char * | crypt (const char *, const char *) |
void | link_required (int unit) |
void | link_terminated (int unit) |
void | link_down (int unit) |
void | link_established (int unit) |
void | start_networks (void) |
void | auth_peer_fail (int unit, int protocol) |
void | auth_peer_success (int unit, int protocol, char *name, int namelen) |
void | auth_withpeer_fail (int unit, int protocol) |
void | auth_withpeer_success (int unit, int protocol) |
void | np_up (int unit, int proto) |
void | np_down (int unit, int proto) |
void | np_finished (int unit, int proto) |
int | auth_check_options (void) |
void | auth_reset (int unit) |
int | check_passwd (int unit, char *auser, int userlen, char *apasswd, int passwdlen, char **msg) |
int | get_secret (int unit, char *client, char *server, unsigned char *secret, int *secret_len, int am_server) |
int | auth_ip_addr (int unit, uint32_t addr) |
int | bad_ip_adrs (uint32_t addr) |
char | peer_authname [MAXNAMELEN] |
void(* | auth_linkup_hook )(void) = NULL |
void(* | auth_linkdown_hook )(void) = NULL |
int(* | idle_time_hook )(struct ppp_idle *) = NULL |
int(* | pap_check_hook )(void) = NULL |
int(* | pap_auth_hook )(char *user, char *passwd) = NULL |
void(* | pap_logout_hook )(void) = NULL |
int(* | pap_passwd_hook )(char *user, char *passwd) = NULL |
bool | uselogin = 0 |
bool | cryptpap = 0 |
bool | refuse_pap = 0 |
bool | refuse_chap = 0 |
bool | usehostname = 0 |
bool | auth_required = 0 |
bool | allow_any_ip = 0 |
bool | explicit_remote = 0 |
char | remote_name [MAXNAMELEN] |
option_t | auth_options [] |
