rtems_blkdev_request Struct Reference
The block device transfer request is used to read or write a number of blocks from or to the device. More...
#include <blkdev.h>
Collaboration diagram for rtems_blkdev_request:
Collaboration graph
[legend]
rtems_blkdev_request_op req
 Block device operation (read or write).
rtems_blkdev_request_cb done
 Request done callback function.
void * done_arg
 Argument to be passed to callback function.
rtems_status_code status
 Last IO operation completion status.
uint32_t bufnum
 Number of blocks for this request.
rtems_id io_task
 The task requesting the IO operation.
rtems_blkdev_sg_buffer bufs [RTEMS_ZERO_LENGTH_ARRAY]
 List of scatter or gather buffers.
Transfer requests are issued to the disk device driver with the RTEMS_BLKIO_REQUEST IO control. The transfer request completion status must be signalled with rtems_blkdev_request_done(). This function must be called exactly once per request. The return value of the IO control will be ignored for transfer requests.
See also
rtems_blkdev_create().
