RTEMS 6.1
Watchdog_Control Struct Reference
The control block used to manage each watchdog timer. More...
#include <watchdog.h>
union {
   RBTree_Node   RBTree
 this field is a red-black tree node structure and allows this to be placed on a red-black tree used to manage the scheduled watchdogs.
   Chain_Node   Chain
 this field is a chain node structure and allows this to be placed on a chain used to manage pending watchdogs by the timer server.
Node
 Nodes for the watchdog.
Watchdog_Service_routine_entry routine
 This field is the function to invoke.
uint64_t expire
 This field is the expiration time point.
The following record defines the control block used to manage each watchdog timer.
