RTEMS 6.1
This header file provides interfaces of the Stack Handler which are used by the implementation and the Application Configuration. More...
#include <rtems/score/basedefs.h>Go to the source code of this file.
| struct | Stack_Control |
| #define | STACK_MINIMUM_SIZE CPU_STACK_MINIMUM_SIZE |
Typedefs | |
| typedef void(* | Stack_Allocator_initialize) (size_t stack_space_size) |
| The stack allocator initialization handler. | |
| typedef void *(* | Stack_Allocator_allocate) (size_t stack_size) |
| Stack allocator allocate handler. | |
| typedef void(* | Stack_Allocator_free) (void *addr) |
| Stack allocator free handler. | |
| typedef void *(* | Stack_Allocator_allocate_for_idle) (uint32_t cpu, size_t *stack_size) |
| Stack allocator allocate for idle handler. | |
| void | _Stack_Allocator_do_initialize (void) |
| Do the stack allocator initialization during system initialize. | |
| void * | _Stack_Allocator_allocate_for_idle_workspace (uint32_t unused, size_t *storage_size) |
| Allocates the IDLE thread storage area from the workspace. | |
| void * | _Stack_Allocator_allocate_for_idle_static (uint32_t cpu_index, size_t *storage_size) |
| Allocates the IDLE thread storage from the memory statically allocated by <rtems/confdefs.h>. | |
| uint32_t | rtems_minimum_stack_size |
| The minimum stack size. | |
| const uintptr_t | _Stack_Space_size |
| The configured stack space size. | |
| const bool | _Stack_Allocator_avoids_workspace |
| Indicates if the stack allocator avoids the workspace. | |
| const Stack_Allocator_initialize | _Stack_Allocator_initialize |
| const Stack_Allocator_allocate | _Stack_Allocator_allocate |
| The stack allocator allocate handler. | |
| const Stack_Allocator_free | _Stack_Allocator_free |
| The stack allocator free handler. | |
| const size_t | _Stack_Allocator_allocate_for_idle_storage_size |
| The size in bytes of the idle thread storage area used by _Stack_Allocator_allocate_for_idle_static(). | |
| char | _Stack_Allocator_allocate_for_idle_storage_areas [] |
| The thread storage areas used by _Stack_Allocator_allocate_for_idle_static(). | |
| const Stack_Allocator_allocate_for_idle | _Stack_Allocator_allocate_for_idle |
| The stack allocator allocate stack for idle thread handler. | |
