RTEMS Logo
RTEMS 4.6.0 On-Line Library
Command and Variable Index
PREV UP NEXT Bookshelf RTEMS C User's Guide
  • _Internal_errors_What_happened
  • confdefs.h
  • CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
  • CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
  • CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
  • CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
  • CONFIGURE_EXECUTIVE_RAM_WORK_AREA
  • CONFIGURE_EXTRA_TASK_STACKS
  • CONFIGURE_GNAT_RTEMS
  • CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
  • CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
  • CONFIGURE_HAS_OWN_INIT_TASK_TABLE
  • CONFIGURE_HAS_OWN_MOUNT_TABLE
  • CONFIGURE_HAS_OWN_MULTIPROCESING_TABLE
  • CONFIGURE_INIT_TASK_ARGUMENTS
  • CONFIGURE_INIT_TASK_ATTRIBUTES
  • CONFIGURE_INIT_TASK_ENTRY_POINT
  • CONFIGURE_INIT_TASK_INITIAL_MODES
  • CONFIGURE_INIT_TASK_NAME
  • CONFIGURE_INIT_TASK_PRIORITY
  • CONFIGURE_INIT_TASK_STACK_SIZE
  • CONFIGURE_INTERRUPT_STACK_MEMORY
  • CONFIGURE_ITRON_HAS_OWN_INIT_TASK_TABLE
  • CONFIGURE_ITRON_INIT_TASK_ATTRIBUTES
  • CONFIGURE_ITRON_INIT_TASK_ENTRY_POINT
  • CONFIGURE_ITRON_INIT_TASK_PRIORITY
  • CONFIGURE_ITRON_INIT_TASK_STACK_SIZE
  • CONFIGURE_ITRON_INIT_TASK_TABLE
  • CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
  • CONFIGURE_MAXIMUM_ADA_TASKS
  • CONFIGURE_MAXIMUM_DEVICES
  • CONFIGURE_MAXIMUM_DRIVERS
  • CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
  • CONFIGURE_MAXIMUM_ITRON_EVENTFLAGS
  • CONFIGURE_MAXIMUM_ITRON_FIXED_MEMORY_POOLS
  • CONFIGURE_MAXIMUM_ITRON_MAILBOXES
  • CONFIGURE_MAXIMUM_ITRON_MEMORY_POOLS
  • CONFIGURE_MAXIMUM_ITRON_MESSAGE_BUFFERS
  • CONFIGURE_MAXIMUM_ITRON_PORTS
  • CONFIGURE_MAXIMUM_ITRON_SEMAPHORES
  • CONFIGURE_MAXIMUM_ITRON_TASKS
  • CONFIGURE_MAXIMUM_MESSAGE_QUEUES
  • CONFIGURE_MAXIMUM_PARTITIONS
  • CONFIGURE_MAXIMUM_PERIODS
  • CONFIGURE_MAXIMUM_PORTS
  • CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
  • CONFIGURE_MAXIMUM_POSIX_KEYS
  • CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
  • CONFIGURE_MAXIMUM_POSIX_MUTEXES
  • CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
  • CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
  • CONFIGURE_MAXIMUM_POSIX_THREADS
  • CONFIGURE_MAXIMUM_POSIX_TIMERS
  • CONFIGURE_MAXIMUM_REGIONS
  • CONFIGURE_MAXIMUM_SEMAPHORES
  • CONFIGURE_MAXIMUM_TASKS
  • CONFIGURE_MAXIMUM_TIMERS
  • CONFIGURE_MAXIMUM_USER_EXTENSIONS
  • CONFIGURE_MEMORY_OVERHEAD
  • CONFIGURE_MICROSECONDS_PER_TICK
  • CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
  • CONFIGURE_MP_MAXIMUM_NODES
  • CONFIGURE_MP_MAXIMUM_PROXIES
  • CONFIGURE_MP_MPCI_TABLE_POINTER
  • CONFIGURE_MP_NODE_NUMBER
  • CONFIGURE_NUMBER_OF_TERMIOS_PORTS
  • CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
  • CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
  • CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
  • CONFIGURE_POSIX_INIT_THREAD_TABLE
  • CONFIGURE_RTEMS_INIT_TASKS_TABLE
  • CONFIGURE_TERMIOS_DISABLED
  • CONFIGURE_TICKS_PER_TIMESLICE
  • CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
  • posix_api_configuration_table
  • posix_initialization_threads_table
  • rtems extensions table index
  • rtems_address
  • rtems_api_configuration_table
  • rtems_asr
  • rtems_asr_entry
  • rtems_attribute
  • rtems_boolean
  • rtems_build_name
  • rtems_clock_get
  • rtems_clock_get_options
  • rtems_clock_set
  • rtems_clock_tick
  • rtems_configuration_table
  • rtems_context
  • rtems_context_fp
  • rtems_device_driver
  • rtems_device_driver_entry
  • rtems_device_major_number
  • rtems_device_minor_number
  • rtems_double
  • rtems_driver_address_table
  • rtems_event_receive
  • rtems_event_send
  • rtems_event_set
  • rtems_extension
  • rtems_extension_create
  • rtems_extension_delete
  • rtems_extension_ident
  • rtems_extensions_table
  • rtems_fatal_error_occurred
  • rtems_fatal_extension
  • rtems_get_class
  • rtems_get_index
  • rtems_get_node
  • rtems_id
  • rtems_initialization_tasks_table
  • rtems_initialize_executive
  • rtems_initialize_executive_early
  • rtems_initialize_executive_late
  • rtems_interrupt_catch
  • rtems_interrupt_disable
  • rtems_interrupt_enable
  • rtems_interrupt_flash
  • rtems_interrupt_frame
  • rtems_interrupt_is_in_progress
  • rtems_interrupt_level
  • rtems_interval
  • rtems_io_close
  • rtems_io_control
  • rtems_io_initialize
  • rtems_io_lookup_name
  • rtems_io_open
  • rtems_io_read
  • rtems_io_register_driver
  • rtems_io_register_name
  • rtems_io_unregister_driver
  • rtems_io_write
  • rtems_isr
  • rtems_isr_entry
  • rtems_message_queue_broadcast
  • rtems_message_queue_create
  • rtems_message_queue_delete
  • rtems_message_queue_flush
  • rtems_message_queue_get_number_pending
  • rtems_message_queue_ident
  • rtems_message_queue_receive
  • rtems_message_queue_send
  • rtems_message_queue_urgent
  • rtems_mode
  • rtems_mp_packet_classes
  • rtems_mpci_entry
  • rtems_mpci_get_packet_entry
  • rtems_mpci_initialization_entry
  • rtems_mpci_receive_packet_entry
  • rtems_mpci_return_packet_entry
  • rtems_mpci_send_packet_entry
  • rtems_mpci_table
  • rtems_multiprocessing_announce
  • rtems_object_name
  • rtems_option
  • rtems_packet_prefix
  • rtems_partition_create
  • rtems_partition_delete
  • rtems_partition_get_buffer
  • rtems_partition_ident
  • rtems_partition_return_buffer
  • rtems_port_create
  • rtems_port_delete
  • rtems_port_external_to_internal
  • rtems_port_ident
  • rtems_port_internal_to_external
  • rtems_rate_monotonic_cancel
  • rtems_rate_monotonic_create
  • rtems_rate_monotonic_delete
  • rtems_rate_monotonic_get_status
  • rtems_rate_monotonic_ident
  • rtems_rate_monotonic_period
  • rtems_rate_monotonic_period_status
  • rtems_region_create
  • rtems_region_delete
  • rtems_region_extend
  • rtems_region_get_segment
  • rtems_region_get_segment_size
  • rtems_region_ident
  • rtems_region_return_segment
  • rtems_semaphore_create
  • rtems_semaphore_delete
  • rtems_semaphore_flush
  • rtems_semaphore_ident
  • rtems_semaphore_obtain
  • rtems_semaphore_release
  • rtems_shutdown_executive
  • rtems_signal_catch
  • rtems_signal_send
  • rtems_signal_set
  • rtems_signed16
  • rtems_signed32
  • rtems_signed64
  • rtems_signed8
  • rtems_single
  • rtems_status_codes
  • rtems_task
  • rtems_task_argument
  • rtems_task_begin_extension
  • rtems_task_create
  • rtems_task_create_extension
  • rtems_task_delete
  • rtems_task_delete_extension
  • rtems_task_entry
  • rtems_task_exitted_extension
  • rtems_task_get_note
  • rtems_task_ident
  • rtems_task_is_suspended
  • rtems_task_mode
  • rtems_task_priority
  • rtems_task_restart
  • rtems_task_restart_extension
  • rtems_task_resume
  • rtems_task_set_note
  • rtems_task_set_priority
  • rtems_task_start
  • rtems_task_start_extension
  • rtems_task_suspend
  • rtems_task_switch_extension
  • rtems_task_variable_add
  • rtems_task_variable_delete
  • rtems_task_variable_get
  • rtems_task_wake_after
  • rtems_task_wake_when
  • rtems_tcb
  • rtems_time_of_day
  • rtems_timer_cancel
  • rtems_timer_create
  • rtems_timer_delete
  • rtems_timer_fire_after
  • rtems_timer_fire_when
  • rtems_timer_ident
  • rtems_timer_initiate_server
  • rtems_timer_reset
  • rtems_timer_server_fire_after
  • rtems_timer_server_fire_when
  • rtems_timer_service_routine
  • rtems_timer_service_routine_entry
  • rtems_unsigned16
  • rtems_unsigned32
  • rtems_unsigned64
  • rtems_unsigned8
  • rtems_vector_number
  • STACK_CHECKER_ON
  • PREV UP NEXT Bookshelf RTEMS C User's Guide
