drvmgr_res.c File Reference
#include <drvmgr/drvmgr.h>
Include dependency graph for drvmgr_res.c:
int drvmgr_keys_get (struct drvmgr_dev *dev, struct drvmgr_key **keys)
 Find all the resource keys for a device among all driver resources on a bus. More...
struct drvmgr_keydrvmgr_key_get (struct drvmgr_key *keys, char *key_name)
 Return the one key that matches key name from a driver keys array. More...
union drvmgr_key_valuedrvmgr_key_val_get (struct drvmgr_key *keys, char *key_name, enum drvmgr_kt key_type)
 Extract key value from the key in the keys array matching name and type. More...
union drvmgr_key_valuedrvmgr_dev_key_get (struct drvmgr_dev *dev, char *key_name, enum drvmgr_kt key_type)
 Get key value from the bus resources matching [device, key name, key type] if no matching key is found NULL is returned. More...
◆ drvmgr_dev_key_get()
union drvmgr_key_value* drvmgr_dev_key_get ( struct drvmgr_dev dev,
char *  key_name,
This is typically used by device drivers to find a particular device resource.
Parameters
devThe device to search resource for.
key_nameThe key name to search for
key_typeThe key type expected.
Returns
Returns NULL if no value found matching Key Name and Key Type was found for device.
References drvmgr_key_val_get(), and drvmgr_keys_get().
◆ drvmgr_key_get()
struct drvmgr_key* drvmgr_key_get ( struct drvmgr_key keys,
char *  key_name
The keys can be obtained using drvmgr_keys_get().
Parameters
keysAn array of keys ended with DRVMGR_KEY_EMPTY to search among.
key_nameName of key to search for among the keys.
Referenced by drvmgr_key_val_get(), and drvmgr_keys_get().
◆ drvmgr_key_val_get()
union drvmgr_key_value* drvmgr_key_val_get ( struct drvmgr_key keys,
char *  key_name,
This function calls drvmgr_keys_get to get the key requested (from key name), then determines if the type is correct. A pointer to the key value is returned.
Parameters
key_typeData Type of value. INTEGER, ADDRESS, STRING.
Returns
Returns NULL if no value found matching Key Name and Key Type.
References drvmgr_key_get().
Referenced by drvmgr_dev_key_get().
◆ drvmgr_keys_get()
int drvmgr_keys_get ( struct drvmgr_dev dev,
struct drvmgr_key **  keys
Typically used by a device driver to get configuration options.
Parameters
devDevice to find resources for
keyLocation where the pointer to the driver resource array (drvmgr_drv_res->keys) is stored.
References drvmgr_dev::drv, drvmgr_drv_res::drv_id, drvmgr_drv::drv_id, drvmgr_key_get(), drvmgr_drv_res::keys, drvmgr_drv_res::minor_bus, drvmgr_dev::minor_bus, drvmgr_bus_res::next, drvmgr_dev::parent, drvmgr_bus::reslist, and drvmgr_bus_res::resource.
