lcp.h File Reference
struct  lcp_options
#define CI_MRU   1 /* Maximum Receive Unit */
#define CI_ASYNCMAP   2 /* Async Control Character Map */
#define CI_AUTHTYPE   3 /* Authentication Type */
#define CI_QUALITY   4 /* Quality Protocol */
#define CI_MAGICNUMBER   5 /* Magic Number */
#define CI_PCOMPRESSION   7 /* Protocol Field Compression */
#define CI_ACCOMPRESSION   8 /* Address/Control Field Compression */
#define CI_CALLBACK   13 /* callback */
#define PROTREJ   8 /* Protocol Reject */
#define ECHOREQ   9 /* Echo Request */
#define ECHOREP   10 /* Echo Reply */
#define DISCREQ   11 /* Discard Request */
#define CBCP_OPT   6 /* Use callback control protocol */
#define DEFMRU   1500 /* Try for this */
#define MINMRU   128 /* No MRUs below this */
#define MAXMRU   16384 /* Normally limit MRU to this */
#define DEFLOOPBACKFAIL   10
typedef struct lcp_options lcp_options
void lcp_open (int)
void lcp_close (int, char *)
void lcp_lowerup (int)
void lcp_lowerdown (int)
void lcp_sprotrej (int, u_char *, int)
fsm lcp_fsm []
lcp_options lcp_wantoptions []
lcp_options lcp_gotoptions []
lcp_options lcp_allowoptions []
lcp_options lcp_hisoptions []
uint32_t xmit_accm [][8]
struct protent lcp_protent
