RTEMS 6.1
This group contains the Watchdog Handler implementation. More...
Files | |
| file | watchdog.h |
| This header file provides interfaces of the Watchdog Handler which are used by the implementation and the Application Configuration. | |
| file | watchdogimpl.h |
| This header file provides interfaces of the Watchdog Handler which are only used by the implementation. | |
| file | watchdogticks.h |
| This header file provides the interfaces of the Watchdog Handler related to watchdog ticks which are used by the implementation and the Application Configuration. | |
| file | watchdoginsert.c |
| This source file contains the implementation of _Watchdog_Insert(). | |
| file | watchdogremove.c |
| This source file contains the implementation of _Watchdog_Remove(). | |
| file | watchdogtick.c |
| This source file contains the implementation of _Watchdog_Do_tickle() and _Watchdog_Tick(). | |
| file | watchdogtickssinceboot.c |
| This source file contains the definition of _Watchdog_Ticks_since_boot. | |
| file | watchdogtimeslicedefault.c |
| This source file contains the default definition of _Watchdog_Ticks_per_timeslice. | |
| struct | Watchdog_Header |
| The watchdog header to manage scheduled watchdogs. More... | |
| struct | Watchdog_Control |
| The control block used to manage each watchdog timer. More... | |
| #define | WATCHDOG_INITIALIZER(routine) |
| Watchdog initializer for static initialization. | |
| #define | _Watchdog_Tickle(header, first, now, lock, lock_context) _Watchdog_Do_tickle( header, first, now, lock_context ) |
| #define | WATCHDOG_MAXIMUM_TICKS UINT64_MAX |
| The maximum watchdog ticks value for the far future. | |
| #define | WATCHDOG_NANOSECONDS_PER_SECOND 1000000000 |
| #define | WATCHDOG_BITS_FOR_1E9_NANOSECONDS 30 |
| The bits necessary to store 1000000000 (= WATCHDOG_NANOSECONDS_PER_SECOND) nanoseconds. | |
| #define | WATCHDOG_MAX_SECONDS 0x3ffffffff |
| The maximum number of seconds representable in the nanoseconds watchdog format. | |
| #define | WATCHDOG_NO_TIMEOUT 0 |
| Special watchdog ticks value to indicate an infinite wait. | |
| #define | WATCHDOG_TICKS_PER_TIMESLICE_DEFAULT 50 |
| Default value for the watchdog ticks per timeslice. | |
Typedefs | |
| typedef struct Watchdog_Control | Watchdog_Control |
| typedef void | Watchdog_Service_routine |
| Return type from a Watchdog Service Routine. | |
| typedef Watchdog_Service_routine(* | Watchdog_Service_routine_entry) (Watchdog_Control *) |
| Pointer to a watchdog service routine. | |
| typedef uint32_t | Watchdog_Interval |
| Type is used to specify the length of intervals. | |
Enumerations | |
| enum | Watchdog_State { WATCHDOG_SCHEDULED_BLACK , WATCHDOG_SCHEDULED_RED , WATCHDOG_INACTIVE , WATCHDOG_PENDING } |
| Watchdog states. More... | |
| void | _Watchdog_Tick (struct Per_CPU_Control *cpu) |
| Performs a watchdog tick. | |
| void | _Watchdog_Do_tickle (Watchdog_Header *header, Watchdog_Control *first, uint64_t now, ISR_lock_Context *lock_context) |
| Calls the routine of each not expired watchdog control node. | |
| void | _Watchdog_Insert (Watchdog_Header *header, Watchdog_Control *the_watchdog, uint64_t expire) |
| Inserts a watchdog into the set of scheduled watchdogs according to the specified expiration time. | |
| void | _Watchdog_Remove (Watchdog_Header *header, Watchdog_Control *the_watchdog) |
| In the case the watchdog is scheduled, then it is removed from the set of scheduled watchdogs. | |
| volatile Watchdog_Interval | _Watchdog_Ticks_since_boot |
| The watchdog ticks counter. | |
| const uint32_t | _Watchdog_Microseconds_per_tick |
| The watchdog microseconds per tick. | |
| const uint32_t | _Watchdog_Nanoseconds_per_tick |
| The watchdog nanoseconds per tick. | |
| const uint32_t | _Watchdog_Ticks_per_second |
| The watchdog ticks per second. | |
| const uint32_t | _Watchdog_Ticks_per_timeslice |
| The watchdog ticks per timeslice. | |
This handler encapsulates functionality related to the scheduling of watchdog functions to be called at specific times in the future. It provides mechanisms which can be used to initialize and manipulate watchdog timers.
| #define WATCHDOG_BITS_FOR_1E9_NANOSECONDS 30 |
The expiration time is an unsigned 64-bit integer. To store nanoseconds timeouts we use 30 bits (2**30 == 1073741824) for the nanoseconds and 34 bits for the seconds since UNIX Epoch. This leads to a year 2514 problem.
| #define WATCHDOG_INITIALIZER | ( | routine | ) |
The processor of this watchdog is set to processor with index zero.
| #define WATCHDOG_MAX_SECONDS 0x3ffffffff |
We have 2**34 bits for the seconds part.
| typedef uint32_t Watchdog_Interval |
This type is used to specify the length of intervals.
| typedef void Watchdog_Service_routine |
This type defines the return type from a Watchdog Service Routine.
| typedef Watchdog_Service_routine(* Watchdog_Service_routine_entry) (Watchdog_Control *) |
This type define a pointer to a watchdog service routine.
| enum Watchdog_State |
Watchdog states.
| void _Watchdog_Do_tickle | ( | Watchdog_Header * | header, |
| Watchdog_Control * | first, | ||
| uint64_t | now, | ||
| ISR_lock_Context * | lock_context | ||
| header | The watchdog header. |
| first | The first watchdog control node. |
| now | The current time to check the expiration time against. |
| lock | The lock that is released before calling the routine and then acquired after the call. |
| lock_context | The lock context for the release before calling the routine and for the acquire after. |
| void _Watchdog_Insert | ( | Watchdog_Header * | header, |
| Watchdog_Control * | the_watchdog, | ||
| uint64_t | expire | ||
The watchdog must be inactive.
| [in,out] | header | The set of scheduler watchdogs to insert into. |
| [in,out] | the_watchdog | The watchdog to insert. |
| expire | The expiration time for the watchdog. |
| void _Watchdog_Remove | ( | Watchdog_Header * | header, |
| Watchdog_Control * | the_watchdog | ||
The watchdog must be initialized before this call.
| [in,out] | header | The scheduled watchdogs. |
| [in,out] | the_watchdog | The watchdog to remove. |
| void _Watchdog_Tick | ( | struct Per_CPU_Control * | cpu | ) |
| cpu | The processor for this watchdog tick. |
extern |
This constant is defined by the application configuration via <rtems/confdefs.h>.
extern |
extern |
extern |
extern |
With a 1ms watchdog tick, this counter overflows after 50 days since boot.
