RBTree_Node_struct Struct Reference
This is used to manage each element (node) which is placed on a RBT. More...
#include <rbtree.h>
Collaboration diagram for RBTree_Node_struct:
Collaboration graph
[legend]
RBTree_Node * parent
 This points to the node's parent.
RBTree_Node * child [2]
 child[0] points to the left child, child[1] points to the right child
RBTree_Color color
 The color of the node. More...
Note
Typically, a more complicated structure will use the rbtree package. The more complicated structure will include a rbtree node as the first element in its control structure. It will then call the rbtree package with a pointer to that node element. The node pointer and the higher level structure start at the same address so the user can cast the pointers back and forth.
Field Documentation
◆ color
RBTree_Color RBTree_Node_struct::color
Either red or black
Referenced by _RBTree_Is_red().
