RTEMS Logo
RTEMS 4.6.0 On-Line Library
Configuring a System Driver Address Table
PREV UP NEXT Bookshelf RTEMS C User's Guide
22.8: Driver Address Table
The Device Driver Table is used to inform the I/O Manager of the set of entry points for each device driver configured in the system. The table contains one entry for each device driver required by the application. The number of entries is defined in the number_of_device_drivers entry in the Configuration Table. This table is copied to the Device Drive Table during the IO Manager's initialization giving the entries in this table the lower major numbers. The format of each entry in the Device Driver Table is defined in the following C structure:
typedef struct {
  rtems_device_driver_entry initialization;
  rtems_device_driver_entry open;
  rtems_device_driver_entry close;
  rtems_device_driver_entry read;
  rtems_device_driver_entry write;
  rtems_device_driver_entry control;
} rtems_driver_address_table;
initialization
is the address of the entry point called by rtems_io_initialize to initialize a device driver and its associated devices.
open
is the address of the entry point called by rtems_io_open.
close
is the address of the entry point called by rtems_io_close.
read
is the address of the entry point called by rtems_io_read.
write
is the address of the entry point called by rtems_io_write.
control
is the address of the entry point called by rtems_io_control.
Driver entry points configured as NULL will always return a status code of RTEMS_SUCCESSFUL. No user code will be executed in this situation.
A typical declaration for a Device Driver Table might appear as follows:
rtems_driver_address_table Driver_table[2] = {
   { tty_initialize, tty_open,  tty_close,  /* major = 0 */
     tty_read,       tty_write, tty_control
   { lp_initialize, lp_open,    lp_close,   /* major = 1 */
     NULL,          lp_write,   lp_control
More information regarding the construction and operation of device drivers is provided in the I/O Manager chapter.
