uuid.h
1 /*
2  * Public include file for the UUID library
3  *
4  * Copyright (C) 1996, 1997, 1998 Theodore Ts'o.
5  *
6  * %Begin-Header%
7  * Redistribution and use in source and binary forms, with or without
8  * modification, are permitted provided that the following conditions
9  * are met:
10  * 1. Redistributions of source code must retain the above copyright
11  * notice, and the entire permission notice in its entirety,
12  * including the disclaimer of warranties.
13  * 2. Redistributions in binary form must reproduce the above copyright
14  * notice, this list of conditions and the following disclaimer in the
15  * documentation and/or other materials provided with the distribution.
16  * 3. The name of the author may not be used to endorse or promote
17  * products derived from this software without specific prior
18  * written permission.
19  *
20  * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
21  * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
22  * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ALL OF
23  * WHICH ARE HEREBY DISCLAIMED. IN NO EVENT SHALL THE AUTHOR BE
24  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
26  * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
27  * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
28  * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
29  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE
30  * USE OF THIS SOFTWARE, EVEN IF NOT ADVISED OF THE POSSIBILITY OF SUCH
31  * DAMAGE.
32  * %End-Header%
33  */
34
35 #ifndef _UUID_UUID_H
36 #define _UUID_UUID_H
37
38 #include <sys/types.h>
39 #ifndef _WIN32
40 #include <sys/time.h>
41 #endif
42 #include <time.h>
43
44 typedef unsigned char uuid_t[16];
45
46 /* UUID Variant definitions */
47 #define UUID_VARIANT_NCS 0
48 #define UUID_VARIANT_DCE 1
49 #define UUID_VARIANT_MICROSOFT 2
50 #define UUID_VARIANT_OTHER 3
51
52 /* UUID Type definitions */
53 #define UUID_TYPE_DCE_TIME 1
54 #define UUID_TYPE_DCE_RANDOM 4
55
56 /* Allow UUID constants to be defined */
57 #ifdef __GNUC__
58 #define UUID_DEFINE(name,u0,u1,u2,u3,u4,u5,u6,u7,u8,u9,u10,u11,u12,u13,u14,u15) \
59  static const uuid_t name __attribute__ ((unused)) = {u0,u1,u2,u3,u4,u5,u6,u7,u8,u9,u10,u11,u12,u13,u14,u15}
60 #else
61 #define UUID_DEFINE(name,u0,u1,u2,u3,u4,u5,u6,u7,u8,u9,u10,u11,u12,u13,u14,u15) \
62  static const uuid_t name = {u0,u1,u2,u3,u4,u5,u6,u7,u8,u9,u10,u11,u12,u13,u14,u15}
63 #endif
64
65 #ifdef __cplusplus
66 extern "C" {
67 #endif
68
69 /* clear.c */
70 void uuid_clear(uuid_t uu);
71
72 /* compare.c */
73 int uuid_compare(const uuid_t uu1, const uuid_t uu2);
74
75 /* copy.c */
76 void uuid_copy(uuid_t dst, const uuid_t src);
77
78 /* gen_uuid.c */
79 void uuid_generate(uuid_t out);
80 void uuid_generate_random(uuid_t out);
81 void uuid_generate_time(uuid_t out);
82
83 /* isnull.c */
84 int uuid_is_null(const uuid_t uu);
85
86 /* parse.c */
87 int uuid_parse(const char *in, uuid_t uu);
88
89 /* unparse.c */
90 void uuid_unparse(const uuid_t uu, char *out);
91 void uuid_unparse_lower(const uuid_t uu, char *out);
92 void uuid_unparse_upper(const uuid_t uu, char *out);
93
94 /* uuid_time.c */
95 time_t uuid_time(const uuid_t uu, struct timeval *ret_tv);
96 int uuid_type(const uuid_t uu);
97 int uuid_variant(const uuid_t uu);
98
99 #ifdef __cplusplus
100 }
101 #endif
102
103 #endif /* _UUID_UUID_H */
POSIX Time Types.
