RTEMS 6.1
Data Structures | Macros | Typedefs | Enumerations | Functions
This header file provides interfaces of the AArch64 CPU port. More...
#include <rtems/score/aarch64.h>
#include <libcpu/vectors.h>
#include <limits.h>
struct  Context_Control
 Thread register context. More...
struct  CPU_Exception_frame
 The set of registers that specifies the complete processor state. More...
#define CPU_SIMPLE_VECTORED_INTERRUPTS   FALSE
#define CPU_ISR_PASSES_FRAME_POINTER   FALSE
#define CPU_HARDWARE_FP   FALSE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   FALSE
#define CPU_ENABLE_ROBUST_THREAD_DISPATCH   TRUE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_CACHE_LINE_BYTES   32
#define CPU_STRUCTURE_ALIGNMENT   RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
#define CPU_MODES_INTERRUPT_MASK   0x1
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   0
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_STACK_MINIMUM_SIZE   (1024 * 8)
#define CPU_SIZEOF_POINTER   __SIZEOF_POINTER__
#define CPU_ALIGNMENT   16
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   16
#define CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
#define CPU_USE_LIBC_INIT_FINI_ARRAY   TRUE
#define CPU_MAXIMUM_PROCESSORS   32
#define AARCH64_CONTEXT_CONTROL_THREAD_ID_OFFSET   0x70
#define AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE   0x68
#define AARCH64_EXCEPTION_FRAME_SIZE   0x350
#define AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET   0xF8
#define AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET   0xF0
#define AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET   0x108
#define AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET   0x118
#define AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET   0x128
#define AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET   0x138
#define AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET   0x150
#define _CPU_ISR_Disable(_isr_cookie)
#define _CPU_ISR_Enable(_isr_cookie)    AArch64_interrupt_enable( _isr_cookie )
#define _CPU_ISR_Flash(_isr_cookie)    AArch64_interrupt_flash( _isr_cookie )
#define _CPU_Context_Get_SP(_context)    (_context)->register_sp
#define _CPU_Context_Restart_self(_the_context)    _CPU_Context_restore( (_the_context) );
#define _CPU_Context_Initialize_fp(_destination)
#define VECTOR_POINTER_OFFSET   0x78
#define VECTOR_ENTRY_SIZE   0x80
Program State Registers
#define AARCH64_PSTATE_N   (1LL << 31)
#define AARCH64_PSTATE_Z   (1LL << 30)
#define AARCH64_PSTATE_C   (1LL << 29)
#define AARCH64_PSTATE_V   (1LL << 28)
#define AARCH64_PSTATE_D   (1LL << 9)
#define AARCH64_PSTATE_A   (1LL << 8)
#define AARCH64_PSTATE_I   (1LL << 7)
#define AARCH64_PSTATE_F   (1LL << 6)
typedef unsigned __int128 uint128_t
typedef void(* CPU_ISR_handler) (void)
typedef uint32_t CPU_Counter_ticks
typedef uintptr_t CPU_Uint32ptr
enum  AArch64_symbolic_exception_name {
  AARCH64_EXCEPTION_SP0_SYNCHRONOUS = 0 , AARCH64_EXCEPTION_SP0_IRQ = 1 , AARCH64_EXCEPTION_SP0_FIQ = 2 , AARCH64_EXCEPTION_SP0_SERROR = 3 ,
  AARCH64_EXCEPTION_SPx_SYNCHRONOUS = 4 , AARCH64_EXCEPTION_SPx_IRQ = 5 , AARCH64_EXCEPTION_SPx_FIQ = 6 , AARCH64_EXCEPTION_SPx_SERROR = 7 ,
  AARCH64_EXCEPTION_LEL64_SYNCHRONOUS = 8 , AARCH64_EXCEPTION_LEL64_IRQ = 9 , AARCH64_EXCEPTION_LEL64_FIQ = 10 , AARCH64_EXCEPTION_LEL64_SERROR = 11 ,
  AARCH64_EXCEPTION_LEL32_SYNCHRONOUS = 12 , AARCH64_EXCEPTION_LEL32_IRQ = 13 , AARCH64_EXCEPTION_LEL32_FIQ = 14 , AARCH64_EXCEPTION_LEL32_SERROR = 15 ,
  MAX_EXCEPTIONS = 16 , AARCH64_EXCEPTION_MAKE_ENUM_64_BIT = INT_MAX
void _CPU_ISR_Set_level (uint32_t level)
 Sets the hardware interrupt level by the level value.
uint32_t _CPU_ISR_Get_level (void)
void _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint64_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
void _CPU_Initialize (void)
 CPU initialization.
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context.
RTEMS_NO_RETURN void _CPU_Context_switch_no_return (Context_Control *executing, Context_Control *heir)
RTEMS_NO_RETURN void _CPU_Context_restore (Context_Control *new_context)
uint32_t _CPU_Counter_frequency (void)
CPU_Counter_ticks _CPU_Counter_read (void)
RTEMS_NO_RETURN void * _CPU_Thread_Idle_body (uintptr_t ignored)
void _AArch64_Exception_interrupt_no_nest (void)
void _AArch64_Exception_interrupt_nest (void)
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
RTEMS_NO_RETURN void _CPU_Exception_resume (CPU_Exception_frame *frame)
RTEMS_NO_RETURN void _CPU_Exception_dispatch_and_resume (CPU_Exception_frame *frame)
void _CPU_Exception_disable_thread_dispatch (void)
int _CPU_Exception_frame_get_signal (CPU_Exception_frame *frame)
void _CPU_Exception_frame_set_resume (CPU_Exception_frame *frame, void *address)
void _CPU_Exception_frame_make_resume_next_instruction (CPU_Exception_frame *frame)
void _AArch64_Exception_frame_copy (CPU_Exception_frame *new_ef, CPU_Exception_frame *old_ef)
void _AArch64_Exception_default (CPU_Exception_frame *frame)
