CORE_mutex_Control Struct Reference
Control block used to manage each mutex. More...
#include <coremutex.h>
Collaboration diagram for CORE_mutex_Control:
Collaboration graph
[legend]
Thread_queue_Control Wait_queue
 This field is the Waiting Queue used to manage the set of tasks which are blocked waiting to lock the mutex.
CORE_mutex_Attributes Attributes
 This element is the set of attributes which define this instance's behavior.
uint32_t nest_count
 This element contains the number of times the mutex has been acquired nested. More...
Thread_Control * holder
 This element points to the thread which is currently holding this mutex. More...
The following defines the control block used to manage each mutex.
Field Documentation
◆ holder
Thread_Control* CORE_mutex_Control::holder
The holder is the last thread to successfully lock the mutex and which has not unlocked it. If the thread is not locked, there is no holder.
Referenced by _API_Mutex_Is_owner(), _CORE_mutex_Initialize(), _CORE_mutex_Is_locked(), _CORE_mutex_Seize_interrupt_trylock_body(), and _CORE_mutex_Surrender().
◆ nest_count
uint32_t CORE_mutex_Control::nest_count
This must be zero (0) before the mutex is actually unlocked.
Referenced by _API_Mutex_Unlock(), _CORE_mutex_Initialize(), and _CORE_mutex_Seize_interrupt_trylock_body().
