blkdev.h
1
9 /*
10  * Copyright (C) 2001 OKTET Ltd., St.-Petersburg, Russia
11  * Author: Victor V. Vengerov <vvv@oktet.ru>
12  */
13
14 #ifndef _RTEMS_BLKDEV_H
15 #define _RTEMS_BLKDEV_H
16
17 #include <rtems.h>
18 #include <rtems/diskdevs.h>
19 #include <rtems/bspIo.h>
20 #include <sys/ioctl.h>
21 #include <stdio.h>
22
23 #ifdef __cplusplus
24 extern "C" {
25 #endif
26
54
56
60 typedef void (*rtems_blkdev_request_cb)(
61  struct rtems_blkdev_request *req,
63 );
64
68 typedef struct rtems_blkdev_sg_buffer {
73
77  uint32_t length;
78
82  void *buffer;
83
87  void *user;
89
102 typedef struct rtems_blkdev_request {
106  rtems_blkdev_request_op req;
107
112
116  void *done_arg;
117
122
126  uint32_t bufnum;
127
132
133  /*
134  * TODO: The use of these req blocks is not a great design. The req is a
135  * struct with a single 'bufs' declared in the req struct and the
136  * others are added in the outer level struct. This relies on the
137  * structs joining as a single array and that assumes the compiler
138  * packs the structs. Why not just place on a list ? The BD has a
139  * node that can be used.
140  */
141
145  rtems_blkdev_sg_buffer bufs[RTEMS_ZERO_LENGTH_ARRAY];
147
159 static inline void rtems_blkdev_request_done(
161  rtems_status_code status
162 )
163 {
164  (*req->done)(req, status);
165 }
166
173 #define RTEMS_BLKDEV_START_BLOCK(req) (req->bufs[0].block)
174
180 #define RTEMS_BLKIO_REQUEST _IOWR('B', 1, rtems_blkdev_request)
181 #define RTEMS_BLKIO_GETMEDIABLKSIZE _IOR('B', 2, uint32_t)
182 #define RTEMS_BLKIO_GETBLKSIZE _IOR('B', 3, uint32_t)
183 #define RTEMS_BLKIO_SETBLKSIZE _IOW('B', 4, uint32_t)
184 #define RTEMS_BLKIO_GETSIZE _IOR('B', 5, rtems_blkdev_bnum)
185 #define RTEMS_BLKIO_SYNCDEV _IO('B', 6)
186 #define RTEMS_BLKIO_DELETED _IO('B', 7)
187 #define RTEMS_BLKIO_CAPABILITIES _IO('B', 8)
188 #define RTEMS_BLKIO_GETDISKDEV _IOR('B', 9, rtems_disk_device *)
189 #define RTEMS_BLKIO_PURGEDEV _IO('B', 10)
190 #define RTEMS_BLKIO_GETDEVSTATS _IOR('B', 11, rtems_blkdev_stats *)
191 #define RTEMS_BLKIO_RESETDEVSTATS _IO('B', 12)
192
195 static inline int rtems_disk_fd_get_media_block_size(
196  int fd,
197  uint32_t *media_block_size
198 )
199 {
200  return ioctl(fd, RTEMS_BLKIO_GETMEDIABLKSIZE, media_block_size);
201 }
202
203 static inline int rtems_disk_fd_get_block_size(int fd, uint32_t *block_size)
204 {
205  return ioctl(fd, RTEMS_BLKIO_GETBLKSIZE, block_size);
206 }
207
208 static inline int rtems_disk_fd_set_block_size(int fd, uint32_t block_size)
209 {
210  return ioctl(fd, RTEMS_BLKIO_SETBLKSIZE, &block_size);
211 }
212
213 static inline int rtems_disk_fd_get_block_count(
214  int fd,
215  rtems_blkdev_bnum *block_count
216 )
217 {
218  return ioctl(fd, RTEMS_BLKIO_GETSIZE, block_count);
219 }
220
221 static inline int rtems_disk_fd_get_disk_device(
222  int fd,
223  rtems_disk_device **dd_ptr
224 )
225 {
226  return ioctl(fd, RTEMS_BLKIO_GETDISKDEV, dd_ptr);
227 }
228
229 static inline int rtems_disk_fd_sync(int fd)
230 {
231  return ioctl(fd, RTEMS_BLKIO_SYNCDEV);
232 }
233
234 static inline int rtems_disk_fd_purge(int fd)
235 {
236  return ioctl(fd, RTEMS_BLKIO_PURGEDEV);
237 }
238
239 static inline int rtems_disk_fd_get_device_stats(
240  int fd,
241  rtems_blkdev_stats *stats
242 )
243 {
244  return ioctl(fd, RTEMS_BLKIO_GETDEVSTATS, stats);
245 }
246
247 static inline int rtems_disk_fd_reset_device_stats(int fd)
248 {
249  return ioctl(fd, RTEMS_BLKIO_RESETDEVSTATS);
250 }
251
264 #define RTEMS_BLKDEV_CAP_MULTISECTOR_CONT (1 << 0)
265
271 #define RTEMS_BLKDEV_CAP_SYNC (1 << 1)
272
281 int
282 rtems_blkdev_ioctl(rtems_disk_device *dd, uint32_t req, void *argp);
283
304  const char *device,
305  uint32_t media_block_size,
306  rtems_blkdev_bnum media_block_count,
307  rtems_block_device_ioctl handler,
308  void *driver_data
309 );
310
337  const char *partition,
338  const char *parent_block_device,
339  rtems_blkdev_bnum media_block_begin,
340  rtems_blkdev_bnum media_block_count
341 );
342
347  const rtems_blkdev_stats *stats,
348  rtems_printk_plugin_t print,
349  void *print_arg
350 );
351
355 void rtems_blkstats(
356  FILE *output,
357  const char *device,
358  bool reset
359 );
360
380 #define RTEMS_GENERIC_BLOCK_DEVICE_DRIVER_ENTRIES \
381  rtems_blkdev_generic_open, \
382  rtems_blkdev_generic_close, \
383  rtems_blkdev_generic_read, \
384  rtems_blkdev_generic_write, \
385  rtems_blkdev_generic_ioctl
386
394  rtems_device_major_number major,
395  rtems_device_minor_number minor,
396  void * arg
397 );
398
406  rtems_device_major_number major,
407  rtems_device_minor_number minor,
408  void * arg
409 );
410
418  rtems_device_major_number major,
419  rtems_device_minor_number minor,
420  void * arg
421 );
422
430  rtems_device_major_number major,
431  rtems_device_minor_number minor,
432  void * arg
433 );
434
442  rtems_device_major_number major,
443  rtems_device_minor_number minor,
444  void * arg
445 );
446
451
454 #ifdef __cplusplus
455 }
456 #endif
457
458 #endif
rtems_device_driver rtems_blkdev_generic_ioctl(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Generic block device IO control primitive.
Definition: blkdev.c:172
uint32_t rtems_blkdev_bnum
Block device block index type.
Definition: diskdevs.h:46
rtems_device_driver rtems_blkdev_generic_write(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Generic block device write primitive.
Definition: blkdev.c:79
void * user
User pointer.
Definition: blkdev.h:87
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:80
const rtems_driver_address_table rtems_blkdev_generic_ops
Generic block operations driver address table.
Definition: blkdev-ops.c:25
int(* rtems_block_device_ioctl)(rtems_disk_device *dd, uint32_t req, void *argp)
Block device IO control handler type.
Definition: diskdevs.h:51
rtems_blkdev_request_cb done
Request done callback function.
Definition: blkdev.h:111
void rtems_blkstats(FILE *output, const char *device, bool reset)
Block device statistics command.
Definition: blkdev-blkstats.c:34
Definition: media.c:41
rtems_status_code rtems_blkdev_create_partition(const char *partition, const char *parent_block_device, rtems_blkdev_bnum media_block_begin, rtems_blkdev_bnum media_block_count)
Creates a partition within a parent block device.
Definition: blkdev-imfs.c:317
Block device request type.
Definition: blkdev.h:49
rtems_device_driver rtems_blkdev_generic_close(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Generic block device close primitive.
Definition: blkdev.c:154
uint32_t bufnum
Number of blocks for this request.
Definition: blkdev.h:126
Block device statistics.
Definition: diskdevs.h:93
rtems_status_code rtems_blkdev_create(const char *device, uint32_t media_block_size, rtems_blkdev_bnum media_block_count, rtems_block_device_ioctl handler, void *driver_data)
Creates a block device.
Definition: blkdev-imfs.c:273
struct rtems_blkdev_sg_buffer rtems_blkdev_sg_buffer
Block device scatter or gather buffer structure.
Definition: io.h:52
Description of a disk device (logical and physical disks).
Definition: diskdevs.h:158
rtems_id io_task
The task requesting the IO operation.
Definition: blkdev.h:131
The block device transfer request is used to read or write a number of blocks from or to the device...
Definition: blkdev.h:102
rtems_device_driver rtems_blkdev_generic_read(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Generic block device read primitive.
Definition: blkdev.c:32
rtems_status_code
Classic API Status.
Definition: status.h:46
Block Device Disk Management API.
void(* rtems_blkdev_request_cb)(struct rtems_blkdev_request *req, rtems_status_code status)
Block device request done callback function type.
Definition: blkdev.h:60
Sync any data with the media.
Definition: blkdev.h:52
Read the requested blocks of data.
Definition: blkdev.h:50
Definition: blkdev.h:68
void * buffer
Buffer pointer.
Definition: blkdev.h:82
rtems_blkdev_bnum block
Block index.
Definition: blkdev.h:72
void rtems_blkdev_print_stats(const rtems_blkdev_stats *stats, rtems_printk_plugin_t print, void *print_arg)
Prints the block device statistics.
Definition: blkdev-print-stats.c:30
Interface to Kernel Print Methods.
rtems_device_driver rtems_blkdev_generic_open(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Generic block device open primitive.
Definition: blkdev.c:131
Write the requested blocks of data.
Definition: blkdev.h:51
uint32_t length
Buffer length.
Definition: blkdev.h:77
int rtems_blkdev_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
Common IO control primitive.
Definition: blkdev-ioctl.c:23
int(* rtems_printk_plugin_t)(void *, const char *format,...)
Type definition for function which can be plugged in to certain reporting routines to redirect the ou...
Definition: bspIo.h:129
Block device operation (read or write).
Definition: blkdev.h:106
struct rtems_blkdev_request rtems_blkdev_request
Last IO operation completion status.
Definition: blkdev.h:121
void * done_arg
Argument to be passed to callback function.
Definition: blkdev.h:116
