Files | Data Structures | Macros | Typedefs | Enumerations | Functions
Red-Black Tree Handler
The Red-Black Tree Handler is used to manage sets of entities. More...
Collaboration diagram for Red-Black Tree Handler:
file  rbtree.c
 Initialize a RBTree Header.
file  rbtreefind.c
 Find the control structure of the tree containing the given node.
file  rbtreeiterate.c
 _RBTree_Iterate() implementation.
file  rbtreenext.c
 _RBTree_Next() and _RBTree_Next() implementation.
struct  RBTree_Node_struct
 This is used to manage each element (node) which is placed on a RBT. More...
struct  RBTree_Control
 This is used to manage a RBT. More...
#define RBTREE_INITIALIZER_EMPTY(name)   { NULL, NULL, { NULL, NULL } }
 RBTree initializer for an empty rbtree with designator name.
#define RBTREE_DEFINE_EMPTY(name)   RBTree_Control name = RBTREE_INITIALIZER_EMPTY( name )
 RBTree definition for an empty rbtree with designator name.
#define RBTREE_NODE_INITIALIZER_EMPTY(name)   { NULL, { NULL, NULL }, RBT_RED }
 RBTree_Node initializer for an empty node with designator name.
#define RBTREE_NODE_DEFINE_EMPTY(name)   RBTree_Node name = RBTREE_NODE_INITIALIZER_EMPTY( name )
typedef struct RBTree_Node_struct RBTree_Node
 This type definition promotes the name for the RBTree Node used by all RTEMS code. More...
typedef long RBTree_Compare_result
 Integer type for compare results. More...
typedef RBTree_Compare_result(* RBTree_Compare) (const RBTree_Node *first, const RBTree_Node *second)
 Compares two red-black tree nodes. More...
typedef bool(* RBTree_Visitor) (const RBTree_Node *node, RBTree_Direction dir, void *visitor_arg)
 Red-black tree visitor. More...
enum  RBTree_Color { RBT_BLACK, RBT_RED }
 This enum type defines the colors available for the RBTree Nodes.
enum  RBTree_Direction { RBT_LEFT =0, RBT_RIGHT =1 }
 This type indicates the direction.
void _RBTree_Initialize (RBTree_Control *the_rbtree, RBTree_Compare compare, void *starting_address, size_t number_nodes, size_t node_size, bool is_unique)
 Initialize a RBTree Header. More...
RBTree_Node * _RBTree_Find (const RBTree_Control *the_rbtree, const RBTree_Node *the_node, RBTree_Compare compare, bool is_unique)
 Tries to find a node for the specified key in the tree. More...
RBTree_Node * _RBTree_Insert (RBTree_Control *the_rbtree, RBTree_Node *the_node, RBTree_Compare compare, bool is_unique)
 Inserts the node into the red-black tree. More...
void _RBTree_Extract (RBTree_Control *the_rbtree, RBTree_Node *the_node)
 Extracts (removes) the node from the red-black tree. More...
RBTree_Node * _RBTree_Next (const RBTree_Node *node, RBTree_Direction dir)
 Returns the in-order next node of a node. More...
RTEMS_INLINE_ROUTINE void _RBTree_Set_off_tree (RBTree_Node *the_node)
 Sets a red-black tree node as off-tree. More...
RTEMS_INLINE_ROUTINE bool _RBTree_Is_node_off_tree (const RBTree_Node *the_node)
 Returns true, if this red-black tree node is off-tree, and false otherwise. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Root (const RBTree_Control *the_rbtree)
 Returns a pointer to root node of the red-black tree. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_First (const RBTree_Control *the_rbtree, RBTree_Direction dir)
 Return pointer to RBTree's first node. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Parent (const RBTree_Node *the_node)
 Returns a pointer to the parent of this node. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Left (const RBTree_Node *the_node)
 Return pointer to the left of this node. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Right (const RBTree_Node *the_node)
 Return pointer to the right of this node. More...
RTEMS_INLINE_ROUTINE bool _RBTree_Is_empty (const RBTree_Control *the_rbtree)
 Is the RBTree empty. More...
RTEMS_INLINE_ROUTINE bool _RBTree_Is_first (const RBTree_Control *the_rbtree, const RBTree_Node *the_node, RBTree_Direction dir)
 Is this the first node on the RBTree. More...
RTEMS_INLINE_ROUTINE bool _RBTree_Is_root (const RBTree_Node *the_node)
 Returns true if this node is the root node of a red-black tree, and false otherwise. More...
RTEMS_INLINE_ROUTINE void _RBTree_Initialize_empty (RBTree_Control *the_rbtree)
 Initialize this RBTree as empty. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Predecessor (const RBTree_Node *node)
 Returns the predecessor of a node. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Successor (const RBTree_Node *node)
 Returns the successor of a node. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Get (RBTree_Control *the_rbtree, RBTree_Direction dir)
 Gets a node with an extremal key value from the red-black tree. More...
void _RBTree_Iterate (const RBTree_Control *rbtree, RBTree_Direction dir, RBTree_Visitor visitor, void *visitor_arg)
 Red-black tree iteration. More...
RTEMS_INLINE_ROUTINE RBTree_Direction _RBTree_Opposite_direction (RBTree_Direction the_dir)
 Get the direction opposite to the_dir.
RTEMS_INLINE_ROUTINE RBTree_Direction _RBTree_Direction (const RBTree_Node *the_node, const RBTree_Node *parent)
 Returns the direction of the node. More...
RTEMS_INLINE_ROUTINE bool _RBTree_Is_red (const RBTree_Node *the_node)
 Is this node red. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Sibling (const RBTree_Node *the_node, const RBTree_Node *parent)
 Returns the sibling of the node. More...
RTEMS_INLINE_ROUTINE bool _RBTree_Is_equal (RBTree_Compare_result compare_result)
RTEMS_INLINE_ROUTINE bool _RBTree_Is_greater (RBTree_Compare_result compare_result)
RTEMS_INLINE_ROUTINE bool _RBTree_Is_lesser (RBTree_Compare_result compare_result)
RTEMS_INLINE_ROUTINE void _RBTree_Rotate (RBTree_Node *the_node, RBTree_Direction dir)
 Rotates the node in the specified direction. More...
This handler provides two data structures. The rbtree Node data structure is included as the first part of every data structure that will be placed on a RBTree. The second data structure is rbtree Control which is used to manage a set of rbtree Nodes.
Typedef Documentation
◆ RBTree_Compare
typedef RBTree_Compare_result( * RBTree_Compare) (const RBTree_Node *first, const RBTree_Node *second)
Parameters
[in]firstThe first node.
[in]secondThe second node.
Return values
positiveThe key value of the first node is greater than the one of the second node.
0The key value of the first node is equal to the one of the second node.
negativeThe key value of the first node is less than the one of the second node.
◆ RBTree_Compare_result
The type is large enough to represent pointers and 32-bit signed integers.
See also
RBTree_Compare.
◆ RBTree_Node
It is a separate type definition because a forward reference is required to define it. See RBTree_Node_struct for detailed information.
◆ RBTree_Visitor
Parameters
[in]nodeThe node.
[in]dirThe direction.
[in]visitor_argThe visitor argument.
Return values
trueStop the iteration.
falseContinue the iteration.
See also
_RBTree_Iterate().
◆ _RBTree_Direction()
RTEMS_INLINE_ROUTINE RBTree_Direction _RBTree_Direction ( const RBTree_Node *  the_node,
const RBTree_Node *  parent
Parameters
[in]the_nodeThe node of interest.
[in]parentThe parent of the node. The parent must exist, thus it is invalid to use this function for the root node.
References RBTree_Node_struct::child.
Referenced by _RBTree_Rotate().
◆ _RBTree_Extract()
void _RBTree_Extract ( RBTree_Control *  the_rbtree,
This function does not set the node off-tree. In case this is desired, then call _RBTree_Set_off_tree() after the extraction.
In case the node to extract is not a node of the tree, then this function yields unpredictable results.
Parameters
[in]the_rbtreeThe red-black tree control.
[in]the_nodeThe node to extract.
References RBTree_Control::first.
Referenced by _RBTree_Get(), and rtems_rbtree_extract().
◆ _RBTree_Find()
RBTree_Node* _RBTree_Find ( const RBTree_Control *  the_rbtree,
bool  is_unique
Parameters
[in]the_nodeA node specifying the key.
[in]compareThe node compare function.
[in]is_uniqueIf true, then return the first node with a key equal to the one of the node specified if it exits, else return the last node if it exists.
Return values
nodeA node corresponding to the key. If the tree is not unique and contains duplicate keys, the set of duplicate keys acts as FIFO.
NULLNo node exists in the tree for the key.
◆ _RBTree_First()
RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_First ( const RBTree_Control *  the_rbtree,
This function returns a pointer to the first node on the_rbtree, where dir specifies whether to return the minimum (0) or maximum (1).
Referenced by _RBTree_Is_first(), _RBTree_Iterate(), rtems_rbtree_max(), rtems_rbtree_min(), rtems_rbtree_peek_max(), and rtems_rbtree_peek_min().
◆ _RBTree_Get()
RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Get ( RBTree_Control *  the_rbtree,
This function extracts a node with the minimum or maximum key value from tree and returns a pointer to that node if it exists. In case multiple nodes with a minimum key value exist, then they are extracted in FIFO order. In case multiple nodes with a maximum key value exist, then they are extracted in LIFO order.
Parameters
[in]dirSpecifies whether to get a node with the minimum (RBT_LEFT) or maximum (RBT_RIGHT) key value.
Return values
NULLThe tree is empty.
extremal_nodeA node with a minimal or maximal key value on the tree.
References _RBTree_Extract(), and RBTree_Control::first.
Referenced by rtems_rbtree_get_max(), and rtems_rbtree_get_min().
◆ _RBTree_Initialize()
void _RBTree_Initialize ( RBTree_Control *  the_rbtree,
void *  starting_address,
size_t  node_size,
bool  is_unique
This routine initializes the_rbtree structure to manage the contiguous array of number_nodes nodes which starts at starting_address. Each node is of node_size bytes.
Parameters
[in]the_rbtreeis the pointer to rbtree header
[in]starting_addressis the starting address of first node
[in]number_nodesis the number of nodes in rbtree
[in]node_sizeis the size of node in bytes
[in]is_uniqueIf true, then reject nodes with a duplicate key, else otherwise.
◆ _RBTree_Initialize_empty()
RTEMS_INLINE_ROUTINE void _RBTree_Initialize_empty ( RBTree_Control *  the_rbtree)
This routine initializes the_rbtree to contain zero nodes.
References RBTree_Control::first, RBTree_Control::permanent_null, and RBTree_Control::root.
Referenced by rtems_rbtree_initialize_empty().
◆ _RBTree_Insert()
RBTree_Node* _RBTree_Insert ( RBTree_Control *  the_rbtree,
bool  is_unique
In case the node is already a node of a tree, then this function yields unpredictable results.
Parameters
[in]the_nodeThe node to insert.
[in]is_uniqueIf true, then reject nodes with a duplicate key, else insert nodes in FIFO order in case the key value is equal to existing nodes.
Return values
NULLSuccessfully inserted.
existing_nodeThis is a unique insert and there exists a node with an equal key in the tree already.
◆ _RBTree_Is_empty()
RTEMS_INLINE_ROUTINE bool _RBTree_Is_empty ( const RBTree_Control *  the_rbtree)
This function returns true if there are no nodes on the_rbtree and false otherwise.
Parameters
[in]the_rbtreeis the rbtree to be operated upon.
Return values
trueThere are no nodes on the_rbtree.
falseThere are nodes on the_rbtree.
References RBTree_Control::root.
Referenced by rtems_rbtree_is_empty().
◆ _RBTree_Is_first()
RTEMS_INLINE_ROUTINE bool _RBTree_Is_first ( const RBTree_Control *  the_rbtree,
This function returns true if the_node is the first node on the_rbtree and false otherwise. dir specifies whether first means minimum (0) or maximum (1).
Return values
truethe_node is the first node on the_rbtree.
falsethe_node is not the first node on the_rbtree.
References _RBTree_First().
Referenced by rtems_rbtree_is_max(), and rtems_rbtree_is_min().
◆ _RBTree_Is_node_off_tree()
RTEMS_INLINE_ROUTINE bool _RBTree_Is_node_off_tree ( const RBTree_Node *  the_node)
Parameters
[in]the_nodeThe node to test.
Return values
trueThe node is not a part of a tree (off-tree).
falseOtherwise.
See also
_RBTree_Set_off_tree().
References RBTree_Node_struct::parent.
Referenced by rtems_rbtree_is_node_off_tree().
◆ _RBTree_Is_red()
RTEMS_INLINE_ROUTINE bool _RBTree_Is_red ( const RBTree_Node *  the_node)
Is this node red.
This function returns true if the_node is red and false otherwise.
Return values
truethe_node is red.
falsethe_node in not red.
References RBTree_Node_struct::color.
◆ _RBTree_Is_root()
RTEMS_INLINE_ROUTINE bool _RBTree_Is_root ( const RBTree_Node *  the_node)
The root node may change after insert or extract operations. In case the node is not a node of a tree, then this function yields unpredictable results.
Parameters
Return values
trueThe node is the root node.
falseOtherwise.
See also
_RBTree_Root().
References _RBTree_Parent().
Referenced by rtems_rbtree_is_root().
◆ _RBTree_Iterate()
void _RBTree_Iterate ( const RBTree_Control *  rbtree,
void *  visitor_arg
Parameters
[in]rbtreeThe red-black tree.
[in]visitorThe visitor.
References _RBTree_First(), _RBTree_Next(), and _RBTree_Opposite_direction().
◆ _RBTree_Left()
RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Left ( const RBTree_Node *  the_node)
This function returns a pointer to the left node of this node.
Parameters
[in]the_nodeis the node to be operated upon.
Returns
This method returns the left node on the rbtree.
Referenced by rtems_rbtree_left().
◆ _RBTree_Next()
RBTree_Node* _RBTree_Next ( const RBTree_Node *  node,
Parameters
[in]nodeThe node.
Return values
NULLThe in-order next node does not exist.
otherwiseThe next node.
References _RBTree_Opposite_direction(), and RBTree_Node_struct::child.
Referenced by _RBTree_Iterate(), _RBTree_Predecessor(), and _RBTree_Successor().
◆ _RBTree_Parent()
RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Parent ( const RBTree_Node *  the_node)
The node must have a parent, thus it is invalid to use this function for the root node or a node that is not part of a tree. To test for the root node compare with _RBTree_Root() or use _RBTree_Is_root().
Parameters
Return values
parentThe parent of this node.
undefinedThe node is the root node or not part of a tree.
Referenced by _RBTree_Is_root(), _RBTree_Rotate(), and rtems_rbtree_parent().
◆ _RBTree_Predecessor()
RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Predecessor ( const RBTree_Node *  node)
Parameters
[in]nodeis the node.
Return values
NULLThe predecessor does not exist. Otherwise it returns the predecessor node.
References _RBTree_Next().
Referenced by rtems_rbtree_predecessor().
◆ _RBTree_Right()
RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Right ( const RBTree_Node *  the_node)
This function returns a pointer to the right node of this node.
Parameters
Returns
This method returns the right node on the rbtree.
Referenced by rtems_rbtree_right().
◆ _RBTree_Root()
RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Root ( const RBTree_Control *  the_rbtree)
Parameters
Return values
rootThe root node.
See also
_RBTree_Is_root().
Referenced by rtems_rbtree_root().
◆ _RBTree_Rotate()
RTEMS_INLINE_ROUTINE void _RBTree_Rotate ( RBTree_Node *  the_node,
The node is swapped with its child in the opposite direction if it exists.
Sub-tree before rotation:
Sub-tree after rotation:
Parameters
[in]the_nodeThe node to rotate.
[in]dirThe rotation direction.
References _RBTree_Direction(), _RBTree_Opposite_direction(), _RBTree_Parent(), RBTree_Node_struct::child, and RBTree_Node_struct::parent.
◆ _RBTree_Set_off_tree()
RTEMS_INLINE_ROUTINE void _RBTree_Set_off_tree ( RBTree_Node *  the_node)
Do not use this function on nodes which are a part of a tree.
Parameters
[in]the_nodeThe node to set off-tree.
See also
_RBTree_Is_node_off_tree().
Referenced by rtems_rbtree_set_off_tree().
◆ _RBTree_Sibling()
RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Sibling ( const RBTree_Node *  the_node,
Parameters
Return values
NULLNo sibling exists.
siblingThe sibling of the node.
◆ _RBTree_Successor()
RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Successor ( const RBTree_Node *  node)
Parameters
Return values
NULLThe successor does not exist. Otherwise the successor node.
Referenced by rtems_rbtree_successor().
