#define | RTEMS_BDPART_PARTITION_NUMBER_HINT 16 |
| Recommended maximum partition table size.
#define | RTEMS_BDPART_MBR_CYLINDER_SIZE 63 |
#define | RTEMS_BDPART_NUMBER_SIZE 4 |
#define | RTEMS_BDPART_BLOCK_SIZE 512 |
#define | RTEMS_BDPART_MBR_TABLE_ENTRY_SIZE 16 |
#define | RTEMS_BDPART_MBR_OFFSET_TABLE_0 446 |
#define | RTEMS_BDPART_MBR_OFFSET_TABLE_1 (RTEMS_BDPART_MBR_OFFSET_TABLE_0 + RTEMS_BDPART_MBR_TABLE_ENTRY_SIZE) |
#define | RTEMS_BDPART_MBR_OFFSET_DISK_ID 440 |
#define | RTEMS_BDPART_MBR_OFFSET_SIGNATURE_0 510 |
#define | RTEMS_BDPART_MBR_OFFSET_SIGNATURE_1 511 |
#define | RTEMS_BDPART_MBR_SIGNATURE_0 0x55U |
#define | RTEMS_BDPART_MBR_SIGNATURE_1 0xaaU |
#define | RTEMS_BDPART_MBR_OFFSET_BEGIN 8 |
#define | RTEMS_BDPART_MBR_OFFSET_SIZE 12 |
#define | RTEMS_BDPART_MBR_OFFSET_TYPE 4 |
#define | RTEMS_BDPART_MBR_OFFSET_FLAGS 0 |
#define | RTEMS_BDPART_MBR_EMPTY 0x0U |
#define | RTEMS_BDPART_MBR_FAT_12 0x1U |
#define | RTEMS_BDPART_MBR_FAT_16 0x4U |
#define | RTEMS_BDPART_MBR_FAT_16_LBA 0xeU |
#define | RTEMS_BDPART_MBR_FAT_32 0xbU |
#define | RTEMS_BDPART_MBR_FAT_32_LBA 0xcU |
#define | RTEMS_BDPART_MBR_EXTENDED 0x5U |
#define | RTEMS_BDPART_MBR_DATA 0xdaU |
#define | RTEMS_BDPART_MBR_GPT 0xeeU |
#define | RTEMS_BDPART_MBR_FLAG_ACTIVE 0x80U |
rtems_status_code | rtems_bdpart_read (const char *disk_name, rtems_bdpart_format *format, rtems_bdpart_partition *partitions, size_t *count) |
| Reads the partition information from the physical disk device with name disk_name. More...
void | rtems_bdpart_sort (rtems_bdpart_partition *partitions, size_t count) |
| Sorts the partition table partitions with count partitions to have ascending begin blocks.
rtems_status_code | rtems_bdpart_write (const char *disk_name, const rtems_bdpart_format *format, const rtems_bdpart_partition *partitions, size_t count) |
| Writes the partition table to the physical disk device with name disk_name. More...
rtems_status_code | rtems_bdpart_create (const char *disk_name, const rtems_bdpart_format *format, rtems_bdpart_partition *partitions, const unsigned *distribution, size_t count) |
| Creates a partition table in partitions with count partitions for the physical disk device with name disk_name. More...
rtems_status_code | rtems_bdpart_register (const char *disk_name, const rtems_bdpart_partition *partitions, size_t count) |
| Registers the partitions as logical disks for the physical disk device with name disk_name. More...
rtems_status_code | rtems_bdpart_register_from_disk (const char *disk_name) |
| brief Reads the partition table from the disk device with name disk_name and registers the partitions as logical disks. More...
rtems_status_code | rtems_bdpart_unregister (const char *disk_name, const rtems_bdpart_partition *partitions, size_t count) |
| Deletes the logical disks associated with the partitions of the disk device with name disk_name. More...
rtems_status_code | rtems_bdpart_mount (const char *disk_name, const rtems_bdpart_partition *partitions, size_t count, const char *mount_base) |
| Mounts all supported file systems inside the logical disks derived from the partitions of the physical disk device with name disk_name. More...
rtems_status_code | rtems_bdpart_unmount (const char *disk_name, const rtems_bdpart_partition *partitions, size_t count, const char *mount_base) |
| Unmounts all file systems mounted with rtems_bdpart_mount().
void | rtems_bdpart_dump (const rtems_bdpart_partition *partitions, size_t count) |
| Prints the partition table partitions with count partitions to standard output.
void | rtems_bdpart_to_partition_type (uint8_t mbr_type, uuid_t type) |
| Returns the partition type for the MBR partition type value mbr_type in type.
bool | rtems_bdpart_to_mbr_partition_type (const uuid_t type, uint8_t *mbr_type) |
| Converts the partition type in type to the MBR partition type. More...
rtems_status_code | rtems_bdpart_get_disk_data (const char *disk_name, int *fd_ptr, rtems_disk_device **dd_ptr, rtems_blkdev_bnum *disk_end) |
Block Device Partition Management.
