RTEMS 5.2
cpu.h File Reference
#include <rtems/score/moxie.h>
#include <rtems/bspIo.h>
struct  Context_Control
 Thread register context. More...
struct  CPU_Interrupt_frame
 Interrupt stack frame (ISF). More...
struct  CPU_Exception_frame
 The set of registers that specifies the complete processor state. More...
#define RTEMS_USE_32_BIT_OBJECT
#define CPU_SIMPLE_VECTORED_INTERRUPTS   TRUE
#define CPU_HARDWARE_FP   FALSE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   FALSE
#define CPU_ENABLE_ROBUST_THREAD_DISPATCH   FALSE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_CACHE_LINE_BYTES   32
#define CPU_STRUCTURE_ALIGNMENT
#define CPU_MODES_INTERRUPT_MASK   0x00000001
#define CPU_MAXIMUM_PROCESSORS   32
#define nogap   __attribute__ ((packed))
#define _CPU_Context_Get_SP(_context)    (_context)->sp
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   0
#define CPU_INTERRUPT_NUMBER_OF_VECTORS   64
#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER    (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_STACK_MINIMUM_SIZE   (1536)
#define CPU_SIZEOF_POINTER   4
#define CPU_ALIGNMENT   8
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   0
#define CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES
#define _CPU_Initialize_vectors()
#define _CPU_ISR_Disable(_isr_cookie)
#define _CPU_ISR_Enable(_isr_cookie)
#define _CPU_ISR_Flash(_isr_cookie)
#define _CPU_ISR_Set_level(_new_level)
#define CPU_CCR_INTERRUPTS_ON   0x80
#define CPU_CCR_INTERRUPTS_OFF   0x00
#define _CPU_Context_Initialize(_the_context, _stack_base, _size, _isr, _entry_point, _is_fp, _tls_area)
#define _CPU_Context_Restart_self(_the_context)    _CPU_Context_restore( (_the_context) );
#define _CPU_Fatal_halt(_source, _error)
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
#define CPU_swap_u16(value)    (((value&0xff) << 8) | ((value >> 8)&0xff))
typedef void(* CPU_ISR_handler) (uint32_t)
typedef uint32_t CPU_Counter_ticks
typedef uintptr_t CPU_Uint32ptr
RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled (uint32_t level)
uint32_t _CPU_ISR_Get_level (void)
void _CPU_Initialize (void)
 CPU initialization. More...
void _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
void * _CPU_Thread_Idle_body (uintptr_t)
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context. More...
void _CPU_Context_restore (Context_Control *new_context) RTEMS_NO_RETURN
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 Prints the exception frame via printk(). More...
uint32_t _CPU_Counter_frequency (void)
CPU_Counter_ticks _CPU_Counter_read (void)
◆ _CPU_Context_Initialize
#define _CPU_Context_Initialize (   _the_context,
  _stack_base,
  _size,
  _isr,
  _entry_point,
  _is_fp,
  _tls_area
Value:
/* Locate Me */ \
do { \
uintptr_t _stack; \
(void) _is_fp; /* avoid warning for being unused */ \
(void) _isr; /* avoid warning for being unused */ \
_stack = ((uintptr_t)(_stack_base)) + (_size) - 8; \
*((void (**)(void))(_stack)) = (_entry_point); \
_stack -= 4; \
(_the_context)->fp = (void *)_stack; \
(_the_context)->sp = (void *)_stack; \
} while (0)
#define sp
stack-pointer *‍/
Definition: regs.h:64
#define fp
frame-pointer *‍/
Definition: regs.h:65
◆ _CPU_Fatal_halt
#define _CPU_Fatal_halt (   _source,
  _error
Value:
printk("Fatal Error %d.%lu Halted\n",_source,_error); \
for(;;)
int printk(const char *fmt,...) RTEMS_PRINTFLIKE(1
Kernel Print.
◆ _CPU_ISR_Disable
#define _CPU_ISR_Disable (   _isr_cookie)
Value:
do { \
(_isr_cookie) = 0; \
} while (0)
◆ _CPU_ISR_Enable
#define _CPU_ISR_Enable (   _isr_cookie)
Value:
do { \
(_isr_cookie) = (_isr_cookie); \
} while (0)
◆ _CPU_ISR_Flash
#define _CPU_ISR_Flash (   _isr_cookie)
Value:
do { \
_CPU_ISR_Enable( _isr_cookie ); \
_CPU_ISR_Disable( _isr_cookie ); \
} while (0)
◆ _CPU_ISR_Set_level
#define _CPU_ISR_Set_level (   _new_level)
Value:
if (_new_level) asm volatile ( "nop\n" ); \
else asm volatile ( "nop\n" ); \
◆ CPU_SIZEOF_POINTER
Size of a pointer.
This must be an integer literal that can be used by the assembler. This value will be used to calculate offsets of structure members. These offsets will be used in assembler code.
Typedef Documentation
◆ CPU_Uint32ptr
Type that can store a 32-bit integer or a pointer.
