drvmgr_drv_ops Struct Reference
Driver operations, function pointers. More...
#include <drvmgr.h>
int(* init [DRVMGR_LEVEL_MAX])(struct drvmgr_dev *)
int(* remove )(struct drvmgr_dev *)
 Function doing Init Stage 1 of a hardware device.
int(* info )(struct drvmgr_dev *, void(*print)(void *p, char *str), void *p, int, char *argv[])
 Function called when device instance is to be removed.
