RTEMS Logo
RTEMS 4.6.0 On-Line Library
Rate Monotonic Manager RATE_MONOTONIC_GET_STATUS - Obtain status information on period
PREV UP NEXT Bookshelf RTEMS C User's Guide
19.4.6: RATE_MONOTONIC_GET_STATUS - Obtain status information on period
CALLING SEQUENCE:
rtems_status_code rtems_rate_monotonic_get_status(
  rtems_id                            id,
  rtems_rate_monotonic_period_status *status
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - period initiated successfully
RTEMS_INVALID_ID - invalid rate monotonic period id
RTEMS_INVALID_ADDRESS - invalid address of status
DESCRIPTION:
This directive returns status information associated with the rate monotonic period id in the following data structure:
typedef struct {
  rtems_rate_monotonic_period_states  state;
  rtems_unsigned32                    ticks_since_last_period;
  rtems_unsigned32                    ticks_executed_since_last_period;
}  rtems_rate_monotonic_period_status;
If the period's state is RATE_MONOTONIC_INACTIVE, both ticks_since_last_period and ticks_executed_since_last_period will be set to 0. Otherwise, ticks_since_last_period will contain the number of clock ticks which have occurred since the last invocation of the rtems_rate_monotonic_period directive. Also in this case, the ticks_executed_since_last_period will indicate how much processor time the owning task has consumed since the invocation of the rtems_rate_monotonic_period directive.
NOTES:
This directive will not cause the running task to be preempted.
