RTEMS 5.2
#include <rtems/score/basedefs.h>#include <rtems/score/epiphany.h>#include <rtems/bspIo.h>#include <stdint.h>#include <stdio.h>#include <inttypes.h>Go to the source code of this file.
| struct | Context_Control |
| Thread register context. More... | |
| struct | CPU_Exception_frame |
| The set of registers that specifies the complete processor state. More... | |
| #define | CPU_ISR_PASSES_FRAME_POINTER TRUE |
| #define | CPU_HARDWARE_FP FALSE |
| #define | CPU_SOFTWARE_FP FALSE |
| #define | CPU_ALL_TASKS_ARE_FP FALSE |
| #define | CPU_IDLE_TASK_IS_FP FALSE |
| #define | CPU_USE_DEFERRED_FP_SWITCH FALSE |
| #define | CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE |
| #define | CPU_STACK_GROWS_UP FALSE |
| #define | CPU_CACHE_LINE_BYTES 64 |
| #define | CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES ) |
| #define | CPU_MODES_INTERRUPT_MASK 0x00000001 |
| #define | _CPU_Context_Get_SP(_context) (_context)->r[13] |
| #define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
| #define | CPU_STACK_MINIMUM_SIZE 4096 |
| #define | CPU_ALIGNMENT 8 |
| #define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
| #define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
| #define | CPU_STACK_ALIGNMENT 8 |
| #define | CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES |
| #define | _CPU_Initialize_vectors() |
| #define | _CPU_ISR_Disable(_level) _level = epiphany_interrupt_disable() |
| #define | _CPU_ISR_Enable(_level) epiphany_interrupt_enable( _level ) |
| #define | _CPU_ISR_Flash(_level) |
| #define | EPIPHANY_GCC_RED_ZONE_SIZE 128 |
| Account for GCC red-zone. More... | |
| #define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ) |
| #define | _CPU_Fatal_halt(_source, _error) |
| #define | CPU_USE_GENERIC_BITFIELD_CODE TRUE |
| #define | CPU_SIZEOF_POINTER 4 |
| #define | CPU_EXCEPTION_FRAME_SIZE 260 |
| #define | CPU_MAXIMUM_PROCESSORS 32 |
| #define | CPU_swap_u16(value) (((value&0xff) << 8) | ((value >> 8)&0xff)) |
Typedefs | |
| typedef Context_Control | CPU_Interrupt_frame |
| typedef uint32_t | CPU_Counter_ticks |
| typedef uintptr_t | CPU_Uint32ptr |
| RTEMS_INLINE_ROUTINE bool | _CPU_ISR_Is_enabled (uint32_t level) |
| void | _CPU_ISR_Set_level (uint32_t level) |
| Sets the hardware interrupt level by the level value. More... | |
| uint32_t | _CPU_ISR_Get_level (void) |
| void | _CPU_Context_Initialize (Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area) |
| Initializes the CPU context. More... | |
| void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
| Prints the exception frame via printk(). More... | |
| void | _CPU_Initialize (void) |
| CPU initialization. More... | |
| void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
| void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
| CPU switch context. More... | |
| void | _CPU_Context_restore (Context_Control *new_context) RTEMS_NO_RETURN |
| void | _CPU_Context_save_fp (void **fp_context_ptr) |
| void | _CPU_Context_restore_fp (void **fp_context_ptr) |
| uint32_t | _CPU_Counter_frequency (void) |
| CPU_Counter_ticks | _CPU_Counter_read (void) |
