| #define | RTEMS_CONFIGURED_MINIMUM_STACK_SIZE 0 |
| | This constant can be used to indicate that the task should be created with the configured minimum stack size.
#define | RTEMS_CURRENT_PRIORITY 0 |
| | This constant is passed to rtems_task_set_priority() when the caller wants to obtain the current priority.
#define | RTEMS_MAXIMUM_PRIORITY _RTEMS_Maximum_priority() |
| | This runtime constant represents the lowest (least important) task priority of the scheduler with index zero.
#define | RTEMS_MINIMUM_PRIORITY 1 |
| | This compile time constant provides the highest (most important) task priority settable by the API.
| #define | RTEMS_MINIMUM_STACK_SIZE STACK_MINIMUM_SIZE |
| | This compile time constant provides the minimum task stack size recommended for the target architecture.
#define | RTEMS_NO_PRIORITY RTEMS_CURRENT_PRIORITY |
| | This compile time constant may be used for the rtems_task_set_priority() directive to get the current task priority.
#define | RTEMS_SELF OBJECTS_ID_OF_SELF |
| | This compile time constant may be used to identify the calling task in task related directives.
| #define | RTEMS_TASK_STORAGE_ALIGNMENT CPU_STACK_ALIGNMENT |
| | This compile time constant defines the recommended alignment of a task storage area in bytes.
| #define | RTEMS_TASK_STORAGE_SIZE(_size, _attributes) ( ( _size ) + CONTEXT_FP_SIZE ) |
| | Gets the recommended task storage area size for the size and task attributes.
#define | RTEMS_YIELD_PROCESSOR WATCHDOG_NO_TIMEOUT |
| | This compile time constant may be passed to the rtems_task_wake_after() directive as the interval when a task wishes to yield the processor.
rtems_task_priority | _RTEMS_Maximum_priority (void) |
| | Returns the maximum priority of the scheduler with index zero.
| rtems_status_code | rtems_task_create (rtems_name name, rtems_task_priority initial_priority, size_t stack_size, rtems_mode initial_modes, rtems_attribute attribute_set, rtems_id *id) |
| | Creates a task.
| rtems_status_code | rtems_task_construct (const rtems_task_config *config, rtems_id *id) |
| | Constructs a task from the specified task configuration.
| rtems_status_code | rtems_task_ident (rtems_name name, uint32_t node, rtems_id *id) |
| | Identifies a task by the object name.
| rtems_id | rtems_task_self (void) |
| | Gets the task identifier of the calling task.
| rtems_status_code | rtems_task_start (rtems_id id, rtems_task_entry entry_point, rtems_task_argument argument) |
| | Starts the task.
| rtems_status_code | rtems_task_restart (rtems_id id, rtems_task_argument argument) |
| | Restarts the task.
| rtems_status_code | rtems_task_delete (rtems_id id) |
| | Deletes the task.
| RTEMS_NO_RETURN void | rtems_task_exit (void) |
| | Deletes the calling task.
| rtems_status_code | rtems_task_suspend (rtems_id id) |
| | Suspends the task.
| rtems_status_code | rtems_task_resume (rtems_id id) |
| | Resumes the task.
| rtems_status_code | rtems_task_is_suspended (rtems_id id) |
| | Checks if the task is suspended.
| rtems_status_code | rtems_task_set_priority (rtems_id id, rtems_task_priority new_priority, rtems_task_priority *old_priority) |
| | Sets the real priority or gets the current priority of the task.
| rtems_status_code | rtems_task_get_priority (rtems_id task_id, rtems_id scheduler_id, rtems_task_priority *priority) |
| | Gets the current priority of the task with respect to the scheduler.
| rtems_status_code | rtems_task_mode (rtems_mode mode_set, rtems_mode mask, rtems_mode *previous_mode_set) |
| | Gets and optionally sets the mode of the calling task.
| rtems_status_code | rtems_task_wake_after (rtems_interval ticks) |
| | Wakes up after a count of clock ticks have occurred or yields the processor.
| rtems_status_code | rtems_task_wake_when (const rtems_time_of_day *time_buffer) |
| | Wakes up when specified.
| rtems_status_code | rtems_task_get_scheduler (rtems_id task_id, rtems_id *scheduler_id) |
| | Gets the home scheduler of the task.
| rtems_status_code | rtems_task_set_scheduler (rtems_id task_id, rtems_id scheduler_id, rtems_task_priority priority) |
| | Sets the home scheduler for the task.
| rtems_status_code | rtems_task_get_affinity (rtems_id id, size_t cpusetsize, cpu_set_t *cpuset) |
| | Gets the processor affinity of the task.
| rtems_status_code | rtems_task_set_affinity (rtems_id id, size_t cpusetsize, const cpu_set_t *cpuset) |
| | Sets the processor affinity of the task.
| void | rtems_task_iterate (rtems_task_visitor visitor, void *arg) |
| | Iterates over all tasks and invokes the visitor routine for each task.
This header file defines the main parts of the Tasks Manager API.
