Files | Data Structures | Macros | Typedefs | Enumerations | Functions
Barrier Handler
This handler encapsulates functionality which provides the foundation Barrier services used in all of the APIs supported by RTEMS. More...
Collaboration diagram for Barrier Handler:
file  corebarrier.c
 Initialize CORE Barrier.
file  corebarrierrelease.c
 Manually releases the Barrier.
file  corebarrierwait.c
 Wait For The Barrier.
struct  CORE_barrier_Attributes
 The following defines the control block used to manage the attributes of each barrier. More...
struct  CORE_barrier_Control
 The following defines the control block used to manage each barrier. More...
#define CORE_BARRIER_STATUS_LAST   CORE_BARRIER_TIMEOUT
 Core barrier last status value. More...
#define _CORE_barrier_Flush(_the_barrier, _remote_extract_callout, _status)
 This routine assists in the deletion of a barrier by flushing the associated wait queue. More...
typedef void(* CORE_barrier_API_mp_support_callout) (Thread_Control *, Objects_Id)
 The following type defines the callout which the API provides to support global/multiprocessor operations on barriers.
enum  CORE_barrier_Disciplines { CORE_BARRIER_AUTOMATIC_RELEASE, CORE_BARRIER_MANUAL_RELEASE }
 Flavors of barriers. More...
enum  CORE_barrier_Status { CORE_BARRIER_STATUS_SUCCESSFUL, CORE_BARRIER_STATUS_AUTOMATICALLY_RELEASED, CORE_BARRIER_WAS_DELETED, CORE_BARRIER_TIMEOUT }
 Core Barrier handler return statuses. More...
void _CORE_barrier_Initialize (CORE_barrier_Control *the_barrier, CORE_barrier_Attributes *the_barrier_attributes)
 Initialize core barrier. More...
RTEMS_INLINE_ROUTINE void _CORE_barrier_Destroy (CORE_barrier_Control *the_barrier)
void _CORE_barrier_Wait (CORE_barrier_Control *the_barrier, Thread_Control *executing, Objects_Id id, bool wait, Watchdog_Interval timeout, CORE_barrier_API_mp_support_callout api_barrier_mp_support)
 Wait for the barrier. More...
uint32_t _CORE_barrier_Release (CORE_barrier_Control *the_barrier, Objects_Id id, CORE_barrier_API_mp_support_callout api_barrier_mp_support)
 Manually release the barrier. More...
RTEMS_INLINE_ROUTINE bool _CORE_barrier_Is_automatic (CORE_barrier_Attributes *the_attribute)
 This function returns true if the automatic release attribute is enabled in the attribute_set and false otherwise. More...
RTEMS_INLINE_ROUTINE uint32_t _CORE_barrier_Get_number_of_waiting_threads (CORE_barrier_Control *the_barrier)
 This routine returns the number of threads currently waiting at the barrier. More...
◆ _CORE_barrier_Flush
#define _CORE_barrier_Flush (   _the_barrier,
  _status
Value:
&((_the_barrier)->Wait_queue), \
(_remote_extract_callout), \
(_status) \
void _Thread_queue_Flush(Thread_queue_Control *the_thread_queue, Thread_queue_Flush_callout remote_extract_callout, uint32_t status)
Unblocks all threads blocked on the_thread_queue.
Definition: threadqflush.c:24
Parameters
[in]_the_barrieris the barrier to flush
[in]_remote_extract_calloutis the routine to invoke if the thread unblocked is remote
[in]_statusis the status to be returned to the unblocked thread
◆ CORE_BARRIER_STATUS_LAST
This is the last status value.
Referenced by _Barrier_Translate_core_barrier_return_code(), and _POSIX_Barrier_Translate_core_barrier_return_code().
◆ CORE_barrier_Disciplines
This specifies that the barrier will automatically release when the user specified number of threads have arrived at the barrier.
This specifies that the user will have to manually release the barrier in order to release the waiting threads.
◆ CORE_barrier_Status
This status indicates that the operation completed successfully.
This status indicates that the barrier is configured for automatic release and the caller tripped the automatic release.
The caller thus did not block.
This status indicates that the thread was blocked waiting for an operation to complete and the barrier was deleted.
This status indicates that the calling task was willing to block but the operation was unable to complete within the time allotted because the resource never became available.
◆ _CORE_barrier_Get_number_of_waiting_threads()
RTEMS_INLINE_ROUTINE uint32_t _CORE_barrier_Get_number_of_waiting_threads ( CORE_barrier_Control *  the_barrier)
Parameters
[in]the_barrieris the barrier to obtain the number of blocked threads for
Returns
the current count of this barrier
References CORE_barrier_Control::number_of_waiting_threads.
◆ _CORE_barrier_Initialize()
void _CORE_barrier_Initialize ( CORE_barrier_Control *  the_barrier,
CORE_barrier_Attributes *  the_barrier_attributes
This routine initializes the barrier based on the parameters passed.
Parameters
[in]the_barrieris the barrier to initialize
[in]the_barrier_attributesdefine the behavior of this instance
References _Thread_queue_Initialize(), CORE_barrier_Control::Attributes, CORE_barrier_Control::number_of_waiting_threads, and CORE_barrier_Control::Wait_queue.
Referenced by rtems_barrier_create().
◆ _CORE_barrier_Is_automatic()
RTEMS_INLINE_ROUTINE bool _CORE_barrier_Is_automatic ( CORE_barrier_Attributes *  the_attribute)
Parameters
[in]the_attributeis the attribute set to test
Returns
true if the priority attribute is enabled
References CORE_BARRIER_AUTOMATIC_RELEASE, and CORE_barrier_Attributes::discipline.
◆ _CORE_barrier_Release()
uint32_t _CORE_barrier_Release ( CORE_barrier_Control *  the_barrier,
Objects_Id  id,
This routine manually releases the barrier. All of the threads waiting for the barrier will be readied.
Parameters
[in]the_barrieris the barrier to surrender
[in]idis the id of the object for a remote unblock
[in]api_barrier_mp_supportis the routine to invoke if the thread unblocked is remote
Return values
thenumber of unblocked threads
References _Objects_Is_local_id(), _Thread_queue_Dequeue(), Objects_Control::id, CORE_barrier_Control::number_of_waiting_threads, Thread_Control::Object, and CORE_barrier_Control::Wait_queue.
◆ _CORE_barrier_Wait()
void _CORE_barrier_Wait ( CORE_barrier_Control *  the_barrier,
Thread_Control *  executing,
Objects_Id  id,
bool  wait,
This routine wait for the barrier to be released. If the barrier is set to automatic and this is the appropriate thread, then it returns immediately. Otherwise, the calling thread is blocked until the barrier is released.
Parameters
[in]the_barrieris the barrier to wait for
[in,out]executingThe currently executing thread.
[in]idis the id of the object being waited upon
[in]waitis true if the calling thread is willing to wait
[in]timeoutis the number of ticks the calling thread is willing to wait if wait is true.
Note
Status is returned via the thread control block.
