RTEMS 6.1
Files | Data Structures | Macros | Typedefs | Functions | Variables
Stack Handler
This group contains the Stack Handler implementation. More...
file  stack.h
 This header file provides interfaces of the Stack Handler which are used by the implementation and the Application Configuration.
file  stackimpl.h
 This header file provides interfaces of the Stack Handler which are only used by the implementation.
file  stackallocator.c
 This source file contains a definition of _Stack_Allocator_avoids_workspace and _Stack_Allocator_allocate which allocates the thread stacks from the RTEMS Workspace.
file  stackallocatorforidle.c
 This source file contains the implementation of _Stack_Allocator_allocate_for_idle_static().
file  stackallocatorforidlewkspace.c
 This source file contains the implementation of _Stack_Allocator_allocate_for_idle_workspace().
file  stackallocatorfree.c
 This source file contains a definition of _Stack_Allocator_free which frees the thread stacks to the RTEMS Workspace.
file  stackallocatorinit.c
 This source file contains the implementation of _Stack_Allocator_do_initialize().
file  threadstackallocate.c
 This source file contains the implementation of _Stack_Allocate().
file  threadstackfree.c
 This source file contains the implementation of _Stack_Free().
struct  Stack_Control
#define STACK_MINIMUM_SIZE   CPU_STACK_MINIMUM_SIZE
typedef void(* Stack_Allocator_initialize) (size_t stack_space_size)
 The stack allocator initialization handler.
typedef void *(* Stack_Allocator_allocate) (size_t stack_size)
 Stack allocator allocate handler.
typedef void(* Stack_Allocator_free) (void *addr)
 Stack allocator free handler.
typedef void *(* Stack_Allocator_allocate_for_idle) (uint32_t cpu, size_t *stack_size)
 Stack allocator allocate for idle handler.
void _Stack_Allocator_do_initialize (void)
 Do the stack allocator initialization during system initialize.
void * _Stack_Allocator_allocate_for_idle_workspace (uint32_t unused, size_t *storage_size)
 Allocates the IDLE thread storage area from the workspace.
void * _Stack_Allocator_allocate_for_idle_static (uint32_t cpu_index, size_t *storage_size)
 Allocates the IDLE thread storage from the memory statically allocated by <rtems/confdefs.h>.
void * _Stack_Allocate (size_t stack_size)
 Allocate the requested stack space.
void _Stack_Free (void *stack_area)
 Free the stack area allocated by _Stack_Allocate().
uint32_t rtems_minimum_stack_size
 The minimum stack size.
const uintptr_t _Stack_Space_size
 The configured stack space size.
const bool _Stack_Allocator_avoids_workspace
 Indicates if the stack allocator avoids the workspace.
const Stack_Allocator_initialize _Stack_Allocator_initialize
const Stack_Allocator_allocate _Stack_Allocator_allocate
 The stack allocator allocate handler.
const Stack_Allocator_free _Stack_Allocator_free
 The stack allocator free handler.
const size_t _Stack_Allocator_allocate_for_idle_storage_size
 The size in bytes of the idle thread storage area used by _Stack_Allocator_allocate_for_idle_static().
char _Stack_Allocator_allocate_for_idle_storage_areas []
 The thread storage areas used by _Stack_Allocator_allocate_for_idle_static().
const Stack_Allocator_allocate_for_idle _Stack_Allocator_allocate_for_idle
 The stack allocator allocate stack for idle thread handler.
This handler encapsulates functionality which is used in the management of thread stacks. It provides mechanisms which can be used to initialize and utilize stacks.
◆ STACK_MINIMUM_SIZE
The following constant defines the minimum stack size which every thread must exceed.
Typedef Documentation
◆ Stack_Allocator_allocate
Parameters
stack_sizeThe size of the stack area to allocate in bytes.
Return values
NULLNot enough memory.
otherPointer to begin of stack area.
◆ Stack_Allocator_allocate_for_idle
The allocate for idle handler is optional even when the user thread stack allocator and deallocator are configured.
Parameters
cpuis the index of the CPU for the IDLE thread using this stack.
stack_size[in,out]is pointer to a size_t object. On function entry, the object contains the proposed size of the stack area to allocate in bytes. The proposed size does not take the actual thread-local storage size of the application into account. The stack allocator can modify the size to ensure that there is enough space available in the stack area for the thread-local storage.
Return values
NULLThere was not enough memory available to allocate a stack area.
Returns
Returns the pointer to begin of the allocated stack area.
◆ Stack_Allocator_free
Parameters
]addr A pointer to previously allocated stack area or NULL.
◆ Stack_Allocator_initialize
Parameters
stack_space_sizeThe size of the stack space in bytes.
◆ _Stack_Allocate()
void * _Stack_Allocate ( size_t  stack_size)
Parameters
stack_sizeThe stack space that is requested.
Return values
stack_areaThe allocated stack area.
NULLThe allocation failed.
◆ _Stack_Allocator_allocate_for_idle_static()
void * _Stack_Allocator_allocate_for_idle_static ( uint32_t  cpu_index,
size_t *  storage_size
Parameters
cpu_indexis the index of the CPU for the IDLE thread using this stack.
stack_size[out]is pointer to a size_t object. On function return, the object value is set to the value of _Stack_Allocator_allocate_for_idle_storage_size.
Returns
Returns a pointer to the begin of the allocated task storage area.
◆ _Stack_Allocator_allocate_for_idle_workspace()
void * _Stack_Allocator_allocate_for_idle_workspace ( uint32_t  unused,
If the thread storage area cannot be allocated, then the ::INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STACK fatal error will occur.
Parameters
unusedis an unused parameter.
stack_size[in]is pointer to a size_t object. On function entry, the object contains the size of the task storage area to allocate in bytes.
Returns
◆ _Stack_Allocator_do_initialize()
void _Stack_Allocator_do_initialize ( void  )
This function is used to initialize application provided stack allocators.
◆ _Stack_Free()
void _Stack_Free ( void *  stack_area)
Do nothing if the stack area is NULL.
Parameters
stack_areaThe stack area to free, or NULL.
Variable Documentation
extern
Application provided via <rtems/confdefs.h>.
extern
◆ _Stack_Allocator_allocate_for_idle_storage_areas
char _Stack_Allocator_allocate_for_idle_storage_areas[]
extern
◆ _Stack_Allocator_allocate_for_idle_storage_size
extern
◆ _Stack_Allocator_avoids_workspace
extern
◆ _Stack_Allocator_free
extern
◆ _Stack_Allocator_initialize
extern
◆ _Stack_Space_size
extern
◆ rtems_minimum_stack_size
extern
