Macros | Typedefs | Functions
Red-Black Trees
A Red-Black Tree container. More...
Collaboration diagram for Red-Black Trees:
#define RTEMS_RBTREE_INITIALIZER_EMPTY(name)   RBTREE_INITIALIZER_EMPTY(name)
 RBTree initializer for an empty rbtree with designator name.
#define RTEMS_RBTREE_DEFINE_EMPTY(name)   RBTREE_DEFINE_EMPTY(name)
 RBTree definition for an empty rbtree with designator name.
typedef RBTree_Node rtems_rbtree_node
 A node that can be manipulated in the rbtree.
typedef RBTree_Control rtems_rbtree_control
 The rbtree's control anchors the rbtree.
typedef RBTree_Compare_result rtems_rbtree_compare_result
 Integer type for compare results. More...
typedef RBTree_Compare rtems_rbtree_compare
 Compares two red-black tree nodes. More...
RTEMS_INLINE_ROUTINE void rtems_rbtree_initialize (rtems_rbtree_control *the_rbtree, rtems_rbtree_compare compare, void *starting_address, size_t number_nodes, size_t node_size, bool is_unique)
 Initialize a RBTree header. More...
RTEMS_INLINE_ROUTINE void rtems_rbtree_initialize_empty (rtems_rbtree_control *the_rbtree)
 Initialize this RBTree as Empty. More...
RTEMS_INLINE_ROUTINE void rtems_rbtree_set_off_tree (rtems_rbtree_node *node)
 Set off RBtree. More...
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_node_off_tree (const rtems_rbtree_node *node)
 Is the Node off RBTree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_root (const rtems_rbtree_control *the_rbtree)
 Return pointer to RBTree root. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_min (const rtems_rbtree_control *the_rbtree)
 Return pointer to RBTree Minimum. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_max (const rtems_rbtree_control *the_rbtree)
 Return pointer to RBTree maximum. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_left (const rtems_rbtree_node *the_node)
 Return pointer to the left child node from this node. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_right (const rtems_rbtree_node *the_node)
 Return pointer to the right child node from this node. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_parent (const rtems_rbtree_node *the_node)
 Returns a pointer to the parent of this node. More...
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_empty (const rtems_rbtree_control *the_rbtree)
 Is the RBTree empty. More...
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_min (const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node)
 Is this the minimum node on the RBTree. More...
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_max (const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node)
 Is this the maximum node on the RBTree. More...
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_root (const rtems_rbtree_node *the_node)
 Returns true if this node is the root node of a red-black tree, and false otherwise. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_find (const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node, rtems_rbtree_compare compare, bool is_unique)
 Tries to find a node for the specified key in the tree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_predecessor (const rtems_rbtree_node *node)
 Returns the predecessor of a node. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_successor (const rtems_rbtree_node *node)
 Returns the successor of a node. More...
RTEMS_INLINE_ROUTINE void rtems_rbtree_extract (rtems_rbtree_control *the_rbtree, rtems_rbtree_node *the_node)
 Extracts (removes) the node from the red-black tree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_get_min (rtems_rbtree_control *the_rbtree)
 Obtain the min node on a rbtree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_get_max (rtems_rbtree_control *the_rbtree)
 Obtain the max node on a rbtree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_peek_min (const rtems_rbtree_control *the_rbtree)
 Peek at the min node on a rbtree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_peek_max (const rtems_rbtree_control *the_rbtree)
 Peek at the max node on a rbtree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_insert (rtems_rbtree_control *the_rbtree, rtems_rbtree_node *the_node, rtems_rbtree_compare compare, bool is_unique)
 Inserts the node into the red-black tree. More...
The red-black tree container offers no internal protection against concurrent access. The user must ensure that at most one thread at once can access a red-black tree instance.
Typedef Documentation
◆ rtems_rbtree_compare
Parameters
[in]firstThe first node.
[in]secondThe second node.
Return values
positiveThe key value of the first node is greater than the one of the second node.
0The key value of the first node is equal to the one of the second node.
negativeThe key value of the first node is less than the one of the second node.
◆ rtems_rbtree_compare_result
The type is large enough to represent pointers and 32-bit signed integers.
See also
RBTree_Compare.
◆ rtems_rbtree_extract()
RTEMS_INLINE_ROUTINE void rtems_rbtree_extract ( rtems_rbtree_control *  the_rbtree,
rtems_rbtree_node *  the_node
This function does not set the node off-tree. In case this is desired, then call _RBTree_Set_off_tree() after the extraction.
In case the node to extract is not a node of the tree, then this function yields unpredictable results.
Parameters
[in]the_rbtreeThe red-black tree control.
[in]the_nodeThe node to extract.
References _RBTree_Extract().
◆ rtems_rbtree_find()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_find ( const rtems_rbtree_control *  the_rbtree,
const rtems_rbtree_node *  the_node,
bool  is_unique
Parameters
[in]the_nodeA node specifying the key.
[in]compareThe node compare function.
[in]is_uniqueIf true, then return the first node with a key equal to the one of the node specified if it exits, else return the last node if it exists.
Return values
nodeA node corresponding to the key. If the tree is not unique and contains duplicate keys, the set of duplicate keys acts as FIFO.
NULLNo node exists in the tree for the key.
◆ rtems_rbtree_get_max()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_get_max ( rtems_rbtree_control *  the_rbtree)
This function removes the max node from the_rbtree and returns a pointer to that node. If the_rbtree is empty, then NULL is returned.
References _RBTree_Get().
◆ rtems_rbtree_get_min()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_get_min ( rtems_rbtree_control *  the_rbtree)
This function removes the min node from the_rbtree and returns a pointer to that node. If the_rbtree is empty, then NULL is returned.
◆ rtems_rbtree_initialize()
RTEMS_INLINE_ROUTINE void rtems_rbtree_initialize ( rtems_rbtree_control *  the_rbtree,
void *  starting_address,
size_t  node_size,
bool  is_unique
This routine initializes the_rbtree structure to manage the contiguous array of number_nodes nodes which starts at starting_address. Each node is of node_size bytes.
◆ rtems_rbtree_initialize_empty()
RTEMS_INLINE_ROUTINE void rtems_rbtree_initialize_empty ( rtems_rbtree_control *  the_rbtree)
This routine initializes the_rbtree to contain zero nodes.
References _RBTree_Initialize_empty().
◆ rtems_rbtree_insert()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_insert ( rtems_rbtree_control *  the_rbtree,
bool  is_unique
In case the node is already a node of a tree, then this function yields unpredictable results.
Parameters
[in]the_nodeThe node to insert.
[in]is_uniqueIf true, then reject nodes with a duplicate key, else insert nodes in FIFO order in case the key value is equal to existing nodes.
Return values
NULLSuccessfully inserted.
existing_nodeThis is a unique insert and there exists a node with an equal key in the tree already.
◆ rtems_rbtree_is_empty()
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_empty ( const rtems_rbtree_control *  the_rbtree)
This function returns true if there a no nodes on the_rbtree and false otherwise.
References _RBTree_Is_empty().
◆ rtems_rbtree_is_max()
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_max ( const rtems_rbtree_control *  the_rbtree,
This function returns true if the_node is the max node on the_rbtree and false otherwise.
References _RBTree_Is_first().
◆ rtems_rbtree_is_min()
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_min ( const rtems_rbtree_control *  the_rbtree,
This function returns true if the_node is the min node on the_rbtree and false otherwise.
◆ rtems_rbtree_is_node_off_tree()
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_node_off_tree ( const rtems_rbtree_node *  node)
This function returns true if the node is not on a rbtree. A node is off rbtree if the next and previous fields are set to NULL.
References _RBTree_Is_node_off_tree().
◆ rtems_rbtree_is_root()
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_root ( const rtems_rbtree_node *  the_node)
The root node may change after insert or extract operations. In case the node is not a node of a tree, then this function yields unpredictable results.
Parameters
[in]the_nodeThe node of interest.
Return values
trueThe node is the root node.
falseOtherwise.
See also
_RBTree_Root().
References _RBTree_Is_root().
◆ rtems_rbtree_left()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_left ( const rtems_rbtree_node *  the_node)
This function returns a pointer to the left child node of the_node.
References _RBTree_Left().
◆ rtems_rbtree_max()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_max ( const rtems_rbtree_control *  the_rbtree)
This function returns a pointer to the maximum node of the_rbtree.
References _RBTree_First().
◆ rtems_rbtree_min()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_min ( const rtems_rbtree_control *  the_rbtree)
This function returns a pointer to the minimum node of the_rbtree.
◆ rtems_rbtree_parent()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_parent ( const rtems_rbtree_node *  the_node)
The node must have a parent, thus it is invalid to use this function for the root node or a node that is not part of a tree. To test for the root node compare with _RBTree_Root() or use _RBTree_Is_root().
Parameters
Return values
parentThe parent of this node.
undefinedThe node is the root node or not part of a tree.
References _RBTree_Parent().
◆ rtems_rbtree_peek_max()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_peek_max ( const rtems_rbtree_control *  the_rbtree)
This function returns a pointer to the max node from the_rbtree without changing the tree. If the_rbtree is empty, then NULL is returned.
◆ rtems_rbtree_peek_min()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_peek_min ( const rtems_rbtree_control *  the_rbtree)
This function returns a pointer to the min node from the_rbtree without changing the tree. If the_rbtree is empty, then NULL is returned.
◆ rtems_rbtree_predecessor()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_predecessor ( const rtems_rbtree_node *  node)
Parameters
[in]nodeis the node.
Return values
NULLThe predecessor does not exist. Otherwise it returns the predecessor node.
References _RBTree_Predecessor().
◆ rtems_rbtree_right()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_right ( const rtems_rbtree_node *  the_node)
This function returns a pointer to the right child node of the_node.
References _RBTree_Right().
◆ rtems_rbtree_root()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_root ( const rtems_rbtree_control *  the_rbtree)
This function returns a pointer to the root node of the_rbtree.
References _RBTree_Root().
◆ rtems_rbtree_set_off_tree()
RTEMS_INLINE_ROUTINE void rtems_rbtree_set_off_tree ( rtems_rbtree_node *  node)
Set off RBtree.
This function sets the next and previous fields of the node to NULL indicating the node is not part of any rbtree.
References _RBTree_Set_off_tree().
◆ rtems_rbtree_successor()
RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_successor ( const rtems_rbtree_node *  node)
Parameters
Return values
NULLThe successor does not exist. Otherwise the successor node.
References _RBTree_Successor().
