RTEMS 6.1
This handler encapsulates the functionality (primarily conditional feature defines) related to paravirtualization on the AArch64. More...
Files | |
| file | paravirt.h |
| This header file provides definitions pertaining to paravirtualization of the AArch64 port. | |
| #define | AARCH64_DISABLE_INLINE_ISR_DISABLE_ENABLE |
Paravirtualization on the AArch64 makes the following assumptions:
| #define AARCH64_DISABLE_INLINE_ISR_DISABLE_ENABLE |
In a paravirtualized environment, RTEMS executes in user space and cannot disable/enable external exceptions (e.g. interrupts). The BSP which acts as an adapter to the hosting environment will provide the interrupt enable/disable methods.
