rtems_status_code rtems_task_get_note( rtems_id id, rtems_unsigned32 notepad, rtems_unsigned32 *note );
RTEMS_SUCCESSFUL - note obtained successfully
RTEMS_INVALID_ID - invalid task id
RTEMS_INVALID_NUMBER - invalid notepad location
This directive returns the note contained in the notepad location of the task specified by id.
This directive will not cause the running task to be preempted.
If id is set to RTEMS_SELF,
the calling task accesses its own notepad.
The sixteen notepad locations can be accessed using the constants
RTEMS_NOTEPAD_0 through RTEMS_NOTEPAD_15.
Getting a note of a global task which does not reside on the local node will generate a request to the remote node to obtain the notepad entry of the specified task.
