This module provides functions to manage disk devices. More...
Files | |
file | diskdevs.h |
Block Device Disk Management API. | |
file | diskdevs-init.c |
Block Device Disk Management Initialize. | |
file | diskdevs.c |
Block device disk management implementation. | |
struct | rtems_blkdev_read_ahead |
Block device read-ahead control. More... | |
struct | rtems_blkdev_stats |
Block device statistics. More... | |
struct | rtems_disk_device |
Description of a disk device (logical and physical disks). More... | |
#define | RTEMS_DISK_READ_AHEAD_NO_TRIGGER ((rtems_blkdev_bnum) -1) |
Trigger value to disable further read-ahead requests. | |
Typedefs | |
typedef uint32_t | rtems_blkdev_bnum |
Block device block index type. | |
typedef int(* | rtems_block_device_ioctl) (rtems_disk_device *dd, uint32_t req, void *argp) |
Block device IO control handler type. | |
Disk Device Maintainance | |
rtems_status_code | rtems_disk_create_phys (dev_t dev, uint32_t block_size, rtems_blkdev_bnum block_count, rtems_block_device_ioctl handler, void *driver_data, const char *name) |
Creates a physical disk with device identifier dev. More... | |
rtems_status_code | rtems_disk_create_log (dev_t dev, dev_t phys, rtems_blkdev_bnum block_begin, rtems_blkdev_bnum block_count, const char *name) |
Creates a logical disk with device identifier dev. More... | |
rtems_status_code | rtems_disk_delete (dev_t dev) |
Deletes a physical or logical disk device with identifier dev. More... | |
rtems_disk_device * | rtems_disk_obtain (dev_t dev) |
Returns the disk device descriptor for the device identifier dev. More... | |
rtems_status_code | rtems_disk_release (rtems_disk_device *dd) |
Releases the disk device descriptor dd. More... | |
Disk Management | |
rtems_status_code | rtems_disk_io_initialize (void) |
Initializes the disk device management. More... | |
rtems_status_code | rtems_disk_io_done (void) |
Releases all resources allocated for disk device management. More... | |
A disk is a set of blocks which are identified by a consecutive set of non-negative integers starting at zero. There are also logical disks which contain a subset of consecutive disk blocks. The logical disks are used to represent the partitions of a disk. The disk devices are accessed via the block device buffer module.
rtems_status_code rtems_disk_create_log | ( | dev_t | dev, |
dev_t | phys, | ||
rtems_blkdev_bnum | block_begin, | ||
rtems_blkdev_bnum | block_count, | ||
const char * | name | ||
A logical disk manages a subset of consecutive blocks contained in the physical disk with identifier phys. The start block index of the logical disk device is block_begin. The block count of the logcal disk will be block_count. The blocks must be within the range of blocks managed by the associated physical disk device. A device node will be registered in the file system with absolute path name, if name is not NULL
. The block size and IO control handler are inherited by the physical disk.
RTEMS_SUCCESSFUL | Successful operation. |
RTEMS_NOT_CONFIGURED | Cannot lock disk device operation mutex. |
RTEMS_INVALID_ID | Specified physical disk identifier does not correspond to a physical disk. |
RTEMS_INVALID_NUMBER | Begin block or block count are out of range. |
RTEMS_NO_MEMORY | Not enough memory. |
RTEMS_RESOURCE_IN_USE | Disk device descriptor for logical disk identifier is already in use. |
RTEMS_UNSATISFIED | Cannot create device node. |
References RTEMS_SUCCESSFUL.
rtems_status_code rtems_disk_create_phys | ( | dev_t | dev, |
uint32_t | block_size, | ||
rtems_block_device_ioctl | handler, | ||
void * | driver_data, | ||
The block size block_size must be positive. The disk will have block_count blocks. The block index starts with zero. The associated disk device driver will be invoked via the IO control handler handler. A device node will be registered in the file system with absolute path name, if name is not NULL
. This function is usually invoked from a block device driver during initialization when a physical device is detected in the system. The device driver provides an IO control handler to allow block device operations.
RTEMS_INVALID_ADDRESS | IO control handler is NULL . |
RTEMS_INVALID_NUMBER | Block size is invalid. |
RTEMS_RESOURCE_IN_USE | Disk device descriptor is already in use. |
References RTEMS_INVALID_ADDRESS, and RTEMS_SUCCESSFUL.
rtems_status_code rtems_disk_delete | ( | dev_t | dev | ) |
Marks the disk device as deleted. When a physical disk device is deleted, all corresponding logical disk devices will marked as deleted too. Disks that are marked as deleted and have a usage counter of zero will be deleted. The corresponding device nodes will be removed from the file system. In case of a physical disk deletion the IO control handler will be invoked with a RTEMS_BLKIO_DELETED request. Disks that are still in use will be deleted upon release.
RTEMS_INVALID_ID | No disk for specified device identifier. |
Referenced by rtems_disk_release().
rtems_status_code rtems_disk_io_done | ( | void | ) |
There is no protection against concurrent access. If parts of the system are still in use the behaviour is undefined.
rtems_status_code rtems_disk_io_initialize | ( | void | ) |
This functions returns successful if the disk device management is already initialized. There is no protection against concurrent access.
RTEMS_SUCCESSFUL | Successful initialization. |
RTEMS_NO_MEMORY | Not enough memory or no semaphore available. |
RTEMS_UNSATISFIED | Block device buffer initialization failed. |
rtems_disk_device* rtems_disk_obtain | ( | dev_t | dev | ) |
Increments usage counter by one. You should release the disk device descriptor with rtems_disk_release().
NULL
if no corresponding disk exists. References rtems_interrupt_lock_acquire, and RTEMS_SUCCESSFUL.
rtems_status_code rtems_disk_release | ( | rtems_disk_device * | dd | ) |
Decrements usage counter by one.
References rtems_disk_device::deleted, rtems_disk_device::dev, rtems_disk_delete(), rtems_interrupt_lock_acquire, rtems_interrupt_lock_release, RTEMS_SUCCESSFUL, and rtems_disk_device::uses.
