Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
Thread Queue Handler
This handler provides the capability to have threads block in ordered sets. More...
Collaboration diagram for Thread Queue Handler:
struct  Thread_queue_Operations
 Thread queue operations. More...
struct  Thread_queue_Control
 This is the structure used to manage sets of tasks which are blocked waiting to acquire a resource. More...
#define THREAD_QUEUE_FIFO_INITIALIZER(designator, name)
#define THREAD_QUEUE_PRIORITY_INITIALIZER(designator, name)
typedef struct Thread_Control Thread_Control
typedef struct Thread_queue_Control Thread_queue_Control
typedef void(* Thread_queue_Priority_change_operation) (Thread_Control *the_thread, Priority_Control new_priority, Thread_queue_Control *the_thread_queue)
 Thread queue priority change operation. More...
typedef void(* Thread_queue_Initialize_operation) (Thread_queue_Control *the_thread_queue)
 Thread queue initialize operation. More...
typedef void(* Thread_queue_Enqueue_operation) (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread)
 Thread queue enqueue operation. More...
typedef void(* Thread_queue_Extract_operation) (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread)
 Thread queue extract operation. More...
typedef Thread_Control *(* Thread_queue_First_operation) (Thread_queue_Control *the_thread_queue)
 Thread queue first operation. More...
typedef void(* Thread_queue_Flush_callout) (Thread_Control *)
 The following type defines the callout used when a remote task is extracted from a local thread queue.
enum  Thread_queue_Disciplines { THREAD_QUEUE_DISCIPLINE_FIFO, THREAD_QUEUE_DISCIPLINE_PRIORITY }
 The following enumerated type details all of the disciplines supported by the Thread Queue Handler.
RTEMS_INLINE_ROUTINE void _Thread_queue_Acquire_critical (Thread_queue_Control *the_thread_queue, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _Thread_queue_Acquire (Thread_queue_Control *the_thread_queue, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _Thread_queue_Release (Thread_queue_Control *the_thread_queue, ISR_lock_Context *lock_context)
Thread_Control * _Thread_queue_Dequeue (Thread_queue_Control *the_thread_queue)
 Gets a pointer to a thread waiting on the_thread_queue. More...
void _Thread_queue_Enqueue_critical (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread, States_Control state, Watchdog_Interval timeout, uint32_t timeout_code, ISR_lock_Context *lock_context)
 Blocks the thread and places it on the thread queue. More...
RTEMS_INLINE_ROUTINE void _Thread_queue_Enqueue (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread, States_Control state, Watchdog_Interval timeout, uint32_t timeout_code)
 Acquires the thread queue lock and calls _Thread_queue_Enqueue_critical().
void _Thread_queue_Extract_locked (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread)
 Extracts the thread from the thread queue, restores the default wait operations and restores the default thread lock. More...
void _Thread_queue_Unblock_critical (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Unblocks the thread which was on the thread queue before. More...
void _Thread_queue_Extract_critical (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Extracts the thread from the thread queue and unblocks it. More...
void _Thread_queue_Extract (Thread_Control *the_thread)
 Extracts thread from thread queue. More...
void _Thread_queue_Extract_with_proxy (Thread_Control *the_thread)
 Extracts the_thread from the_thread_queue. More...
RTEMS_INLINE_ROUTINE Thread_Control * _Thread_queue_First_locked (Thread_queue_Control *the_thread_queue)
 Returns the first thread on the thread queue if it exists, otherwise NULL. More...
Thread_Control * _Thread_queue_First (Thread_queue_Control *the_thread_queue)
void _Thread_queue_Flush (Thread_queue_Control *the_thread_queue, Thread_queue_Flush_callout remote_extract_callout, uint32_t status)
 Unblocks all threads blocked on the_thread_queue. More...
void _Thread_queue_Initialize (Thread_queue_Control *the_thread_queue, Thread_queue_Disciplines the_discipline)
 Initialize the_thread_queue. More...
RTEMS_INLINE_ROUTINE void _Thread_queue_Destroy (Thread_queue_Control *the_thread_queue)
RBTree_Compare_result _Thread_queue_Compare_priority (const RBTree_Node *left, const RBTree_Node *right)
 Compare two thread's priority for RBTree Insertion. More...
const Thread_queue_Operations _Thread_queue_Operations_default
const Thread_queue_Operations _Thread_queue_Operations_FIFO
const Thread_queue_Operations _Thread_queue_Operations_priority
The sets may be ordered using the FIFO or priority discipline.
◆ THREAD_QUEUE_FIFO_INITIALIZER
#define THREAD_QUEUE_FIFO_INITIALIZER (   designator,
  name
Value:
.Queues = { \
.Fifo = CHAIN_INITIALIZER_EMPTY( designator.Queues.Fifo ) \
.operations = &_Thread_queue_Operations_FIFO \
#define CHAIN_INITIALIZER_EMPTY(name)
Chain initializer for an empty chain with designator name.
Definition: chainimpl.h:37
◆ THREAD_QUEUE_PRIORITY_INITIALIZER
#define THREAD_QUEUE_PRIORITY_INITIALIZER (   designator,
  name
Value:
.Queues = { \
.Priority = RBTREE_INITIALIZER_EMPTY( designator.Queues.Priority ) \
.operations = &_Thread_queue_Operations_priority \
#define RBTREE_INITIALIZER_EMPTY(name)
RBTree initializer for an empty rbtree with designator name.
Definition: score/include/rtems/score/rbtree.h:150
Typedef Documentation
◆ Thread_queue_Enqueue_operation
typedef void( * Thread_queue_Enqueue_operation) (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread)
Parameters
[in]the_thread_queueThe thread queue.
[in]the_threadThe thread to enqueue on the queue.
See also
_Thread_Wait_set_operations().
◆ Thread_queue_Extract_operation
typedef void( * Thread_queue_Extract_operation) (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread)
Parameters
[in]the_threadThe thread to extract from the thread queue.
See also
◆ Thread_queue_First_operation
typedef Thread_Control*( * Thread_queue_First_operation) (Thread_queue_Control *the_thread_queue)
Parameters
Return values
NULLNo thread is present on the thread queue.
firstThe first thread of the thread queue according to the insert order. This thread remains on the thread queue.
See also
◆ Thread_queue_Initialize_operation
typedef void( * Thread_queue_Initialize_operation) (Thread_queue_Control *the_thread_queue)
Parameters
See also
◆ Thread_queue_Priority_change_operation
typedef void( * Thread_queue_Priority_change_operation) (Thread_Control *the_thread, Priority_Control new_priority, Thread_queue_Control *the_thread_queue)
Parameters
[in]the_threadThe thread.
[in]new_priorityThe new priority value.
See also
Thread_queue_Operations.
◆ _Thread_queue_Compare_priority()
RBTree_Compare_result _Thread_queue_Compare_priority ( const RBTree_Node *  left,
const RBTree_Node *  right
Parameters
[in]leftpoints to the left thread's RBnode
[in]rightpoints to the right thread's RBnode
Return values
1The left node is more important than right node.
0The left node is of equal importance with right node.
1The left node is less important than right node.
◆ _Thread_queue_Dequeue()
Thread_Control* _Thread_queue_Dequeue ( Thread_queue_Control *  the_thread_queue)
This function returns a pointer to a thread waiting on the_thread_queue. The selection of this thread is based on the discipline of the_thread_queue. If no threads are waiting on the_thread_queue, then NULL is returned.
  • INTERRUPT LATENCY:
    • single case
Referenced by _CORE_barrier_Release().
◆ _Thread_queue_Enqueue_critical()
void _Thread_queue_Enqueue_critical ( Thread_queue_Control *  the_thread_queue,
Thread_Control *  the_thread,
ISR_lock_Context *  lock_context
This enqueues the thread on the thread queue, blocks the thread, and optionally starts the thread timer in case the timeout interval is not WATCHDOG_NO_TIMEOUT.
The caller must be the owner of the thread queue lock. This function will release the thread queue lock and register it as the new thread lock. Thread dispatching is disabled before the thread queue lock is released. Thread dispatching is enabled once the sequence to block the thread is complete. The operation to enqueue the thread on the queue is protected by the thread queue lock. This makes it possible to use the thread queue lock to protect the state of objects embedding the thread queue and directly enter _Thread_queue_Enqueue_critical() in case the thread must block.
typedef struct {
} Mutex;
void _Mutex_Obtain( Mutex *mutex )
ISR_lock_Context lock_context;
Thread_Control *executing;
_Thread_queue_Acquire( &mutex->Queue, &lock_context );
executing = _Thread_Executing;
if ( mutex->owner == NULL ) {
mutex->owner = executing;
_Thread_queue_Release( &mutex->Queue, &lock_context );
} else {
&mutex->Queue,
executing,
0,
&lock_context
Parameters
[in]the_threadThe thread to enqueue.
[in]stateThe new state of the thread.
[in]timeoutInterval to wait. Use WATCHDOG_NO_TIMEOUT to block potentially forever.
[in]timeout_codeThe return code in case a timeout occurs.
[in]lock_contextThe lock context of the lock acquire.
◆ _Thread_queue_Extract()
void _Thread_queue_Extract ( Thread_Control *  the_thread)
This routine removes the_thread its thread queue and cancels any timeouts associated with this blocking.
Parameters
[in]the_threadis the pointer to a thread control block that is to be removed
◆ _Thread_queue_Extract_critical()
void _Thread_queue_Extract_critical ( Thread_queue_Control *  the_thread_queue,
The caller must be the owner of the thread queue lock. This function will release the thread queue lock and restore the default thread lock. Thread dispatching is disabled before the thread queue lock is released and an unblock is necessary. Thread dispatching is enabled once the sequence to unblock the thread is complete. This makes it possible to use the thread queue lock to protect the state of objects embedding the thread queue and directly enter _Thread_queue_Extract_critical() to finalize an operation in case a waiting thread exists.
typedef struct {
} Mutex;
void _Mutex_Release( Mutex *mutex )
first = _Thread_queue_First_locked( &mutex->Queue );
mutex->owner = first;
if ( first != NULL ) {
&mutex->Queue,
first,
&lock_context
Parameters
[in]the_threadThe thread to extract.
References _Thread_queue_Extract_locked(), and _Thread_queue_Unblock_critical().
◆ _Thread_queue_Extract_locked()
void _Thread_queue_Extract_locked ( Thread_queue_Control *  the_thread_queue,
The caller must be the owner of the thread queue lock. The thread queue lock is not released.
Parameters
References _Thread_Lock_restore_default, _Thread_Wait_restore_default_operations(), _Thread_Wait_set_queue(), Thread_queue_Operations::extract, and Thread_queue_Control::operations.
Referenced by _Thread_queue_Extract_critical().
◆ _Thread_queue_Extract_with_proxy()
void _Thread_queue_Extract_with_proxy ( Thread_Control *  the_thread)
This routine extracts the_thread from the_thread_queue and ensures that if there is a proxy for this task on another node, it is also dealt with.
This routine extracts the_thread from the_thread_queue and ensures that if there is a proxy for this task on another node, it is also dealt with. A proxy is a data data that is on the thread queue on the remote node and acts as a proxy for the local thread. If the local thread was waiting on a remote operation, then the remote side of the operation must be cleaned up.
◆ _Thread_queue_First()
Thread_Control* _Thread_queue_First ( Thread_queue_Control *  the_thread_queue)
Parameters
Return values
firstThe first thread on the thread queue according to the enqueue order.
Referenced by _Thread_queue_First_locked().
◆ _Thread_queue_First_locked()
RTEMS_INLINE_ROUTINE Thread_Control* _Thread_queue_First_locked ( Thread_queue_Control *  the_thread_queue)
Parameters
Return values
References _Thread_queue_First(), _Thread_queue_Flush(), Thread_queue_Operations::first, and Thread_queue_Control::operations.
◆ _Thread_queue_Flush()
void _Thread_queue_Flush ( Thread_queue_Control *  the_thread_queue,
uint32_t  status
This routine unblocks all threads blocked on the_thread_queue and cancels any associated timeouts.
Parameters
[in]the_thread_queueis the pointer to a threadq header
[in]remote_extract_calloutpoints to a method to invoke to invoke when a remote thread is unblocked
[in]statusis the status which will be returned to all unblocked threads
◆ _Thread_queue_Initialize()
void _Thread_queue_Initialize ( Thread_queue_Control *  the_thread_queue,
This routine initializes the_thread_queue based on the discipline indicated in attribute_set. The state set on threads which block on the_thread_queue is state.
Parameters
[in]the_disciplineis the queueing discipline
References _ISR_lock_Initialize.
Referenced by _CORE_barrier_Initialize(), _CORE_mutex_Initialize(), _CORE_RWLock_Initialize(), _CORE_semaphore_Initialize(), and pthread_cond_init().
◆ _Thread_queue_Unblock_critical()
void _Thread_queue_Unblock_critical ( Thread_queue_Control *  the_thread_queue,
The caller must be the owner of the thread queue lock. This function will release the thread queue lock. Thread dispatching is disabled before the thread queue lock is released and an unblock is necessary. Thread dispatching is enabled once the sequence to unblock the thread is complete.
Parameters
