RTEMS Logo
RTEMS 4.6.0 On-Line Library
Task Manager TASK_SET_NOTE - Set task notepad entry
PREV UP NEXT Bookshelf RTEMS C User's Guide
5.4.12: TASK_SET_NOTE - Set task notepad entry
CALLING SEQUENCE:
rtems_status_code rtems_task_set_note(
  rtems_id         id,
  rtems_unsigned32 notepad,
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - task's note set successfully
RTEMS_INVALID_ID - invalid task id
RTEMS_INVALID_NUMBER - invalid notepad location
DESCRIPTION:
This directive sets the notepad entry for the task specified by id to the value note.
NOTES:
If id is set to RTEMS_SELF, the calling task accesses its own notepad locations.
This directive will not cause the running task to be preempted.
The sixteen notepad locations can be accessed using the constants RTEMS_NOTEPAD_0 through RTEMS_NOTEPAD_15.
Setting a notepad location of a global task which does not reside on the local node will generate a request to the remote node to set the specified notepad entry.
