, DMAMEM_TO_CPU, src_address=PCI-BAR-ADR).
Source address is translated and the result is put into *dst_address, if the address is not accessible on the other bus -1 is returned.
| dev | Device to translate addresses for |
| options | Tanslation direction options, see enum drvmgr_tr_opts |
| src_address | Address to translate |
| dst_address | Location where translated address is stored |
Returns 0 if unable to translate. The remaining length from the given address of the map is returned on success, for example if a map starts at 0x40000000 of size 0x100000 the result will be 0x40000 if the address was translated into 0x400C0000. If dev is on root-bus no translation is performed 0xffffffff is returned and src_address is stored in *dst_address.
