| file | aarch64-exception-default.c |
| | This source file contains the implementation of _AArch64_Exception_default().
| file | aarch64-exception-frame-print.c |
| | Implementation of _CPU_Exception_frame_print.
| file | aarch64-exception-frame.c |
| | This source file contains the implementation of _CPU_Exception_disable_thread_dispatch(), _CPU_Exception_frame_get_signal(), _CPU_Exception_frame_set_resume(), and _CPU_Exception_frame_make_resume_next_instruction().
| file | aarch64-thread-idle.c |
| | This source file contains the AArch64-specific _CPU_Thread_Idle_body() implementation.
| file | cpu.c |
| | AArch64 architecture support implementation.
| file | mmu-vmsav8-64.h |
| | Definitions used in MMU setup.
| file | vectors.h |
| | ARM AArch64 Exception API.
| file | aarch64-system-registers.h |
| | This header file provides the API to read and write the AArch64 system registers.
| file | cpu.h |
| | This header file provides interfaces of the AArch64 CPU port.
#define | AARCH64_MULTILIB_HAS_WFI |
#define | AARCH64_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE |
#define | AARCH64_MULTILIB_HAS_BARRIER_INSTRUCTIONS |
#define | AARCH64_MULTILIB_HAS_CPACR |
#define | AARCH64_MULTILIB_CACHE_LINE_MAX_64 |
#define | CPU_NAME "AArch64" |
#define | CPU_SIMPLE_VECTORED_INTERRUPTS FALSE |
#define | CPU_ISR_PASSES_FRAME_POINTER FALSE |
#define | CPU_HARDWARE_FP FALSE |
#define | CPU_SOFTWARE_FP FALSE |
#define | CPU_ALL_TASKS_ARE_FP FALSE |
#define | CPU_IDLE_TASK_IS_FP FALSE |
#define | CPU_USE_DEFERRED_FP_SWITCH FALSE |
#define | CPU_ENABLE_ROBUST_THREAD_DISPATCH TRUE |
#define | CPU_STACK_GROWS_UP FALSE |
#define | CPU_CACHE_LINE_BYTES 32 |
#define | CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES ) |
#define | CPU_MODES_INTERRUPT_MASK 0x1 |
#define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
#define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
#define | CPU_STACK_MINIMUM_SIZE (1024 * 8) |
#define | CPU_SIZEOF_POINTER __SIZEOF_POINTER__ |
#define | CPU_ALIGNMENT 16 |
#define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_STACK_ALIGNMENT 16 |
#define | CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES |
#define | CPU_USE_GENERIC_BITFIELD_CODE TRUE |
#define | CPU_USE_LIBC_INIT_FINI_ARRAY TRUE |
#define | CPU_MAXIMUM_PROCESSORS 32 |
#define | AARCH64_CONTEXT_CONTROL_THREAD_ID_OFFSET 0x70 |
#define | AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 0x68 |
#define | AARCH64_EXCEPTION_FRAME_SIZE 0x350 |
#define | AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET 0xF8 |
#define | AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET 0xF0 |
#define | AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET 0x108 |
#define | AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET 0x118 |
#define | AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET 0x128 |
#define | AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET 0x138 |
#define | AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET 0x150 |
| #define | _CPU_ISR_Disable(_isr_cookie) |
#define | _CPU_ISR_Enable(_isr_cookie) AArch64_interrupt_enable( _isr_cookie ) |
#define | _CPU_ISR_Flash(_isr_cookie) AArch64_interrupt_flash( _isr_cookie ) |
#define | _CPU_Context_Get_SP(_context) (_context)->register_sp |
#define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
| #define | _CPU_Context_Initialize_fp(_destination) |
#define | VECTOR_POINTER_OFFSET 0x78 |
#define | VECTOR_ENTRY_SIZE 0x80 |
#define | CPU_PER_CPU_CONTROL_SIZE 0 |
#define | CPU_INTERRUPT_FRAME_SIZE 0x2E0 |
#define | CPU_THREAD_LOCAL_STORAGE_VARIANT 11 |
| enum | AArch64_symbolic_exception_name {
AARCH64_EXCEPTION_SP0_SYNCHRONOUS = 0
, AARCH64_EXCEPTION_SP0_IRQ = 1
, AARCH64_EXCEPTION_SP0_FIQ = 2
, AARCH64_EXCEPTION_SP0_SERROR = 3
AARCH64_EXCEPTION_SPx_SYNCHRONOUS = 4
, AARCH64_EXCEPTION_SPx_IRQ = 5
, AARCH64_EXCEPTION_SPx_FIQ = 6
, AARCH64_EXCEPTION_SPx_SERROR = 7
AARCH64_EXCEPTION_LEL64_SYNCHRONOUS = 8
, AARCH64_EXCEPTION_LEL64_IRQ = 9
, AARCH64_EXCEPTION_LEL64_FIQ = 10
, AARCH64_EXCEPTION_LEL64_SERROR = 11
AARCH64_EXCEPTION_LEL32_SYNCHRONOUS = 12
, AARCH64_EXCEPTION_LEL32_IRQ = 13
, AARCH64_EXCEPTION_LEL32_FIQ = 14
, AARCH64_EXCEPTION_LEL32_SERROR = 15
MAX_EXCEPTIONS = 16
, AARCH64_EXCEPTION_MAKE_ENUM_64_BIT = INT_MAX
| void | _CPU_ISR_Set_level (uint32_t level) |
| | Sets the hardware interrupt level by the level value.
uint32_t | _CPU_ISR_Get_level (void) |
void | _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint64_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area) |
| void | _CPU_Initialize (void) |
| | CPU initialization.
void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
| | CPU switch context.
RTEMS_NO_RETURN void | _CPU_Context_switch_no_return (Context_Control *executing, Context_Control *heir) |
RTEMS_NO_RETURN void | _CPU_Context_restore (Context_Control *new_context) |
uint32_t | _CPU_Counter_frequency (void) |
CPU_Counter_ticks | _CPU_Counter_read (void) |
RTEMS_NO_RETURN void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
void | _AArch64_Exception_interrupt_no_nest (void) |
void | _AArch64_Exception_interrupt_nest (void) |
void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
RTEMS_NO_RETURN void | _CPU_Exception_resume (CPU_Exception_frame *frame) |
RTEMS_NO_RETURN void | _CPU_Exception_dispatch_and_resume (CPU_Exception_frame *frame) |
void | _CPU_Exception_disable_thread_dispatch (void) |
int | _CPU_Exception_frame_get_signal (CPU_Exception_frame *frame) |
void | _CPU_Exception_frame_set_resume (CPU_Exception_frame *frame, void *address) |
void | _CPU_Exception_frame_make_resume_next_instruction (CPU_Exception_frame *frame) |
void | _AArch64_Exception_frame_copy (CPU_Exception_frame *new_ef, CPU_Exception_frame *old_ef) |
void | _AArch64_Exception_default (CPU_Exception_frame *frame) |
void | _CPU_Context_volatile_clobber (uintptr_t pattern) |
void | _CPU_Context_validate (uintptr_t pattern) |
This group contains the AArch64 CPU port.
ARM AArch64 Architecture Support.
