RTEMS 6.1
attr.h
2
11/*
12 * Copyright (C) 2014, 2020 embedded brains GmbH & Co. KG
13 * Copyright (C) 2008 On-Line Applications Research Corporation (OAR)
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37/*
38 * This file is part of the RTEMS quality process and was automatically
39 * generated. If you find something that needs to be fixed or
40 * worded better please post a report or patch to an RTEMS mailing list
41 * or raise a bug report:
42 *
43 * https://www.rtems.org/bugs.html
44 *
45 * For information on updating and regenerating please refer to the How-To
46 * section in the Software Requirements Engineering chapter of the
47 * RTEMS Software Engineering manual. The manual is provided as a part of
48 * a release. For development sources please refer to the online
49 * documentation at:
50 *
51 * https://docs.rtems.org
52 */
53
54/* Generated from spec:/rtems/attr/if/header */
55
56#ifndef _RTEMS_RTEMS_ATTR_H
57#define _RTEMS_RTEMS_ATTR_H
58
59#include <stdint.h>
60
61#ifdef __cplusplus
62extern "C" {
63#endif
64
65/* Generated from spec:/rtems/attr/if/group */
66
75/* Generated from spec:/rtems/attr/if/application-task */
76
84#define RTEMS_APPLICATION_TASK 0x00000000
85
86/* Generated from spec:/rtems/attr/if/attribute */
87
96typedef uint32_t rtems_attribute;
97
98/* Generated from spec:/rtems/attr/if/barrier-automatic-release */
99
107#define RTEMS_BARRIER_AUTOMATIC_RELEASE 0x00000200
108
109/* Generated from spec:/rtems/attr/if/barrier-manual-release */
110
117#define RTEMS_BARRIER_MANUAL_RELEASE 0x00000000
118
119/* Generated from spec:/rtems/attr/if/binary-semaphore */
120
128#define RTEMS_BINARY_SEMAPHORE 0x00000010
129
130/* Generated from spec:/rtems/attr/if/counting-semaphore */
131
138#define RTEMS_COUNTING_SEMAPHORE 0x00000000
139
140/* Generated from spec:/rtems/attr/if/default */
141
147#define RTEMS_DEFAULT_ATTRIBUTES 0x00000000
148
149/* Generated from spec:/rtems/attr/if/fifo */
150
157#define RTEMS_FIFO 0x00000000
158
159/* Generated from spec:/rtems/attr/if/floating-point */
160
172#define RTEMS_FLOATING_POINT 0x00000001
173
174/* Generated from spec:/rtems/attr/if/global */
175
185#define RTEMS_GLOBAL 0x00000002
186
187/* Generated from spec:/rtems/attr/if/inherit-priority */
188
199#define RTEMS_INHERIT_PRIORITY 0x00000040
200
201/* Generated from spec:/rtems/attr/if/local */
202
212#define RTEMS_LOCAL 0x00000000
213
214/* Generated from spec:/rtems/attr/if/multiprocessor-resource-sharing */
215
226#define RTEMS_MULTIPROCESSOR_RESOURCE_SHARING 0x00000100
227
228/* Generated from spec:/rtems/attr/if/no-floating-point */
229
241#define RTEMS_NO_FLOATING_POINT 0x00000000
242
243/* Generated from spec:/rtems/attr/if/no-inherit-priority */
244
252#define RTEMS_NO_INHERIT_PRIORITY 0x00000000
253
254/* Generated from spec:/rtems/attr/if/no-multiprocessor-resource-sharing */
255
263#define RTEMS_NO_MULTIPROCESSOR_RESOURCE_SHARING 0x00000000
264
265/* Generated from spec:/rtems/attr/if/no-priority-ceiling */
266
274#define RTEMS_NO_PRIORITY_CEILING 0x00000000
275
276/* Generated from spec:/rtems/attr/if/priority */
277
284#define RTEMS_PRIORITY 0x00000004
285
286/* Generated from spec:/rtems/attr/if/priority-ceiling */
287
298#define RTEMS_PRIORITY_CEILING 0x00000080
299
300/* Generated from spec:/rtems/attr/if/semaphore-class */
301
309#define RTEMS_SEMAPHORE_CLASS 0x00000030
310
311/* Generated from spec:/rtems/attr/if/simple-binary-semaphore */
312
319#define RTEMS_SIMPLE_BINARY_SEMAPHORE 0x00000020
320
321/* Generated from spec:/rtems/attr/if/system-task */
322
329#define RTEMS_SYSTEM_TASK 0x00008000
330
331#ifdef __cplusplus
332}
333#endif
334
335#endif /* _RTEMS_RTEMS_ATTR_H */
This type represents Classic API attributes.
Definition: attr.h:96
