RTEMS 6.1
Implementation of _CPU_Exception_frame_print. More...
#include <inttypes.h>#include <rtems/score/cpu.h>#include <rtems/dev/io.h>#include <rtems/bspIo.h>Data Structures | |
| struct | String_Context |
| void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
| Prints the exception frame via printk(). | |
This file implements _CPU_Exception_frame_print for use in fatal output. It dumps all standard integer and floating point registers as well as some of the more important system registers.
