RTEMS 6.1
Macros | Functions
aarch64-exception-frame.c File Reference
This source file contains the implementation of _CPU_Exception_disable_thread_dispatch(), _CPU_Exception_frame_get_signal(), _CPU_Exception_frame_set_resume(), and _CPU_Exception_frame_make_resume_next_instruction(). More...
#include <rtems/score/cpu.h>
#include <rtems/score/aarch64-system-registers.h>
#define AARCH64_INSTRUCTION_SIZE   4
void _CPU_Exception_disable_thread_dispatch (void)
void _AArch64_Exception_frame_copy (CPU_Exception_frame *new_ef, CPU_Exception_frame *old_ef)
int _CPU_Exception_frame_get_signal (CPU_Exception_frame *ef)
void _CPU_Exception_frame_set_resume (CPU_Exception_frame *ef, void *address)
void _CPU_Exception_frame_make_resume_next_instruction (CPU_Exception_frame *ef)
