rtems_status_code rtems_timer_server_fire_when( rtems_id id, rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data );
RTEMS_SUCCESSFUL - timer initiated successfully
RTEMS_INVALID_ID - invalid timer id
RTEMS_NOT_DEFINED - system date and time is not set
RTEMS_INVALID_CLOCK - invalid time of day
RTEMS_INCORRECT_STATE - Timer Server not initiated
This directive initiates the timer specified by id and specifies that when it fires it will be executed by the Timer Server.
If the timer is running, it is automatically canceled before being initiated. The timer is scheduled to fire at the time of day specified by wall_time. When the timer fires, the timer service routine routine will be invoked with the argument user_data.
This directive will not cause the running task to be preempted.
