Files | Data Structures | Macros | Typedefs | Enumerations | Functions
Mutex Handler
This handler encapsulates functionality which provides the foundation Mutex services used in all of the APIs supported by RTEMS. More...
Collaboration diagram for Mutex Handler:
file  coremuteximpl.h
 CORE Mutex Implementation.
file  coremutex.c
 Initialize a Core Mutex.
file  coremutexflush.c
 Flush all waiting threads.
file  coremutexseize.c
 Seize Mutex with Blocking.
file  coremutexseizeintr.c
 Trylock CORE Mutex Seize Interrupt.
file  coremutexsurrender.c
 Surrender the Mutex.
struct  CORE_mutex_Attributes
 The control block used to manage attributes of each mutex. More...
struct  CORE_mutex_Control
 Control block used to manage each mutex. More...
#define CORE_MUTEX_STATUS_LAST   CORE_MUTEX_STATUS_CEILING_VIOLATED
 The last status value. More...
#define _CORE_mutex_Seize_interrupt_trylock(_mutex, _executing, _lock_context)   _CORE_mutex_Seize_interrupt_trylock_body( _mutex, _executing, _lock_context )
 The default is to favor speed and inlining this definitely saves a few instructions. More...
#define _CORE_mutex_Check_dispatch_for_seize(_wait)
 Verifies that a mutex blocking seize is performed safely. More...
#define _CORE_mutex_Seize(_the_mutex, _executing, _id, _wait, _timeout, _lock_context)
 This method is used to obtain a core mutex. More...
typedef void(* CORE_mutex_API_mp_support_callout) (Thread_Control *, Objects_Id)
 Callout which provides to support global/multiprocessor operations. More...
enum  CORE_mutex_Disciplines { CORE_MUTEX_DISCIPLINES_FIFO, CORE_MUTEX_DISCIPLINES_PRIORITY, CORE_MUTEX_DISCIPLINES_PRIORITY_INHERIT, CORE_MUTEX_DISCIPLINES_PRIORITY_CEILING }
 The blocking disciplines for a mutex. More...
enum  CORE_mutex_Nesting_behaviors { CORE_MUTEX_NESTING_ACQUIRES, CORE_MUTEX_NESTING_BLOCKS }
 The possible behaviors for lock nesting. More...
enum  CORE_mutex_Status {
  CORE_MUTEX_STATUS_SUCCESSFUL, CORE_MUTEX_STATUS_UNSATISFIED_NOWAIT, CORE_MUTEX_STATUS_NOT_OWNER_OF_RESOURCE, CORE_MUTEX_WAS_DELETED,
  CORE_MUTEX_TIMEOUT, CORE_MUTEX_STATUS_CEILING_VIOLATED
 The possible Mutex handler return statuses. More...
CORE_mutex_Status _CORE_mutex_Initialize (CORE_mutex_Control *the_mutex, Thread_Control *executing, const CORE_mutex_Attributes *the_mutex_attributes, bool initially_locked)
 Initializes the mutex based on the parameters passed. More...
RTEMS_INLINE_ROUTINE void _CORE_mutex_Destroy (CORE_mutex_Control *the_mutex)
RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock_body (CORE_mutex_Control *the_mutex, Thread_Control *executing, ISR_lock_Context *lock_context)
 Attempt to receive a unit from the_mutex. More...
void _CORE_mutex_Seize_interrupt_blocking (CORE_mutex_Control *the_mutex, Thread_Control *executing, Watchdog_Interval timeout, ISR_lock_Context *lock_context)
 Performs the blocking portion of a mutex obtain. More...
RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize_body (CORE_mutex_Control *the_mutex, Thread_Control *executing, Objects_Id id, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context)
 Attempt to obtain the mutex. More...
CORE_mutex_Status _CORE_mutex_Surrender (CORE_mutex_Control *the_mutex, Objects_Id id, CORE_mutex_API_mp_support_callout api_mutex_mp_support, ISR_lock_Context *lock_context)
 Frees a unit to the mutex. More...
void _CORE_mutex_Flush (CORE_mutex_Control *the_mutex, Thread_queue_Flush_callout remote_extract_callout, uint32_t status)
 Flush all waiting threads. More...
RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_locked (const CORE_mutex_Control *the_mutex)
 Is mutex locked. More...
RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_fifo (const CORE_mutex_Attributes *the_attribute)
 Does core mutex use FIFO blocking. More...
RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_priority (CORE_mutex_Attributes *the_attribute)
 Doex core mutex use priority blocking. More...
RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_inherit_priority (CORE_mutex_Attributes *the_attribute)
 Does mutex use priority inheritance. More...
RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_priority_ceiling (CORE_mutex_Attributes *the_attribute)
 Does mutex use priority ceiling. More...
◆ _CORE_mutex_Check_dispatch_for_seize
#define _CORE_mutex_Check_dispatch_for_seize (   _wait)
Value:
&& (_wait) \
&& (_System_state_Get() >= SYSTEM_STATE_UP))
RTEMS_INLINE_ROUTINE bool _Thread_Dispatch_is_enabled(void)
Indicates if the executing thread is inside a thread dispatch critical section.
Definition: threaddispatch.h:51
The system is up and operating normally.
Definition: sysstate.h:54
This macro is to verify that a mutex blocking seize is performed from a safe system state. For example, one cannot block inside an isr.
Return values
thismethod returns true if dispatch is in an unsafe state.
◆ _CORE_mutex_Seize
#define _CORE_mutex_Seize (   _the_mutex,
  _executing,
  _id,
  _wait,
  _timeout,
  _lock_context
Value:
_the_mutex, _executing, _id, _wait, _timeout, _lock_context )
RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize_body(CORE_mutex_Control *the_mutex, Thread_Control *executing, Objects_Id id, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context)
Definition: coremuteximpl.h:245
Parameters
[in]_the_mutexis the mutex to attempt to lock
[in]_executingThe currently executing thread.
[in]_idis the Id of the owning API level Semaphore object
[in]_waitis true if the thread is willing to wait
[in]_timeoutis the maximum number of ticks to block
[in]_lock_contextis a temporary variable used to contain the ISR disable level cookie
◆ _CORE_mutex_Seize_interrupt_trylock
#define _CORE_mutex_Seize_interrupt_trylock (   _mutex,
  _executing,
  _lock_context
This is very important for mutex performance.
Parameters
[in]_mutexwill attempt to lock
[in]_executingpoints to the executing thread
[in]_lock_contextis the interrupt level
◆ CORE_MUTEX_STATUS_LAST
This is the last status value.
Referenced by _POSIX_Mutex_Translate_core_mutex_return_code().
Typedef Documentation
◆ CORE_mutex_API_mp_support_callout
typedef void( * CORE_mutex_API_mp_support_callout) (Thread_Control *, Objects_Id)
The following type defines the callout which the API provides to support global/multiprocessor operations on mutexes.
◆ CORE_mutex_Disciplines
This enumerated type defines the blocking disciplines for a mutex.
This specifies that threads will wait for the mutex in FIFO order.
This specifies that threads will wait for the mutex in priority order.
Additionally, the Priority Inheritance Protocol will be in effect.
Additionally, the Priority Ceiling Protocol will be in effect.
◆ CORE_mutex_Nesting_behaviors
This enumerated type defines the possible behaviors for lock nesting.
This sequence has no blocking or errors:
  • lock(m)
  • lock(m)
  • unlock(m)
  • unlock(m)
This sequence performs as indicated:
  • lock(m)
  • lock(m) - deadlocks or timeouts
  • unlock(m) - releases
◆ CORE_mutex_Status
This enumerated type defines the possible Mutex handler return statuses.
This status indicates that the operation completed successfully.
This status indicates that the calling task did not want to block and the operation was unable to complete immediately because the resource was unavailable.
This status indicates that an attempt was made to release a mutex by a thread other than the thread which locked it.
This status indicates that the thread was blocked waiting for an operation to complete and the mutex was deleted.
CORE_MUTEX_TIMEOUT
This status indicates that the calling task was willing to block but the operation was unable to complete within the time allotted because the resource never became available.
This status indicates that a thread of logically greater importance than the ceiling priority attempted to lock this mutex.
◆ _CORE_mutex_Flush()
void _CORE_mutex_Flush ( CORE_mutex_Control *  the_mutex,
uint32_t  status
This routine assists in the deletion of a mutex by flushing the associated wait queue.
Parameters
[in]the_mutexis the mutex to flush
[in]remote_extract_calloutis the routine to invoke when a remote thread is extracted
[in]statusis the status value which each unblocked thread will return to its caller.
◆ _CORE_mutex_Initialize()
CORE_mutex_Status _CORE_mutex_Initialize ( CORE_mutex_Control *  the_mutex,
Thread_Control *  executing,
const CORE_mutex_Attributes *  the_mutex_attributes,
This routine initializes the mutex based on the parameters passed.
Parameters
[in,out]the_mutexis the mutex to initalize
[in,out]executingThe currently executing thread.
[in]the_mutex_attributesis the attributes associated with this mutex instance
[in]initially_lockedIf true, then the mutex is initially locked by the executing thread.
Return values
Thismethod returns CORE_MUTEX_STATUS_SUCCESSFUL if successful.
References _Chain_Prepend_unprotected(), _CORE_mutex_Is_fifo(), _CORE_mutex_Is_inherit_priority(), _CORE_mutex_Is_priority_ceiling(), _Thread_Dispatch_disable(), _Thread_Dispatch_enable(), _Thread_queue_Initialize(), _Thread_Raise_priority(), CORE_mutex_Control::Attributes, CORE_MUTEX_STATUS_CEILING_VIOLATED, Thread_Control::current_priority, CORE_mutex_Control::holder, CORE_mutex_Control::nest_count, CORE_mutex_Attributes::priority_ceiling, Thread_Control::resource_count, and CORE_mutex_Control::Wait_queue.
Referenced by _API_Mutex_Allocate(), and rtems_semaphore_create().
◆ _CORE_mutex_Is_fifo()
RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_fifo ( const CORE_mutex_Attributes *  the_attribute)
This routine returns true if the mutex's wait discipline is FIFO and false otherwise.
Parameters
[in]the_attributeis the attribute set of the mutex.
Return values
trueThe mutex is using FIFO blocking order.
falseThe mutex is not using FIFO blocking order.
References CORE_MUTEX_DISCIPLINES_FIFO, and CORE_mutex_Attributes::discipline.
Referenced by _CORE_mutex_Initialize().
◆ _CORE_mutex_Is_inherit_priority()
RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_inherit_priority ( CORE_mutex_Attributes *  the_attribute)
This routine returns true if the mutex's wait discipline is INHERIT_PRIORITY and false otherwise.
Parameters
Return values
trueThe mutex is using priority inheritance.
falseThe mutex is not using priority inheritance.
References CORE_MUTEX_DISCIPLINES_PRIORITY_INHERIT, and CORE_mutex_Attributes::discipline.
Referenced by _CORE_mutex_Initialize(), and _CORE_mutex_Seize_interrupt_trylock_body().
◆ _CORE_mutex_Is_locked()
RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_locked ( const CORE_mutex_Control *  the_mutex)
Is mutex locked.
This routine returns true if the mutex specified is locked and false otherwise.
Parameters
[in]the_mutexis the mutex to check.
Return values
trueThe mutex is locked.
falseThe mutex is not locked.
References CORE_mutex_Control::holder.
Referenced by _CORE_mutex_Seize_interrupt_trylock_body().
◆ _CORE_mutex_Is_priority()
RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_priority ( CORE_mutex_Attributes *  the_attribute)
This routine returns true if the mutex's wait discipline is PRIORITY and false otherwise.
Parameters
Return values
trueThe mutex is using priority blocking order.
falseThe mutex is not using priority blocking order.
References CORE_MUTEX_DISCIPLINES_PRIORITY, and CORE_mutex_Attributes::discipline.
◆ _CORE_mutex_Is_priority_ceiling()
RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_priority_ceiling ( CORE_mutex_Attributes *  the_attribute)
This routine returns true if the mutex's wait discipline is PRIORITY_CEILING and false otherwise.
Parameters
Return values
trueThe mutex is using priority ceiling.
falseThe mutex is not using priority ceiling.
References CORE_MUTEX_DISCIPLINES_PRIORITY_CEILING, and CORE_mutex_Attributes::discipline.
◆ _CORE_mutex_Seize_body()
RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize_body ( CORE_mutex_Control *  the_mutex,
Objects_Id  id,
bool  wait,
ISR_lock_Context *  lock_context
This routine attempts to obtain the mutex. If the mutex is available, then it will return immediately. Otherwise, it will invoke the support routine _Core_mutex_Seize_interrupt_blocking.
Parameters
[in]the_mutexis the mutex to attempt to lock
[in]idis the Id of the owning API level Semaphore object
[in]waitis true if the thread is willing to wait
[in]timeoutis the maximum number of ticks to block
[in]lock_contextis a temporary variable used to contain the ISR disable level cookie
Note
If the mutex is called from an interrupt service routine, with context switching disabled, or before multitasking, then a fatal error is generated.
The logic on this routine is as follows:
  • If incorrect system state return an error
  • If mutex is available without any contention or blocking obtain it with interrupts disabled and returned
  • If the caller is willing to wait then they are blocked.
◆ _CORE_mutex_Seize_interrupt_blocking()
void _CORE_mutex_Seize_interrupt_blocking ( CORE_mutex_Control *  the_mutex,
This routine performs the blocking portion of a mutex obtain. It is an actual subroutine and is not implemented as something that may be inlined.
Parameters
[in,out]the_mutexis the mutex to attempt to lock
[in]lock_contextis the interrupt level
◆ _CORE_mutex_Seize_interrupt_trylock_body()
RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock_body ( CORE_mutex_Control *  the_mutex,
This routine attempts to receive a unit from the_mutex. If a unit is available or if the wait flag is false, then the routine returns. Otherwise, the calling task is blocked until a unit becomes available.
Parameters
Return values
Thisroutine returns 0 if "trylock" can resolve whether or not the mutex is immediately obtained or there was an error attempting to get it. It returns 1 to indicate that the caller cannot obtain the mutex and will have to block to do so.
Note
For performance reasons, this routine is implemented as a macro that uses two support routines.
References _Chain_Prepend_unprotected(), _CORE_mutex_Is_inherit_priority(), _CORE_mutex_Is_locked(), _CORE_mutex_Is_priority_ceiling(), CORE_mutex_Control::Attributes, CORE_MUTEX_STATUS_SUCCESSFUL, Thread_Control::current_priority, CORE_mutex_Control::holder, CORE_mutex_Control::nest_count, Thread_Control::resource_count, Thread_Wait_information::return_code, and Thread_Control::Wait.
◆ _CORE_mutex_Surrender()
CORE_mutex_Status _CORE_mutex_Surrender ( CORE_mutex_Control *  the_mutex,
Objects_Id  id,
This routine frees a unit to the mutex. If a task was blocked waiting for a unit from this mutex, then that task will be readied and the unit given to that task. Otherwise, the unit will be returned to the mutex.
Parameters
[in]the_mutexis the mutex to surrender
[in]idis the id of the RTEMS Object associated with this mutex
[in]api_mutex_mp_supportis the routine that will be called when unblocking a remote mutex
Return values
anindication of whether the routine succeeded or failed
References _ISR_lock_ISR_enable, _Thread_Is_executing(), CORE_mutex_Control::Attributes, CORE_MUTEX_STATUS_NOT_OWNER_OF_RESOURCE, CORE_mutex_Control::holder, and CORE_mutex_Attributes::only_owner_release.
Referenced by _API_Mutex_Unlock().
