bdpart.h
1
9 /*
10  * Copyright (c) 2009-2012 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Obere Lagerstr. 30
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef RTEMS_BDPART_H
24 #define RTEMS_BDPART_H
25
26 #include <uuid/uuid.h>
27
28 #include <rtems.h>
29 #include <rtems/blkdev.h>
30
31 #ifdef __cplusplus
32 extern "C" {
33 #endif /* __cplusplus */
34
90 #define RTEMS_BDPART_MBR_EMPTY 0x0U
91
92 #define RTEMS_BDPART_MBR_FAT_12 0x1U
93
94 #define RTEMS_BDPART_MBR_FAT_16 0x4U
95
96 #define RTEMS_BDPART_MBR_FAT_16_LBA 0xeU
97
98 #define RTEMS_BDPART_MBR_FAT_32 0xbU
99
100 #define RTEMS_BDPART_MBR_FAT_32_LBA 0xcU
101
102 #define RTEMS_BDPART_MBR_EXTENDED 0x5U
103
104 #define RTEMS_BDPART_MBR_DATA 0xdaU
105
106 #define RTEMS_BDPART_MBR_GPT 0xeeU
107
108 #define RTEMS_BDPART_MBR_FLAG_ACTIVE 0x80U
109
115 #define RTEMS_BDPART_PARTITION_NUMBER_HINT 16
116
120 typedef struct rtems_bdpart_partition {
125
130
134  uuid_t type;
135
139  uuid_t id;
140
144  uint64_t flags;
146
150 typedef enum {
155
161
165 typedef union {
169  rtems_bdpart_format_type type;
170
174  struct {
175  rtems_bdpart_format_type type;
176
180  uint32_t disk_id;
181
190  } mbr;
191
195  struct {
196  rtems_bdpart_format_type type;
197
201  uuid_t disk_id;
202  } gpt;
204
216  const char *disk_name,
218  rtems_bdpart_partition *partitions,
219  size_t *count
220 );
221
226 void rtems_bdpart_sort( rtems_bdpart_partition *partitions, size_t count);
227
242  const char *disk_name,
244  const rtems_bdpart_partition *partitions,
245  size_t count
246 );
247
259  const char *disk_name,
261  rtems_bdpart_partition *partitions,
262  const unsigned *distribution,
263  size_t count
264 );
265
278  const char *disk_name,
279  const rtems_bdpart_partition *partitions,
280  size_t count
281 );
282
289 rtems_status_code rtems_bdpart_register_from_disk( const char *disk_name);
290
300  const char *disk_name,
301  const rtems_bdpart_partition *partitions,
302  size_t count
303 );
304
320  const char *disk_name,
321  const rtems_bdpart_partition *partitions,
322  size_t count,
323  const char *mount_base
324 );
325
330  const char *disk_name,
331  const rtems_bdpart_partition *partitions,
332  size_t count,
333  const char *mount_base
334 );
335
340 void rtems_bdpart_dump( const rtems_bdpart_partition *partitions, size_t count);
341
346 void rtems_bdpart_to_partition_type( uint8_t mbr_type, uuid_t type);
347
356  const uuid_t type,
357  uint8_t *mbr_type
358 );
359
362 #define RTEMS_BDPART_MBR_CYLINDER_SIZE 63
363
364 #define RTEMS_BDPART_NUMBER_SIZE 4
365
366 #define RTEMS_BDPART_BLOCK_SIZE 512
367
368 #define RTEMS_BDPART_MBR_TABLE_ENTRY_SIZE 16
369
370 #define RTEMS_BDPART_MBR_OFFSET_TABLE_0 446
371
372 #define RTEMS_BDPART_MBR_OFFSET_TABLE_1 \
373  (RTEMS_BDPART_MBR_OFFSET_TABLE_0 + RTEMS_BDPART_MBR_TABLE_ENTRY_SIZE)
374
375 #define RTEMS_BDPART_MBR_OFFSET_DISK_ID 440
376
377 #define RTEMS_BDPART_MBR_OFFSET_SIGNATURE_0 510
378
379 #define RTEMS_BDPART_MBR_OFFSET_SIGNATURE_1 511
380
381 #define RTEMS_BDPART_MBR_SIGNATURE_0 0x55U
382
383 #define RTEMS_BDPART_MBR_SIGNATURE_1 0xaaU
384
385 #define RTEMS_BDPART_MBR_OFFSET_BEGIN 8
386
387 #define RTEMS_BDPART_MBR_OFFSET_SIZE 12
388
389 #define RTEMS_BDPART_MBR_OFFSET_TYPE 4
390
391 #define RTEMS_BDPART_MBR_OFFSET_FLAGS 0
392
393 static inline uint8_t rtems_bdpart_mbr_partition_type(
394  const uuid_t type
395 )
396 {
397  return type [0];
398 }
399
400 rtems_status_code rtems_bdpart_get_disk_data(
401  const char *disk_name,
402  int *fd_ptr,
403  rtems_disk_device **dd_ptr,
404  rtems_blkdev_bnum *disk_end
405 );
406
407 #ifdef __cplusplus
408 }
409 #endif /* __cplusplus */
410
411 #endif /* RTEMS_BDPART_H */
struct rtems_bdpart_partition rtems_bdpart_partition
Partition description.
uint32_t rtems_blkdev_bnum
Block device block index type.
Definition: diskdevs.h:46
bool rtems_bdpart_to_mbr_partition_type(const uuid_t type, uint8_t *mbr_type)
Converts the partition type in type to the MBR partition type.
Definition: bdpart-read.c:51
uuid_t id
Partition ID.
Definition: bdpart.h:139
Disk format for the partition tables.
Definition: bdpart.h:150
uuid_t type
Partition type.
Definition: bdpart.h:134
uint64_t flags
Partition flags.
Definition: bdpart.h:144
Definition: mknod-pack_dev.c:255
rtems_blkdev_bnum end
Block index for partition end (this block is not a part of the partition).
Definition: bdpart.h:129
rtems_status_code rtems_bdpart_unmount(const char *disk_name, const rtems_bdpart_partition *partitions, size_t count, const char *mount_base)
Unmounts all file systems mounted with rtems_bdpart_mount().
Definition: bdpart-mount.c:119
rtems_status_code rtems_bdpart_register(const char *disk_name, const rtems_bdpart_partition *partitions, size_t count)
Registers the partitions as logical disks for the physical disk device with name disk_name.
Definition: bdpart-register.c:63
rtems_status_code rtems_bdpart_mount(const char *disk_name, const rtems_bdpart_partition *partitions, size_t count, const char *mount_base)
Mounts all supported file systems inside the logical disks derived from the partitions of the physica...
Definition: bdpart-mount.c:33
Disk format description.
Definition: bdpart.h:165
rtems_status_code rtems_bdpart_read(const char *disk_name, rtems_bdpart_format *format, rtems_bdpart_partition *partitions, size_t *count)
Reads the partition information from the physical disk device with name disk_name.
Definition: bdpart-read.c:223
Description of a disk device (logical and physical disks).
Definition: diskdevs.h:158
void rtems_bdpart_sort(rtems_bdpart_partition *partitions, size_t count)
Sorts the partition table partitions with count partitions to have ascending begin blocks...
Definition: bdpart-sort.c:44
rtems_status_code
Classic API Status.
Definition: status.h:46
void rtems_bdpart_to_partition_type(uint8_t mbr_type, uuid_t type)
Returns the partition type for the MBR partition type value mbr_type in type.
Definition: bdpart-read.c:45
rtems_status_code rtems_bdpart_unregister(const char *disk_name, const rtems_bdpart_partition *partitions, size_t count)
Deletes the logical disks associated with the partitions of the disk device with name disk_name...
Definition: bdpart-register.c:143
Type value for GPT format.
Definition: bdpart.h:159
rtems_status_code rtems_bdpart_register_from_disk(const char *disk_name)
brief Reads the partition table from the disk device with name disk_name and registers the partitions...
Definition: bdpart-register.c:126
void rtems_bdpart_dump(const rtems_bdpart_partition *partitions, size_t count)
Prints the partition table partitions with count partitions to standard output.
Definition: bdpart-dump.c:39
bool dos_compatibility
This option is used for partition table creation and validation checks before a write to the disk...
Definition: bdpart.h:189
Format type.
Definition: bdpart.h:169
rtems_status_code rtems_bdpart_write(const char *disk_name, const rtems_bdpart_format *format, const rtems_bdpart_partition *partitions, size_t count)
Writes the partition table to the physical disk device with name disk_name.
Definition: bdpart-write.c:85
Definition: bdpart.h:120
uint32_t disk_id
Disk ID in MBR at offset 440.
Definition: bdpart.h:180
Type value for MBR format.
Definition: bdpart.h:154
Block Device Management.
rtems_blkdev_bnum begin
Block index for partition begin.
Definition: bdpart.h:124
rtems_status_code rtems_bdpart_create(const char *disk_name, const rtems_bdpart_format *format, rtems_bdpart_partition *partitions, const unsigned *distribution, size_t count)
Creates a partition table in partitions with count partitions for the physical disk device with name ...
Definition: bdpart-create.c:28
