RTEMS 6.1
This header file provides the interfaces of the Watchdog Handler related to watchdog ticks which are used by the implementation and the Application Configuration. More...
#include <rtems/score/basedefs.h>Go to the source code of this file.
| #define | WATCHDOG_NO_TIMEOUT 0 |
| Special watchdog ticks value to indicate an infinite wait. | |
| #define | WATCHDOG_TICKS_PER_TIMESLICE_DEFAULT 50 |
| Default value for the watchdog ticks per timeslice. | |
Typedefs | |
| typedef uint32_t | Watchdog_Interval |
| Type is used to specify the length of intervals. | |
| volatile Watchdog_Interval | _Watchdog_Ticks_since_boot |
| The watchdog ticks counter. | |
| const uint32_t | _Watchdog_Microseconds_per_tick |
| The watchdog microseconds per tick. | |
| const uint32_t | _Watchdog_Nanoseconds_per_tick |
| The watchdog nanoseconds per tick. | |
| const uint32_t | _Watchdog_Ticks_per_second |
| The watchdog ticks per second. | |
| const uint32_t | _Watchdog_Ticks_per_timeslice |
| The watchdog ticks per timeslice. | |
