Files | Data Structures | Macros | Typedefs | Enumerations | Functions
Semaphore Handler
This handler encapsulates functionality which provides the foundation Semaphore services used in all of the APIs supported by RTEMS. More...
Collaboration diagram for Semaphore Handler:
file  coresem.c
 Core Semaphore Initialize.
struct  CORE_semaphore_Attributes
 The following defines the control block used to manage the attributes of each semaphore. More...
struct  CORE_semaphore_Control
 The following defines the control block used to manage each counting semaphore. More...
#define CORE_SEMAPHORE_STATUS_LAST   CORE_SEMAPHORE_MAXIMUM_COUNT_EXCEEDED
 Core semaphore last status value. More...
typedef void(* CORE_semaphore_API_mp_support_callout) (Thread_Control *, Objects_Id)
 The following type defines the callout which the API provides to support global/multiprocessor operations on semaphores.
enum  CORE_semaphore_Disciplines { CORE_SEMAPHORE_DISCIPLINES_FIFO, CORE_SEMAPHORE_DISCIPLINES_PRIORITY }
 Blocking disciplines for a semaphore. More...
enum  CORE_semaphore_Status {
  CORE_SEMAPHORE_STATUS_SUCCESSFUL, CORE_SEMAPHORE_STATUS_UNSATISFIED_NOWAIT, CORE_SEMAPHORE_WAS_DELETED, CORE_SEMAPHORE_TIMEOUT,
 Core Semaphore handler return statuses. More...
void _CORE_semaphore_Initialize (CORE_semaphore_Control *the_semaphore, const CORE_semaphore_Attributes *the_semaphore_attributes, uint32_t initial_value)
 Initialize the semaphore based on the parameters passed. More...
RTEMS_INLINE_ROUTINE void _CORE_semaphore_Destroy (CORE_semaphore_Control *the_semaphore)
RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Surrender (CORE_semaphore_Control *the_semaphore, Objects_Id id, CORE_semaphore_API_mp_support_callout api_semaphore_mp_support, ISR_lock_Context *lock_context)
 Surrender a unit to a semaphore. More...
RTEMS_INLINE_ROUTINE void _CORE_semaphore_Flush (CORE_semaphore_Control *the_semaphore, Thread_queue_Flush_callout remote_extract_callout, uint32_t status)
 Core semaphore flush. More...
RTEMS_INLINE_ROUTINE bool _CORE_semaphore_Is_priority (const CORE_semaphore_Attributes *the_attribute)
 This function returns true if the priority attribute is enabled in the attribute_set and false otherwise. More...
RTEMS_INLINE_ROUTINE uint32_t _CORE_semaphore_Get_count (CORE_semaphore_Control *the_semaphore)
 This routine returns the current count associated with the semaphore. More...
RTEMS_INLINE_ROUTINE void _CORE_semaphore_Seize (CORE_semaphore_Control *the_semaphore, Thread_Control *executing, Objects_Id id, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context)
 This routine attempts to receive a unit from the_semaphore. More...
◆ CORE_SEMAPHORE_STATUS_LAST
This is the last status value.
Referenced by _POSIX_Semaphore_Translate_core_semaphore_return_code().
◆ CORE_semaphore_Disciplines
This specifies that threads will wait for the semaphore in FIFO order.
This specifies that threads will wait for the semaphore in priority order.
◆ CORE_semaphore_Status
This status indicates that the operation completed successfully.
This status indicates that the calling task did not want to block and the operation was unable to complete immediately because the resource was unavailable.
This status indicates that the thread was blocked waiting for an operation to complete and the semaphore was deleted.
This status indicates that the calling task was willing to block but the operation was unable to complete within the time allotted because the resource never became available.
This status indicates that an attempt was made to unlock the semaphore and this would have made its count greater than that allowed.
◆ _CORE_semaphore_Flush()
RTEMS_INLINE_ROUTINE void _CORE_semaphore_Flush ( CORE_semaphore_Control *  the_semaphore,
uint32_t  status
This package is the implementation of the CORE Semaphore Handler. This core object utilizes standard Dijkstra counting semaphores to provide synchronization and mutual exclusion capabilities.
This routine assists in the deletion of a semaphore by flushing the associated wait queue.
Parameters
[in]the_semaphoreis the semaphore to flush
[in]remote_extract_calloutis the routine to invoke if the thread unblocked is remote
[in]statusis the status to be returned to the unblocked thread
Referenced by _POSIX_Semaphore_Delete().
◆ _CORE_semaphore_Get_count()
RTEMS_INLINE_ROUTINE uint32_t _CORE_semaphore_Get_count ( CORE_semaphore_Control *  the_semaphore)
Parameters
[in]the_semaphoreis the semaphore to obtain the count of
Returns
the current count of this semaphore
References CORE_semaphore_Control::count.
◆ _CORE_semaphore_Initialize()
void _CORE_semaphore_Initialize ( CORE_semaphore_Control *  the_semaphore,
const CORE_semaphore_Attributes *  the_semaphore_attributes,
This routine initializes the semaphore based on the parameters passed.
Parameters
[in]the_semaphoreis the semaphore to initialize
[in]the_semaphore_attributesdefine the behavior of this instance
[in]initial_valueis the initial count of the semaphore
References _CORE_semaphore_Is_priority(), _Thread_queue_Initialize(), CORE_semaphore_Control::Attributes, CORE_semaphore_Control::count, and CORE_semaphore_Control::Wait_queue.
Referenced by rtems_semaphore_create().
◆ _CORE_semaphore_Is_priority()
RTEMS_INLINE_ROUTINE bool _CORE_semaphore_Is_priority ( const CORE_semaphore_Attributes *  the_attribute)
Parameters
[in]the_attributeis the attribute set to test
Returns
References CORE_SEMAPHORE_DISCIPLINES_PRIORITY, and CORE_semaphore_Attributes::discipline.
Referenced by _CORE_semaphore_Initialize().
◆ _CORE_semaphore_Seize()
RTEMS_INLINE_ROUTINE void _CORE_semaphore_Seize ( CORE_semaphore_Control *  the_semaphore,
Thread_Control *  executing,
Objects_Id  id,
bool  wait,
ISR_lock_Context *  lock_context
If a unit is available or if the wait flag is false, then the routine returns. Otherwise, the calling task is blocked until a unit becomes available.
Parameters
[in,out]executingThe currently executing thread.
[in]idis the Id of the owning API level Semaphore object
[in]waitis true if the thread is willing to wait
[in]timeoutis the maximum number of ticks to block
[in]lock_contextis a temporary variable used to contain the ISR disable level cookie
Note
There is currently no MACRO version of this routine.
Referenced by _MPCI_Receive_server().
◆ _CORE_semaphore_Surrender()
RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Surrender ( CORE_semaphore_Control *  the_semaphore,
Objects_Id  id,
This routine frees a unit to the semaphore. If a task was blocked waiting for a unit from this semaphore, then that task will be readied and the unit given to that task. Otherwise, the unit will be returned to the semaphore.
Parameters
[in]the_semaphoreis the semaphore to surrender
[in]idis the Id of the API level Semaphore object associated with this instance of a SuperCore Semaphore
[in]api_semaphore_mp_supportis the routine to invoke if the thread unblocked is remote
Return values
anindication of whether the routine succeeded or failed
Referenced by _MPCI_Announce().
