chap.h
1 /*
2  * chap.h - Challenge Handshake Authentication Protocol definitions.
3  *
4  * Copyright (c) 1993 The Australian National University.
5  * All rights reserved.
6  *
7  * Redistribution and use in source and binary forms are permitted
8  * provided that the above copyright notice and this paragraph are
9  * duplicated in all such forms and that any documentation,
10  * advertising materials, and other materials related to such
11  * distribution and use acknowledge that the software was developed
12  * by the Australian National University. The name of the University
13  * may not be used to endorse or promote products derived from this
14  * software without specific prior written permission.
15  * THIS SOFTWARE IS PROVIDED ``AS IS'' AND WITHOUT ANY EXPRESS OR
16  * IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
17  * WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE.
18  *
19  * Copyright (c) 1991 Gregory M. Christy
20  * All rights reserved.
21  *
22  * Redistribution and use in source and binary forms are permitted
23  * provided that the above copyright notice and this paragraph are
24  * duplicated in all such forms and that any documentation,
25  * advertising materials, and other materials related to such
26  * distribution and use acknowledge that the software was developed
27  * by the author.
28  *
29  * THIS SOFTWARE IS PROVIDED ``AS IS'' AND WITHOUT ANY EXPRESS OR
30  * IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
31  * WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE.
32  *
33  * $Id$
34  */
35
36 #ifndef __CHAP_INCLUDE__
37
38 /* Code + ID + length */
39 #define CHAP_HEADERLEN 4
40
41 /*
42  * CHAP codes.
43  */
44
45 #define CHAP_DIGEST_MD5 5 /* use MD5 algorithm */
46 #define MD5_SIGNATURE_SIZE 16 /* 16 bytes in a MD5 message digest */
47 #define CHAP_MICROSOFT 0x80 /* use Microsoft-compatible alg. */
48 #define MS_CHAP_RESPONSE_LEN 49 /* Response length for MS-CHAP */
49
50 #define CHAP_CHALLENGE 1
51 #define CHAP_RESPONSE 2
52 #define CHAP_SUCCESS 3
53 #define CHAP_FAILURE 4
54
55 /*
56  * Challenge lengths (for challenges we send) and other limits.
57  */
58 #define MIN_CHALLENGE_LENGTH 16
59 #define MAX_CHALLENGE_LENGTH 24
60 #define MAX_RESPONSE_LENGTH 64 /* sufficient for MD5 or MS-CHAP */
61
62 /*
63  * Each interface is described by a chap structure.
64  */
65
66 typedef struct chap_state {
67  int unit; /* Interface unit number */
68  int clientstate; /* Client state */
69  int serverstate; /* Server state */
70  u_char challenge[MAX_CHALLENGE_LENGTH]; /* last challenge string sent */
71  u_char chal_len; /* challenge length */
72  u_char chal_id; /* ID of last challenge */
73  u_char chal_type; /* hash algorithm for challenges */
74  u_char id; /* Current id */
75  char *chal_name; /* Our name to use with challenge */
76  int chal_interval; /* Time until we challenge peer again */
77  int timeouttime; /* Timeout time in seconds */
78  int max_transmits; /* Maximum # of challenge transmissions */
79  int chal_transmits; /* Number of transmissions of challenge */
80  int resp_transmits; /* Number of transmissions of response */
81  u_char response[MAX_RESPONSE_LENGTH]; /* Response to send */
82  u_char resp_length; /* length of response */
83  u_char resp_id; /* ID for response messages */
84  u_char resp_type; /* hash algorithm for responses */
85  char *resp_name; /* Our name to send with response */
86 } chap_state;
87
88
89 /*
90  * Client (peer) states.
91  */
92 #define CHAPCS_INITIAL 0 /* Lower layer down, not opened */
93 #define CHAPCS_CLOSED 1 /* Lower layer up, not opened */
94 #define CHAPCS_PENDING 2 /* Auth us to peer when lower up */
95 #define CHAPCS_LISTEN 3 /* Listening for a challenge */
96 #define CHAPCS_RESPONSE 4 /* Sent response, waiting for status */
97 #define CHAPCS_OPEN 5 /* We've received Success */
98
99 /*
100  * Server (authenticator) states.
101  */
102 #define CHAPSS_INITIAL 0 /* Lower layer down, not opened */
103 #define CHAPSS_CLOSED 1 /* Lower layer up, not opened */
104 #define CHAPSS_PENDING 2 /* Auth peer when lower up */
105 #define CHAPSS_INITIAL_CHAL 3 /* We've sent the first challenge */
106 #define CHAPSS_OPEN 4 /* We've sent a Success msg */
107 #define CHAPSS_RECHALLENGE 5 /* We've sent another challenge */
108 #define CHAPSS_BADAUTH 6 /* We've sent a Failure msg */
109
110 /*
111  * Timeouts.
112  */
113 #define CHAP_DEFTIMEOUT 5 /* Timeout time in seconds */
114 #define CHAP_DEFTRANSMITS 10 /* max # times to send challenge */
115
116 extern chap_state chap[];
117
118 void ChapAuthWithPeer(int, char *, int);
119 void ChapAuthPeer(int, char *, int);
120
121 extern struct protent chap_protent;
122
123 #define __CHAP_INCLUDE__
124 #endif /* __CHAP_INCLUDE__ */
Definition: pppd.h:250
Definition: chap.h:67
