RTEMS 6.1
stack.h
2
13/*
14 * Copyright (C) 2022 embedded brains GmbH & Co. KG
15 * Copyright (C) 1989, 2021 On-Line Applications Research Corporation (OAR)
16 *
17 * Redistribution and use in source and binary forms, with or without
18 * modification, are permitted provided that the following conditions
19 * are met:
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 * 2. Redistributions in binary form must reproduce the above copyright
23 * notice, this list of conditions and the following disclaimer in the
24 * documentation and/or other materials provided with the distribution.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36 * POSSIBILITY OF SUCH DAMAGE.
37 */
38
39#ifndef _RTEMS_SCORE_STACK_H
40#define _RTEMS_SCORE_STACK_H
41
43
44#ifdef __cplusplus
45extern "C" {
46#endif
47
66#define STACK_MINIMUM_SIZE CPU_STACK_MINIMUM_SIZE
67
71typedef struct {
73 size_t size;
75 void *area;
77
83typedef void ( *Stack_Allocator_initialize )( size_t stack_space_size );
84
93typedef void *( *Stack_Allocator_allocate )( size_t stack_size );
94
100typedef void ( *Stack_Allocator_free )( void *addr );
101
121typedef void *( *Stack_Allocator_allocate_for_idle )(
122 uint32_t cpu,
123 size_t *stack_size
124);
125
131extern uint32_t rtems_minimum_stack_size;
132
138extern const uintptr_t _Stack_Space_size;
139
145extern const bool _Stack_Allocator_avoids_workspace;
146
153
160
167
174
189 uint32_t unused,
190 size_t *storage_size
191);
192
200
208
222 uint32_t cpu_index,
223 size_t *storage_size
224);
225
233
236#ifdef __cplusplus
237}
238#endif
239
240#endif
241/* end of include file */
This header file provides basic definitions used by the API and the implementation.
char _Stack_Allocator_allocate_for_idle_storage_areas[]
The thread storage areas used by _Stack_Allocator_allocate_for_idle_static().
void(* Stack_Allocator_initialize)(size_t stack_space_size)
The stack allocator initialization handler.
Definition: stack.h:83
const Stack_Allocator_allocate_for_idle _Stack_Allocator_allocate_for_idle
The stack allocator allocate stack for idle thread handler.
void _Stack_Allocator_do_initialize(void)
Do the stack allocator initialization during system initialize.
Definition: stackallocatorinit.c:44
void * _Stack_Allocator_allocate_for_idle_workspace(uint32_t unused, size_t *storage_size)
Allocates the IDLE thread storage area from the workspace.
Definition: stackallocatorforidlewkspace.c:45
void *(* Stack_Allocator_allocate_for_idle)(uint32_t cpu, size_t *stack_size)
Stack allocator allocate for idle handler.
Definition: stack.h:121
Indicates if the stack allocator avoids the workspace.
Definition: stackallocator.c:45
void *(* Stack_Allocator_allocate)(size_t stack_size)
Stack allocator allocate handler.
Definition: stack.h:93
The configured stack space size.
const Stack_Allocator_allocate _Stack_Allocator_allocate
The stack allocator allocate handler.
Definition: stackallocator.c:47
void * _Stack_Allocator_allocate_for_idle_static(uint32_t cpu_index, size_t *storage_size)
Allocates the IDLE thread storage from the memory statically allocated by <rtems/confdefs....
Definition: stackallocatorforidle.c:44
const size_t _Stack_Allocator_allocate_for_idle_storage_size
The size in bytes of the idle thread storage area used by _Stack_Allocator_allocate_for_idle_static()...
const Stack_Allocator_free _Stack_Allocator_free
The stack allocator free handler.
Definition: stackallocatorfree.c:44
const Stack_Allocator_initialize _Stack_Allocator_initialize
void(* Stack_Allocator_free)(void *addr)
Stack allocator free handler.
Definition: stack.h:100
The minimum stack size.
Definition: stack.h:71
size_t size
Definition: stack.h:73
void * area
Definition: stack.h:75
