rtems_status_code rtems_clock_get( rtems_clock_get_options option, void *time_buffer );
RTEMS_SUCCESSFUL - current time obtained successfully
RTEMS_NOT_DEFINED - system date and time is not set
This directive obtains the system date and time. If
the caller is attempting to obtain the date and time (i.e.
option is set to either RTEMS_CLOCK_GET_SECONDS_SINCE_EPOCH,
RTEMS_CLOCK_GET_TOD, or
RTEMS_CLOCK_GET_TIME_VALUE) and the date and time
has not been set with a previous call to
rtems_clock_set, then the
RTEMS_NOT_DEFINED status code is returned.
The caller can always obtain the number of ticks per second (option is
RTEMS_CLOCK_GET_TICKS_PER_SECOND) and the number of
ticks since the executive was initialized option is
RTEMS_CLOCK_GET_TICKS_SINCE_BOOT).
The option argument may taken on any value of the enumerated
type rtems_clock_get_options. The data type expected for
time_buffer is based on the value of option as
indicated below:
RTEMS_CLOCK_GET_TOD - (rtems_time_of_day *)
RTEMS_CLOCK_GET_TIME_VALUE - (rtems_clock_time_value *)
RTEMS_CLOCK_GET_TICKS_SINCE_BOOT - (rtems_interval *)
RTEMS_CLOCK_GET_SECONDS_SINCE_EPOCH - (rtems_interval *)
RTEMS_CLOCK_GET_TICKS_PER_SECOND - (rtems_interval *)
This directive is callable from an ISR.
This directive will not cause the running task to be
preempted. Re-initializing RTEMS causes the system date and
time to be reset to an uninitialized state. Another call to
rtems_clock_set is required to re-initialize the
system date and time to application specific specifications.
