lcp.h
1 /*
2  * lcp.h - Link Control Protocol definitions.
3  *
4  * Copyright (c) 1989 Carnegie Mellon University.
5  * All rights reserved.
6  *
7  * Redistribution and use in source and binary forms are permitted
8  * provided that the above copyright notice and this paragraph are
9  * duplicated in all such forms and that any documentation,
10  * advertising materials, and other materials related to such
11  * distribution and use acknowledge that the software was developed
12  * by Carnegie Mellon University. The name of the
13  * University may not be used to endorse or promote products derived
14  * from this software without specific prior written permission.
15  * THIS SOFTWARE IS PROVIDED ``AS IS'' AND WITHOUT ANY EXPRESS OR
16  * IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
17  * WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE.
18  *
19  * $Id$
20  */
21
22 /*
23  * Options.
24  */
25 #define CI_MRU 1 /* Maximum Receive Unit */
26 #define CI_ASYNCMAP 2 /* Async Control Character Map */
27 #define CI_AUTHTYPE 3 /* Authentication Type */
28 #define CI_QUALITY 4 /* Quality Protocol */
29 #define CI_MAGICNUMBER 5 /* Magic Number */
30 #define CI_PCOMPRESSION 7 /* Protocol Field Compression */
31 #define CI_ACCOMPRESSION 8 /* Address/Control Field Compression */
32 #define CI_CALLBACK 13 /* callback */
33
34 /*
35  * LCP-specific packet types.
36  */
37 #define PROTREJ 8 /* Protocol Reject */
38 #define ECHOREQ 9 /* Echo Request */
39 #define ECHOREP 10 /* Echo Reply */
40 #define DISCREQ 11 /* Discard Request */
41 #define CBCP_OPT 6 /* Use callback control protocol */
42
43 /*
44  * The state of options is described by an lcp_options structure.
45  */
46 typedef struct lcp_options {
47  bool passive; /* Don't die if we don't get a response */
48  bool silent; /* Wait for the other end to start first */
49  bool restart; /* Restart vs. exit after close */
50  bool neg_mru; /* Negotiate the MRU? */
51  bool neg_asyncmap; /* Negotiate the async map? */
52  bool neg_upap; /* Ask for UPAP authentication? */
53  bool neg_chap; /* Ask for CHAP authentication? */
54  bool neg_magicnumber; /* Ask for magic number? */
55  bool neg_pcompression; /* HDLC Protocol Field Compression? */
56  bool neg_accompression; /* HDLC Address/Control Field Compression? */
57  bool neg_lqr; /* Negotiate use of Link Quality Reports */
58  bool neg_cbcp; /* Negotiate use of CBCP */
59  int mru; /* Value of MRU */
60  u_char chap_mdtype; /* which MD type (hashing algorithm) */
61  uint32_t asyncmap; /* Value of async map */
62  uint32_t magicnumber;
63  int numloops; /* Number of loops during magic number neg. */
64  uint32_t lqr_period; /* Reporting period for LQR 1/100ths second */
65 } lcp_options;
66
67 extern fsm lcp_fsm[];
68 extern lcp_options lcp_wantoptions[];
69 extern lcp_options lcp_gotoptions[];
70 extern lcp_options lcp_allowoptions[];
71 extern lcp_options lcp_hisoptions[];
72 extern uint32_t xmit_accm[][8];
73
74 #define DEFMRU 1500 /* Try for this */
75 #define MINMRU 128 /* No MRUs below this */
76 #define MAXMRU 16384 /* Normally limit MRU to this */
77
78 void lcp_open(int);
79 void lcp_close(int, char *);
80 void lcp_lowerup(int);
81 void lcp_lowerdown(int);
82 void lcp_sprotrej(int, u_char *, int); /* send protocol reject */
83
84 extern struct protent lcp_protent;
85
86 /* Default number of times we receive our magic number from the peer
87  before deciding the link is looped-back. */
88 #define DEFLOOPBACKFAIL 10
Definition: fsm.h:44
Definition: pppd.h:250
Definition: lcp.h:47
