confdefs.h
1
13 /*
14  * COPYRIGHT (c) 1989-2015.
15  * On-Line Applications Research Corporation (OAR).
16  *
17  * The license and distribution terms for this file may be
18  * found in the file LICENSE in this distribution or at
19  * http://www.rtems.org/license/LICENSE.
20  */
21
22 #ifndef __CONFIGURATION_TEMPLATE_h
23 #define __CONFIGURATION_TEMPLATE_h
24
25 /*
26  * Include the executive's configuration
27  */
28 #include <rtems.h>
29 #include <rtems/score/apimutex.h>
30 #include <rtems/score/percpu.h>
31 #include <rtems/score/wkspace.h>
32
33 #ifdef CONFIGURE_DISABLE_BSP_SETTINGS
34  #undef BSP_DEFAULT_UNIFIED_WORK_AREAS
35  #undef BSP_IDLE_TASK_BODY
36  #undef BSP_IDLE_TASK_STACK_SIZE
37  #undef BSP_INITIAL_EXTENSION
38  #undef BSP_INTERRUPT_STACK_SIZE
39  #undef BSP_MAXIMUM_DEVICES
40  #undef BSP_ZERO_WORKSPACE_AUTOMATICALLY
41  #undef CONFIGURE_BSP_PREREQUISITE_DRIVERS
42  #undef CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
43 #else
44  #include <bsp.h>
45 #endif
46
47 #ifdef RTEMS_NEWLIB
48  #include <sys/reent.h>
49 #endif
50
51 #ifdef __cplusplus
52 extern "C" {
53 #endif
54
83
84 #if defined(RTEMS_MULTIPROCESSING)
85
88  extern rtems_multiprocessing_table Multiprocessing_configuration;
89 #endif
90
91 #ifdef RTEMS_POSIX_API
92
96 #endif
97
102 #ifdef RTEMS_SCHEDSIM
103  #undef RTEMS_NEWLIB
104 #endif
105
106 #if (defined(RTEMS_NEWLIB) && !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY))
107  #define CONFIGURE_NEWLIB_EXTENSION 1
108 #else
109  #define CONFIGURE_NEWLIB_EXTENSION 0
110 #endif
111
112 #ifndef RTEMS_SCHEDSIM
113 #include <rtems/libio_.h>
114
115 #ifdef CONFIGURE_INIT
116 const rtems_libio_helper rtems_libio_init_helper =
117  #ifdef CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
118  rtems_libio_helper_null;
119  #else
121  #endif
122
123 const rtems_libio_helper rtems_libio_post_driver_helper =
124  #ifdef CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
125  rtems_libio_helper_null;
126  #else
127  rtems_libio_post_driver;
128  #endif
129
130 const rtems_libio_helper rtems_libio_exit_helper =
131  #ifdef CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
132  rtems_libio_helper_null;
133  #else
134  rtems_libio_exit;
135  #endif
136
137 const rtems_libio_helper rtems_fs_init_helper =
138  #ifdef CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
139  rtems_libio_helper_null;
140  #else
142  #endif
143 #endif
144 #endif
145
151 #ifndef CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
152  #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 3
153 #endif
154
158 #define CONFIGURE_LIBIO_SEMAPHORES 1
159
163 #define CONFIGURE_LIBIO_POSIX_KEYS 1
164
168 #ifdef RTEMS_DRVMGR_STARTUP
169  #define CONFIGURE_DRVMGR_SEMAPHORES 1
170 #else
171  #define CONFIGURE_DRVMGR_SEMAPHORES 0
172 #endif
173
174 #ifdef CONFIGURE_INIT
176
181  const uint32_t rtems_libio_number_iops = RTEMS_ARRAY_SIZE(rtems_libio_iops);
182 #endif
183
189 #ifdef CONFIGURE_TERMIOS_DISABLED
190  #define CONFIGURE_TERMIOS_SEMAPHORES 0
191 #else
192
196  #ifndef CONFIGURE_NUMBER_OF_TERMIOS_PORTS
197  #define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 1
198  #endif
199
204  #define CONFIGURE_TERMIOS_SEMAPHORES \
205  ((CONFIGURE_NUMBER_OF_TERMIOS_PORTS * 4) + 1)
206 #endif
207
212 #ifndef CONFIGURE_MAXIMUM_PTYS
213  #define CONFIGURE_MAXIMUM_PTYS 0
214 #endif
215
220 #ifdef CONFIGURE_INIT
222 #else
223  extern int rtems_telnetd_maximum_ptys;
224 #endif
225
226 #if defined(RTEMS_SMP)
227  /*
228  * If configured for SMP, then we need to know the maximum CPU cores.
229  */
230  #if !defined(CONFIGURE_SMP_APPLICATION)
231  #if !defined(CONFIGURE_SMP_MAXIMUM_PROCESSORS)
232  #define CONFIGURE_SMP_MAXIMUM_PROCESSORS 1
233  #endif
234  #else
235  #if !defined(CONFIGURE_SMP_MAXIMUM_PROCESSORS)
236  #error "CONFIGURE_SMP_MAXIMUM_PROCESSORS not specified for SMP Application"
237  #endif
238  #endif
239 #endif
240
241 /*
242  * This sets up the resources for the FIFOs/pipes.
243  */
244
248 #if !defined(CONFIGURE_MAXIMUM_FIFOS)
249  #define CONFIGURE_MAXIMUM_FIFOS 0
250 #endif
251
255 #if !defined(CONFIGURE_MAXIMUM_PIPES)
256  #define CONFIGURE_MAXIMUM_PIPES 0
257 #endif
258
265 #if CONFIGURE_MAXIMUM_FIFOS > 0 || CONFIGURE_MAXIMUM_PIPES > 0
266  #define CONFIGURE_BARRIERS_FOR_FIFOS \
267  (2 * (CONFIGURE_MAXIMUM_FIFOS + CONFIGURE_MAXIMUM_PIPES))
268 #else
269  #define CONFIGURE_BARRIERS_FOR_FIFOS 0
270 #endif
271
278 #if CONFIGURE_MAXIMUM_FIFOS > 0 || CONFIGURE_MAXIMUM_PIPES > 0
279  #define CONFIGURE_SEMAPHORES_FOR_FIFOS \
280  (1 + (CONFIGURE_MAXIMUM_FIFOS + CONFIGURE_MAXIMUM_PIPES))
281 #else
282  #define CONFIGURE_SEMAPHORES_FOR_FIFOS 0
283 #endif
284
324 #ifdef CONFIGURE_INIT
325
326  /*
327  * Include all file systems. Do this before checking if the filesystem has
328  * been disabled.
329  */
330  #ifdef CONFIGURE_FILESYSTEM_ALL
331  #define CONFIGURE_FILESYSTEM_IMFS
332  #define CONFIGURE_FILESYSTEM_DEVFS
333  #define CONFIGURE_FILESYSTEM_TFTPFS
334  #define CONFIGURE_FILESYSTEM_FTPFS
335  #define CONFIGURE_FILESYSTEM_NFS
336  #define CONFIGURE_FILESYSTEM_DOSFS
337  #define CONFIGURE_FILESYSTEM_RFS
338  #define CONFIGURE_FILESYSTEM_JFFS2
339  #endif
340
341  /*
342  * If disabling the file system, give a compile error if the user has
343  * configured other filesystem parameters.
344  */
345  #if defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM)
346  #if defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM)
347  #error "Filesystem disabled and a base filesystem configured."
348  #endif
349
350  #if defined(CONFIGURE_FILESYSTEM_IMFS) || \
351  defined(CONFIGURE_FILESYSTEM_DEVFS) || \
352  defined(CONFIGURE_FILESYSTEM_TFTPFS) || \
353  defined(CONFIGURE_FILESYSTEM_FTPFS) || \
354  defined(CONFIGURE_FILESYSTEM_NFS) || \
355  defined(CONFIGURE_FILESYSTEM_DOSFS) || \
356  defined(CONFIGURE_FILESYSTEM_RFS) || \
357  defined(CONFIGURE_FILESYSTEM_JFFS2)
358  #error "Filesystem disabled and a filesystem configured."
359  #endif
360  #endif
361
362  /*
363  * If the base filesystem is DEVFS define it else define IMFS.
364  * We will have either DEVFS or IMFS defined after this.
365  */
366  #if !defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM)
367  #if defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM)
368  #define CONFIGURE_FILESYSTEM_DEVFS
369  #endif
370  #endif
371
372 #endif
373
374 #ifndef RTEMS_SCHEDSIM
375
378 #include <rtems/imfs.h>
379
386 #ifndef CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
387  #define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK \
388  IMFS_MEMFILE_DEFAULT_BYTES_PER_BLOCK
389 #endif
390
394 #if !defined(CONFIGURE_FILESYSTEM_ENTRY_IMFS) && \
395  defined(CONFIGURE_FILESYSTEM_IMFS)
396  #define CONFIGURE_FILESYSTEM_ENTRY_IMFS \
397  { RTEMS_FILESYSTEM_TYPE_IMFS, IMFS_initialize }
398 #endif
399 #endif
400
401 #ifdef CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
402  #define CONFIGURE_IMFS_DISABLE_CHMOD
403  #define CONFIGURE_IMFS_DISABLE_CHOWN
404  #define CONFIGURE_IMFS_DISABLE_UTIME
405  #define CONFIGURE_IMFS_DISABLE_LINK
406  #define CONFIGURE_IMFS_DISABLE_SYMLINK
407  #define CONFIGURE_IMFS_DISABLE_READLINK
408  #define CONFIGURE_IMFS_DISABLE_RENAME
409  #define CONFIGURE_IMFS_DISABLE_UNMOUNT
410 #endif
411
415 #if !defined(CONFIGURE_FILESYSTEM_ENTRY_DEVFS) && \
416  defined(CONFIGURE_FILESYSTEM_DEVFS)
417 #include <rtems/devfs.h>
418  #define CONFIGURE_FILESYSTEM_ENTRY_DEVFS \
419  { RTEMS_FILESYSTEM_TYPE_DEVFS, devFS_initialize }
420 #endif
421
422 #ifdef RTEMS_NETWORKING
423
426  #if !defined(CONFIGURE_FILESYSTEM_ENTRY_FTPFS) && \
427  defined(CONFIGURE_FILESYSTEM_FTPFS)
428  #include <rtems/ftpfs.h>
429  #define CONFIGURE_FILESYSTEM_ENTRY_FTPFS \
430  { RTEMS_FILESYSTEM_TYPE_FTPFS, rtems_ftpfs_initialize }
431  #endif
432
436  #if !defined(CONFIGURE_FILESYSTEM_ENTRY_TFTPFS) && \
437  defined(CONFIGURE_FILESYSTEM_TFTPFS)
438  #include <rtems/tftp.h>
439  #define CONFIGURE_FILESYSTEM_ENTRY_TFTPFS \
440  { RTEMS_FILESYSTEM_TYPE_TFTPFS, rtems_tftpfs_initialize }
441  #endif
442
446  #if !defined(CONFIGURE_FILESYSTEM_ENTRY_NFS) && \
447  defined(CONFIGURE_FILESYSTEM_NFS)
448  #include <librtemsNfs.h>
449  #if !defined(CONFIGURE_MAXIMUM_NFS_MOUNTS)
450  #define CONFIGURE_MAXIMUM_NFS_MOUNTS 1
451  #endif
452  #define CONFIGURE_FILESYSTEM_ENTRY_NFS \
453  { RTEMS_FILESYSTEM_TYPE_NFS, rtems_nfs_initialize }
454  #define CONFIGURE_SEMAPHORES_FOR_NFS ((CONFIGURE_MAXIMUM_NFS_MOUNTS * 2) + 1)
455  #else
456  #define CONFIGURE_SEMAPHORES_FOR_NFS 0
457  #endif
458 #else
459  #define CONFIGURE_SEMAPHORES_FOR_NFS 0
460 #endif
461
465 #if !defined(CONFIGURE_FILESYSTEM_ENTRY_DOSFS) && \
466  defined(CONFIGURE_FILESYSTEM_DOSFS)
467  #include <rtems/dosfs.h>
468  #if !defined(CONFIGURE_MAXIMUM_DOSFS_MOUNTS)
469  #define CONFIGURE_MAXIMUM_DOSFS_MOUNTS 1
470  #endif
471  #define CONFIGURE_FILESYSTEM_ENTRY_DOSFS \
472  { RTEMS_FILESYSTEM_TYPE_DOSFS, rtems_dosfs_initialize }
473  #define CONFIGURE_SEMAPHORES_FOR_DOSFS CONFIGURE_MAXIMUM_DOSFS_MOUNTS
474 #else
475  #define CONFIGURE_SEMAPHORES_FOR_DOSFS 0
476 #endif
477
481 #if !defined(CONFIGURE_FILESYSTEM_ENTRY_RFS) && \
482  defined(CONFIGURE_FILESYSTEM_RFS)
483  #include <rtems/rtems-rfs.h>
484  #if !defined(CONFIGURE_MAXIMUM_RFS_MOUNTS)
485  #define CONFIGURE_MAXIMUM_RFS_MOUNTS 1
486  #endif
487  #define CONFIGURE_FILESYSTEM_ENTRY_RFS \
488  { RTEMS_FILESYSTEM_TYPE_RFS, rtems_rfs_rtems_initialise }
489  #define CONFIGURE_SEMAPHORES_FOR_RFS CONFIGURE_MAXIMUM_RFS_MOUNTS
490 #else
491  #define CONFIGURE_SEMAPHORES_FOR_RFS 0
492 #endif
493
497 #if !defined(CONFIGURE_FILESYSTEM_ENTRY_JFFS2) && \
498  defined(CONFIGURE_FILESYSTEM_JFFS2)
499  #include <rtems/jffs2.h>
500  #if !defined(CONFIGURE_MAXIMUM_JFFS2_MOUNTS)
501  #define CONFIGURE_MAXIMUM_JFFS2_MOUNTS 1
502  #endif
503  #define CONFIGURE_FILESYSTEM_ENTRY_JFFS2 \
504  { RTEMS_FILESYSTEM_TYPE_JFFS2, rtems_jffs2_initialize }
505  #define CONFIGURE_SEMAPHORES_FOR_JFFS2 CONFIGURE_MAXIMUM_JFFS2_MOUNTS
506 #else
507  #define CONFIGURE_SEMAPHORES_FOR_JFFS2 0
508 #endif
509
516 #define CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS \
517  (CONFIGURE_SEMAPHORES_FOR_FIFOS + \
518  CONFIGURE_SEMAPHORES_FOR_NFS + \
519  CONFIGURE_SEMAPHORES_FOR_DOSFS + \
520  CONFIGURE_SEMAPHORES_FOR_RFS + \
521  CONFIGURE_SEMAPHORES_FOR_JFFS2)
522
523 #ifdef CONFIGURE_INIT
524
534  #ifdef CONFIGURE_FILESYSTEM_DEVFS
535  #ifndef CONFIGURE_MAXIMUM_DEVICES
536  #if defined(BSP_MAXIMUM_DEVICES)
537  #define CONFIGURE_MAXIMUM_DEVICES BSP_MAXIMUM_DEVICES
538  #else
539  #define CONFIGURE_MAXIMUM_DEVICES 4
540  #endif
541  #endif
542  #include <rtems/devfs.h>
543  #endif
544
548  #define CONFIGURE_FILESYSTEM_NULL { NULL, NULL }
549
550 #ifndef RTEMS_SCHEDSIM
551  #if !defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM) && \
552  !defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM)
553  int imfs_rq_memfile_bytes_per_block =
555  #endif
556
561  #if !defined(CONFIGURE_HAS_OWN_FILESYSTEM_TABLE) && \
562  !defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM)
564  #if !defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM)
565  { "/", IMFS_initialize_support },
566  #endif
567  #if defined(CONFIGURE_FILESYSTEM_IMFS) && \
568  defined(CONFIGURE_FILESYSTEM_ENTRY_IMFS)
569  CONFIGURE_FILESYSTEM_ENTRY_IMFS,
570  #endif
571  #if defined(CONFIGURE_FILESYSTEM_DEVFS) && \
572  defined(CONFIGURE_FILESYSTEM_ENTRY_DEVFS)
573  CONFIGURE_FILESYSTEM_ENTRY_DEVFS,
574  #endif
575  #if defined(CONFIGURE_FILESYSTEM_TFTPFS) && \
576  defined(CONFIGURE_FILESYSTEM_ENTRY_TFTPFS)
577  CONFIGURE_FILESYSTEM_ENTRY_TFTPFS,
578  #endif
579  #if defined(CONFIGURE_FILESYSTEM_FTPFS) && \
580  defined(CONFIGURE_FILESYSTEM_ENTRY_FTPFS)
581  CONFIGURE_FILESYSTEM_ENTRY_FTPFS,
582  #endif
583  #if defined(CONFIGURE_FILESYSTEM_NFS) && \
584  defined(CONFIGURE_FILESYSTEM_ENTRY_NFS)
585  CONFIGURE_FILESYSTEM_ENTRY_NFS,
586  #endif
587  #if defined(CONFIGURE_FILESYSTEM_DOSFS) && \
588  defined(CONFIGURE_FILESYSTEM_ENTRY_DOSFS)
589  CONFIGURE_FILESYSTEM_ENTRY_DOSFS,
590  #endif
591  #if defined(CONFIGURE_FILESYSTEM_RFS) && \
592  defined(CONFIGURE_FILESYSTEM_ENTRY_RFS)
593  CONFIGURE_FILESYSTEM_ENTRY_RFS,
594  #endif
595  #if defined(CONFIGURE_FILESYSTEM_JFFS2) && \
596  defined(CONFIGURE_FILESYSTEM_ENTRY_JFFS2)
597  CONFIGURE_FILESYSTEM_ENTRY_JFFS2,
598  #endif
599  CONFIGURE_FILESYSTEM_NULL
600  };
601  #endif
602
603  #if !defined(CONFIGURE_HAS_OWN_MOUNT_TABLE) && \
604  !defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM)
605  #if defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM)
606  static devFS_node devFS_root_filesystem_nodes [CONFIGURE_MAXIMUM_DEVICES];
607  static const devFS_data devFS_root_filesystem_data = {
608  devFS_root_filesystem_nodes,
609  CONFIGURE_MAXIMUM_DEVICES
610  };
611  #else
612  static IMFS_fs_info_t _Configure_IMFS_fs_info;
613
614  static const rtems_filesystem_operations_table _Configure_IMFS_ops = {
618  #ifdef CONFIGURE_IMFS_DISABLE_LINK
620  #else
621  IMFS_link,
622  #endif
624  #ifdef CONFIGURE_IMFS_DISABLE_MKNOD
626  #else
627  IMFS_mknod,
628  #endif
629  #ifdef CONFIGURE_IMFS_DISABLE_RMNOD
631  #else
632  IMFS_rmnod,
633  #endif
634  #ifdef CONFIGURE_IMFS_DISABLE_CHMOD
636  #else
637  IMFS_fchmod,
638  #endif
639  #ifdef CONFIGURE_IMFS_DISABLE_CHOWN
641  #else
642  IMFS_chown,
643  #endif
646  #ifdef CONFIGURE_IMFS_DISABLE_MOUNT
648  #else
649  IMFS_mount,
650  #endif
651  #ifdef CONFIGURE_IMFS_DISABLE_UNMOUNT
653  #else
654  IMFS_unmount,
655  #endif
657  #ifdef CONFIGURE_IMFS_DISABLE_UTIME
659  #else
660  IMFS_utime,
661  #endif
662  #ifdef CONFIGURE_IMFS_DISABLE_SYMLINK
664  #else
665  IMFS_symlink,
666  #endif
667  #ifdef CONFIGURE_IMFS_DISABLE_READLINK
669  #else
671  #endif
672  #ifdef CONFIGURE_IMFS_DISABLE_RENAME
674  #else
675  IMFS_rename,
676  #endif
678  };
679
680  static const IMFS_mknod_controls _Configure_IMFS_mknod_controls = {
681  #ifdef CONFIGURE_IMFS_DISABLE_READDIR
682  &IMFS_mknod_control_dir_minimal,
683  #else
684  &IMFS_mknod_control_dir_default,
685  #endif
686  &IMFS_mknod_control_device,
687  #ifdef CONFIGURE_IMFS_DISABLE_MKNOD_FILE
688  &IMFS_mknod_control_enosys,
689  #else
690  &IMFS_mknod_control_memfile,
691  #endif
692  #if CONFIGURE_MAXIMUM_FIFOS > 0 || CONFIGURE_MAXIMUM_PIPES > 0
693  &IMFS_mknod_control_fifo
694  #else
695  &IMFS_mknod_control_enosys
696  #endif
697  };
698
699  static const IMFS_mount_data _Configure_IMFS_mount_data = {
700  &_Configure_IMFS_fs_info,
701  &_Configure_IMFS_ops,
702  &_Configure_IMFS_mknod_controls
703  };
704  #endif
705
707  rtems_filesystem_root_configuration = {
708  NULL,
709  NULL,
710  #if defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM)
711  RTEMS_FILESYSTEM_TYPE_DEVFS,
712  #else
713  "/",
714  #endif
715  RTEMS_FILESYSTEM_READ_WRITE,
716  #if defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM)
717  &devFS_root_filesystem_data
718  #else
719  &_Configure_IMFS_mount_data
720  #endif
721  };
722  #endif
723
724 #endif
725 #endif
726  /* end of file system group */
727
728 /*
729  * STACK_CHECKER_ON was still available in 4.9 so give a warning for now.
730  */
731 #if defined(STACK_CHECKER_ON)
732  #define CONFIGURE_STACK_CHECKER_ENABLED
733  #warning "STACK_CHECKER_ON deprecated -- use CONFIGURE_STACK_CHECKER_ENABLED"
734 #endif
735
739 #ifdef CONFIGURE_STACK_CHECKER_ENABLED
740  #define CONFIGURE_STACK_CHECKER_EXTENSION 1
741 #else
742  #define CONFIGURE_STACK_CHECKER_EXTENSION 0
743 #endif
744
775 #ifndef CONFIGURE_MAXIMUM_PRIORITY
776  #define CONFIGURE_MAXIMUM_PRIORITY PRIORITY_DEFAULT_MAXIMUM
777 #endif
778
811 #if !defined(CONFIGURE_SCHEDULER_USER) && \
812  !defined(CONFIGURE_SCHEDULER_PRIORITY) && \
813  !defined(CONFIGURE_SCHEDULER_PRIORITY_SMP) && \
814  !defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP) && \
815  !defined(CONFIGURE_SCHEDULER_SIMPLE) && \
816  !defined(CONFIGURE_SCHEDULER_SIMPLE_SMP) && \
817  !defined(CONFIGURE_SCHEDULER_EDF) && \
818  !defined(CONFIGURE_SCHEDULER_CBS)
819  #if defined(RTEMS_SMP) && defined(CONFIGURE_SMP_APPLICATION)
820
824  #define CONFIGURE_SCHEDULER_PRIORITY_SMP
825  #else
826
830  #define CONFIGURE_SCHEDULER_PRIORITY
831  #endif
832 #endif
833
834 #include <rtems/scheduler.h>
835
836 /*
837  * If the Priority Scheduler is selected, then configure for it.
838  */
839 #if defined(CONFIGURE_SCHEDULER_PRIORITY)
840  #if !defined(CONFIGURE_SCHEDULER_NAME)
841
842  #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'P', 'D', ' ')
843  #endif
844
845  #if !defined(CONFIGURE_SCHEDULER_CONTROLS)
846
847  #define CONFIGURE_SCHEDULER_CONTEXT \
848  RTEMS_SCHEDULER_CONTEXT_PRIORITY( \
849  dflt, \
850  CONFIGURE_MAXIMUM_PRIORITY + 1 \
851  )
852
854  #define CONFIGURE_SCHEDULER_CONTROLS \
855  RTEMS_SCHEDULER_CONTROL_PRIORITY(dflt, CONFIGURE_SCHEDULER_NAME)
856  #endif
857 #endif
858
859 /*
860  * If the Deterministic Priority SMP Scheduler is selected, then configure for
861  * it.
862  */
863 #if defined(CONFIGURE_SCHEDULER_PRIORITY_SMP)
864  #if !defined(CONFIGURE_SCHEDULER_NAME)
865
866  #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'D', ' ')
867  #endif
868
869  #if !defined(CONFIGURE_SCHEDULER_CONTROLS)
870
871  #define CONFIGURE_SCHEDULER_CONTEXT \
872  RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP( \
873  dflt, \
874  CONFIGURE_MAXIMUM_PRIORITY + 1 \
875  )
876
878  #define CONFIGURE_SCHEDULER_CONTROLS \
879  RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP(dflt, CONFIGURE_SCHEDULER_NAME)
880  #endif
881 #endif
882
883 /*
884  * If the Deterministic Priority Affinity SMP Scheduler is selected, then configure for
885  * it.
886  */
887 #if defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP)
888  #if !defined(CONFIGURE_SCHEDULER_NAME)
889
890  #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'A', ' ')
891  #endif
892
893  #if !defined(CONFIGURE_SCHEDULER_CONTROLS)
894
895  #define CONFIGURE_SCHEDULER_CONTEXT \
896  RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP( \
897  dflt, \
898  CONFIGURE_MAXIMUM_PRIORITY + 1 \
899  )
900
901  #define CONFIGURE_SCHEDULER_CONTROLS \
902  RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP( \
903  dflt, \
904  CONFIGURE_SCHEDULER_NAME \
905  )
906  #endif
907 #endif
908
909 /*
910  * If the Simple Priority Scheduler is selected, then configure for it.
911  */
912 #if defined(CONFIGURE_SCHEDULER_SIMPLE)
913  #if !defined(CONFIGURE_SCHEDULER_NAME)
914
915  #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'P', 'S', ' ')
916  #endif
917
918  #if !defined(CONFIGURE_SCHEDULER_CONTROLS)
919
920  #define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_SIMPLE(dflt)
921
923  #define CONFIGURE_SCHEDULER_CONTROLS \
924  RTEMS_SCHEDULER_CONTROL_SIMPLE(dflt, CONFIGURE_SCHEDULER_NAME)
925  #endif
926 #endif
927
928 /*
929  * If the Simple SMP Priority Scheduler is selected, then configure for it.
930  */
931 #if defined(CONFIGURE_SCHEDULER_SIMPLE_SMP)
932  #if !defined(CONFIGURE_SCHEDULER_NAME)
933
934  #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'S', ' ')
935  #endif
936
937  #if !defined(CONFIGURE_SCHEDULER_CONTROLS)
938
939  #define CONFIGURE_SCHEDULER_CONTEXT \
940  RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(dflt)
941
943  #define CONFIGURE_SCHEDULER_CONTROLS \
944  RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(dflt, CONFIGURE_SCHEDULER_NAME)
945  #endif
946 #endif
947
948 /*
949  * If the EDF Scheduler is selected, then configure for it.
950  */
951 #if defined(CONFIGURE_SCHEDULER_EDF)
952  #if !defined(CONFIGURE_SCHEDULER_NAME)
953
954  #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'E', 'D', 'F')
955  #endif
956
957  #if !defined(CONFIGURE_SCHEDULER_CONTROLS)
958
959  #define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_EDF(dflt)
960
962  #define CONFIGURE_SCHEDULER_CONTROLS \
963  RTEMS_SCHEDULER_CONTROL_EDF(dflt, CONFIGURE_SCHEDULER_NAME)
964  #endif
965 #endif
966
967 /*
968  * If the CBS Scheduler is selected, then configure for it.
969  */
970 #if defined(CONFIGURE_SCHEDULER_CBS)
971  #if !defined(CONFIGURE_SCHEDULER_NAME)
972
973  #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'C', 'B', 'S')
974  #endif
975
976  #if !defined(CONFIGURE_SCHEDULER_CONTROLS)
977
978  #define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_CBS(dflt)
979
981  #define CONFIGURE_SCHEDULER_CONTROLS \
982  RTEMS_SCHEDULER_CONTROL_CBS(dflt, CONFIGURE_SCHEDULER_NAME)
983  #endif
984
985  #ifndef CONFIGURE_CBS_MAXIMUM_SERVERS
986  #define CONFIGURE_CBS_MAXIMUM_SERVERS CONFIGURE_MAXIMUM_TASKS
987  #endif
988
989  #ifdef CONFIGURE_INIT
990  const uint32_t _Scheduler_CBS_Maximum_servers =
991  CONFIGURE_CBS_MAXIMUM_SERVERS;
992
994  _Scheduler_CBS_Server_list[ CONFIGURE_CBS_MAXIMUM_SERVERS ];
995  #endif
996 #endif
997
998 /*
999  * Set up the scheduler entry points table. The scheduling code uses
1000  * this code to know which scheduler is configured by the user.
1001  */
1002 #ifdef CONFIGURE_INIT
1003  #if defined(CONFIGURE_SCHEDULER_CONTEXT)
1005  #endif
1006
1009  };
1010
1011  #if defined(RTEMS_SMP)
1012  const size_t _Scheduler_Count =
1013  RTEMS_ARRAY_SIZE( _Scheduler_Table );
1014
1015  const Scheduler_Assignment _Scheduler_Assignments[] = {
1016  #if defined(CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS)
1017  CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
1018  #else
1019  #define CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT \
1020  RTEMS_SCHEDULER_ASSIGN( \
1021  0, \
1022  RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL \
1023  )
1024  CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1025  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 2
1026  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1027  #endif
1028  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 3
1029  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1030  #endif
1031  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 4
1032  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1033  #endif
1034  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 5
1035  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1036  #endif
1037  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 6
1038  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1039  #endif
1040  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 7
1041  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1042  #endif
1043  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 8
1044  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1045  #endif
1046  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 9
1047  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1048  #endif
1049  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 10
1050  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1051  #endif
1052  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 11
1053  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1054  #endif
1055  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 12
1056  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1057  #endif
1058  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 13
1059  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1060  #endif
1061  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 14
1062  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1063  #endif
1064  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 15
1065  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1066  #endif
1067  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 16
1068  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1069  #endif
1070  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 17
1071  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1072  #endif
1073  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 18
1074  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1075  #endif
1076  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 19
1077  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1078  #endif
1079  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 20
1080  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1081  #endif
1082  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 21
1083  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1084  #endif
1085  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 22
1086  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1087  #endif
1088  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 23
1089  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1090  #endif
1091  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 24
1092  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1093  #endif
1094  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 25
1095  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1096  #endif
1097  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 26
1098  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1099  #endif
1100  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 27
1101  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1102  #endif
1103  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 28
1104  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1105  #endif
1106  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 29
1107  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1108  #endif
1109  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 30
1110  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1111  #endif
1112  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 31
1113  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1114  #endif
1115  #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 32
1116  , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1117  #endif
1118  #undef CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1119  #endif
1120  };
1121
1122  RTEMS_STATIC_ASSERT(
1123  CONFIGURE_SMP_MAXIMUM_PROCESSORS
1124  == RTEMS_ARRAY_SIZE( _Scheduler_Assignments ),
1125  _Scheduler_Assignments
1126  );
1127  #endif
1128 #endif
1129  /* end of Scheduler Configuration */
1130
1141 /*
1142  * If you said the IDLE task was going to do application initialization
1143  * and didn't override the IDLE body, then something is amiss.
1144  */
1145 #if (defined(CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION) && \
1146  !defined(CONFIGURE_IDLE_TASK_BODY))
1147  #error "CONFIGURE_ERROR: You did not override the IDLE task body."
1148 #endif
1149
1158 #ifndef CONFIGURE_IDLE_TASK_BODY
1159  #if defined(BSP_IDLE_TASK_BODY)
1160  #define CONFIGURE_IDLE_TASK_BODY BSP_IDLE_TASK_BODY
1161  #elif (CPU_PROVIDES_IDLE_THREAD_BODY == TRUE)
1162  #define CONFIGURE_IDLE_TASK_BODY _CPU_Thread_Idle_body
1163  #else
1164  /* only instantiate and compile if used */
1165  #ifdef CONFIGURE_INIT
1166  void *_Thread_Idle_body(uintptr_t ignored)
1167  {
1168  for( ; ; ) ;
1169  return 0; /* to avoid warning */
1170  }
1171  #endif
1172  #define CONFIGURE_IDLE_TASK_BODY _Thread_Idle_body
1173  #endif
1174 #endif
1175  /* end of IDLE thread configuration */
1176
1188 #ifndef CONFIGURE_MINIMUM_TASK_STACK_SIZE
1189  #define CONFIGURE_MINIMUM_TASK_STACK_SIZE CPU_STACK_MINIMUM_SIZE
1190 #endif
1191
1196 #define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE \
1197  (2 * CONFIGURE_MINIMUM_TASK_STACK_SIZE)
1198
1205 #ifndef CONFIGURE_IDLE_TASK_STACK_SIZE
1206  #ifdef BSP_IDLE_TASK_STACK_SIZE
1207  #define CONFIGURE_IDLE_TASK_STACK_SIZE BSP_IDLE_TASK_STACK_SIZE
1208  #else
1209  #define CONFIGURE_IDLE_TASK_STACK_SIZE CONFIGURE_MINIMUM_TASK_STACK_SIZE
1210  #endif
1211 #endif
1212 #if CONFIGURE_IDLE_TASK_STACK_SIZE < CONFIGURE_MINIMUM_TASK_STACK_SIZE
1213  #error "CONFIGURE_IDLE_TASK_STACK_SIZE less than CONFIGURE_MINIMUM_TASK_STACK_SIZE"
1214 #endif
1215
1222 #ifndef CONFIGURE_INTERRUPT_STACK_SIZE
1223  #ifdef BSP_INTERRUPT_STACK_SIZE
1224  #define CONFIGURE_INTERRUPT_STACK_SIZE BSP_INTERRUPT_STACK_SIZE
1225  #else
1226  #define CONFIGURE_INTERRUPT_STACK_SIZE CONFIGURE_MINIMUM_TASK_STACK_SIZE
1227  #endif
1228 #endif
1229
1237 #if (CPU_ALLOCATE_INTERRUPT_STACK == 0)
1238  #define CONFIGURE_INTERRUPT_STACK_MEMORY 0
1239 #else
1240  #define CONFIGURE_INTERRUPT_STACK_MEMORY \
1241  _Configure_From_workspace( CONFIGURE_INTERRUPT_STACK_SIZE )
1242 #endif
1243
1247 #ifndef CONFIGURE_TASK_STACK_ALLOCATOR_INIT
1248  #define CONFIGURE_TASK_STACK_ALLOCATOR_INIT NULL
1249 #endif
1250
1251 /*
1252  * Configure the very much optional task stack allocator and deallocator.
1253  */
1254 #if !defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
1255  && !defined(CONFIGURE_TASK_STACK_DEALLOCATOR)
1256
1259  #define CONFIGURE_TASK_STACK_ALLOCATOR _Workspace_Allocate
1260
1263  #define CONFIGURE_TASK_STACK_DEALLOCATOR _Workspace_Free
1264 #elif (defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
1265  && !defined(CONFIGURE_TASK_STACK_DEALLOCATOR)) \
1266  || (!defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
1267  && defined(CONFIGURE_TASK_STACK_DEALLOCATOR))
1268  #error "CONFIGURE_TASK_STACK_ALLOCATOR and CONFIGURE_TASK_STACK_DEALLOCATOR must be both defined or both undefined"
1269 #endif
1270  /* end of thread/interrupt stack configuration */
1271
1281 #ifndef CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
1282  #ifdef BSP_ZERO_WORKSPACE_AUTOMATICALLY
1283  #define CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY \
1284  BSP_ZERO_WORKSPACE_AUTOMATICALLY
1285  #else
1286  #define CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY FALSE
1287  #endif
1288 #endif
1289  /* end of add to group Configuration */
1290
1298 #include <rtems/malloc.h>
1299
1300 #ifdef CONFIGURE_INIT
1301
1307  #ifdef CONFIGURE_UNIFIED_WORK_AREAS
1309  #else
1310  Heap_Control RTEMS_Malloc_Area;
1311  Heap_Control *RTEMS_Malloc_Heap = &RTEMS_Malloc_Area;
1312  #endif
1313 #endif
1314
1315 #ifdef CONFIGURE_INIT
1316
1322  const rtems_heap_extend_handler rtems_malloc_extend_handler =
1323  #ifdef CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
1325  #else
1326  rtems_heap_null_extend;
1327  #endif
1328 #endif
1329
1330 #ifdef CONFIGURE_INIT
1331
1336  rtems_malloc_dirtier_t rtems_malloc_dirty_helper =
1337  #if defined(CONFIGURE_MALLOC_DIRTY)
1339  #else
1340  NULL;
1341  #endif
1342 #endif
1343  /* end of Malloc Configuration */
1344
1358 #define _Configure_Zero_or_One(_number) ((_number) ? 1 : 0)
1359
1363 #define _Configure_Align_up(_val, _align) \
1364  (((_val) + (_align) - 1) & ~((_align) - 1))
1365
1372 #define _Configure_From_workspace(_size) \
1373  (ssize_t) (_Configure_Zero_or_One(_size) * \
1374  _Configure_Align_up((_size) + HEAP_BLOCK_HEADER_SIZE, CPU_HEAP_ALIGNMENT))
1375
1381 #ifdef CONFIGURE_TASK_STACK_FROM_ALLOCATOR
1382  #define _Configure_From_stackspace(_stack_size) \
1383  CONFIGURE_TASK_STACK_FROM_ALLOCATOR(_stack_size)
1384 #else
1385  #define _Configure_From_stackspace(_stack_size) \
1386  _Configure_From_workspace(_stack_size)
1387 #endif
1388
1393 #define _Configure_Max_Objects(_max) \
1394  (_Configure_Zero_or_One(_max) * rtems_resource_maximum_per_allocation(_max))
1395
1403 #define _Configure_Object_RAM(_number, _size) ( \
1404  _Configure_From_workspace(_Configure_Max_Objects(_number) * (_size)) + \
1405  _Configure_From_workspace( \
1406  _Configure_Zero_or_One(_number) * ( \
1407  (_Configure_Max_Objects(_number) + 1) * sizeof(Objects_Control *) + \
1408  _Configure_Align_up(sizeof(void *), CPU_ALIGNMENT) + \
1409  _Configure_Align_up(sizeof(uint32_t), CPU_ALIGNMENT) \
1410  ) \
1411  ) \
1412  )
1413
1426 #ifdef CONFIGURE_RTEMS_INIT_TASKS_TABLE
1427
1428 #ifdef CONFIGURE_HAS_OWN_INIT_TASK_TABLE
1429
1430 /*
1431  * The user is defining their own table information and setting the
1432  * appropriate variables.
1433  */
1434
1435 #else
1436
1441 #ifndef CONFIGURE_INIT_TASK_NAME
1442  #define CONFIGURE_INIT_TASK_NAME rtems_build_name('U', 'I', '1', ' ')
1443 #endif
1444
1449 #ifndef CONFIGURE_INIT_TASK_STACK_SIZE
1450  #define CONFIGURE_INIT_TASK_STACK_SIZE CONFIGURE_MINIMUM_TASK_STACK_SIZE
1451 #endif
1452
1457 #ifndef CONFIGURE_INIT_TASK_PRIORITY
1458  #define CONFIGURE_INIT_TASK_PRIORITY 1
1459 #endif
1460
1465 #ifndef CONFIGURE_INIT_TASK_ATTRIBUTES
1466  #define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
1467 #endif
1468
1473 #ifndef CONFIGURE_INIT_TASK_ENTRY_POINT
1474  #ifdef __cplusplus
1475  extern "C" {
1476  #endif
1478  #ifdef __cplusplus
1479  }
1480  #endif
1481  #define CONFIGURE_INIT_TASK_ENTRY_POINT Init
1482  extern const char* bsp_boot_cmdline;
1483  #define CONFIGURE_INIT_TASK_ARGUMENTS ((rtems_task_argument) &bsp_boot_cmdline)
1484 #endif
1485
1490 #ifndef CONFIGURE_INIT_TASK_INITIAL_MODES
1491  #if defined(RTEMS_SMP) && defined(CONFIGURE_SMP_APPLICATION)
1492  #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
1493  #else
1494  #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT
1495  #endif
1496 #endif
1497
1502 #ifndef CONFIGURE_INIT_TASK_ARGUMENTS
1503  #define CONFIGURE_INIT_TASK_ARGUMENTS 0
1504 #endif
1505
1506 #ifdef CONFIGURE_INIT
1507  rtems_initialization_tasks_table Initialization_tasks[] = {
1508  { CONFIGURE_INIT_TASK_NAME,
1510  CONFIGURE_INIT_TASK_PRIORITY,
1511  CONFIGURE_INIT_TASK_ATTRIBUTES,
1512  CONFIGURE_INIT_TASK_ENTRY_POINT,
1513  CONFIGURE_INIT_TASK_INITIAL_MODES,
1514  CONFIGURE_INIT_TASK_ARGUMENTS
1515  }
1516  };
1517 #endif
1518
1524 #define CONFIGURE_INIT_TASK_TABLE Initialization_tasks
1525
1531 #define CONFIGURE_INIT_TASK_TABLE_SIZE \
1532  RTEMS_ARRAY_SIZE(CONFIGURE_INIT_TASK_TABLE)
1533
1534 #endif /* CONFIGURE_HAS_OWN_INIT_TASK_TABLE */
1535
1536 #else /* CONFIGURE_RTEMS_INIT_TASKS_TABLE */
1537
1543 #define CONFIGURE_INIT_TASK_TABLE NULL
1544
1550 #define CONFIGURE_INIT_TASK_TABLE_SIZE 0
1551
1557 #define CONFIGURE_INIT_TASK_STACK_SIZE 0
1558
1559 #endif
1560  /* end of Classic API Initialization Tasks Table */
1561
1578 #define NULL_DRIVER_TABLE_ENTRY \
1579  { NULL, NULL, NULL, NULL, NULL, NULL }
1580
1581 #ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
1582  #include <rtems/console.h>
1583 #endif
1584
1585 #ifdef CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
1586  #include <rtems/clockdrv.h>
1587 #endif
1588
1589 #ifdef CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
1590  #include <rtems/btimer.h>
1591 #endif
1592
1593 #ifdef CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
1594  #include <rtems/rtc.h>
1595 #endif
1596
1597 #ifdef CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
1598  #include <rtems/watchdogdrv.h>
1599 #endif
1600
1601 #ifdef CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
1602  #include <rtems/framebuffer.h>
1603 #endif
1604
1605 #ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
1606  #include <rtems/devnull.h>
1607 #endif
1608
1609 #ifdef CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
1610  #include <rtems/devzero.h>
1611 #endif
1612
1613 #ifdef CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
1614  /* the ide driver needs the ATA driver */
1615  #ifndef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
1616  #define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
1617  #endif
1618  #include <libchip/ide_ctrl.h>
1619 #endif
1620
1621 #ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
1622  #include <libchip/ata.h>
1623 #endif
1624
1625 #ifndef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
1626
1632 #ifndef CONFIGURE_MAXIMUM_DRIVERS
1633  #define CONFIGURE_MAXIMUM_DRIVERS
1634 #endif
1635
1636 #ifdef CONFIGURE_INIT
1638  _IO_Driver_address_table[ CONFIGURE_MAXIMUM_DRIVERS ] = {
1639  #ifdef CONFIGURE_BSP_PREREQUISITE_DRIVERS
1640  CONFIGURE_BSP_PREREQUISITE_DRIVERS,
1641  #endif
1642  #ifdef CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
1643  CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS,
1644  #endif
1645  #ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
1647  #endif
1648  #ifdef CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
1649  CLOCK_DRIVER_TABLE_ENTRY,
1650  #endif
1651  #ifdef CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
1653  #endif
1654  #ifdef CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
1656  #endif
1657  #ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
1658  DEVNULL_DRIVER_TABLE_ENTRY,
1659  #endif
1660  #ifdef CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
1661  DEVZERO_DRIVER_TABLE_ENTRY,
1662  #endif
1663  #ifdef CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
1664  IDE_CONTROLLER_DRIVER_TABLE_ENTRY,
1665  #endif
1666  #ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
1667  ATA_DRIVER_TABLE_ENTRY,
1668  #endif
1669  #ifdef CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
1671  #endif
1672  #ifdef CONFIGURE_APPLICATION_EXTRA_DRIVERS
1673  CONFIGURE_APPLICATION_EXTRA_DRIVERS,
1674  #endif
1675  #ifdef CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
1677  #elif !defined(CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER) && \
1678  !defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) && \
1679  !defined(CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER) && \
1680  !defined(CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER) && \
1681  !defined(CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER) && \
1682  !defined(CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER) && \
1683  !defined(CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER) && \
1684  !defined(CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER) && \
1685  !defined(CONFIGURE_APPLICATION_EXTRA_DRIVERS)
1687  #endif
1688  };
1689
1690  const size_t _IO_Number_of_drivers =
1691  RTEMS_ARRAY_SIZE( _IO_Driver_address_table );
1692 #endif
1693
1694 #endif /* CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE */
1695
1696 #ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
1697  /*
1698  * configure the priority of the ATA driver task
1699  */
1700  #ifndef CONFIGURE_ATA_DRIVER_TASK_PRIORITY
1701  #define CONFIGURE_ATA_DRIVER_TASK_PRIORITY ATA_DRIVER_TASK_DEFAULT_PRIORITY
1702  #endif
1703  #ifdef CONFIGURE_INIT
1704  rtems_task_priority rtems_ata_driver_task_priority
1705  = CONFIGURE_ATA_DRIVER_TASK_PRIORITY;
1706  #endif /* CONFIGURE_INIT */
1707 #endif
1708  /* end of Device Driver Table Configuration */
1709
1720 #ifdef CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
1721  #include <rtems/bdbuf.h>
1722  /*
1723  * configure the bdbuf cache parameters
1724  */
1725  #ifndef CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
1726  #define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS \
1727  RTEMS_BDBUF_MAX_READ_AHEAD_BLOCKS_DEFAULT
1728  #endif
1729  #ifndef CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
1730  #define CONFIGURE_BDBUF_MAX_WRITE_BLOCKS \
1731  RTEMS_BDBUF_MAX_WRITE_BLOCKS_DEFAULT
1732  #endif
1733  #ifndef CONFIGURE_SWAPOUT_TASK_PRIORITY
1734  #define CONFIGURE_SWAPOUT_TASK_PRIORITY \
1735  RTEMS_BDBUF_SWAPOUT_TASK_PRIORITY_DEFAULT
1736  #endif
1737  #ifndef CONFIGURE_SWAPOUT_SWAP_PERIOD
1738  #define CONFIGURE_SWAPOUT_SWAP_PERIOD \
1739  RTEMS_BDBUF_SWAPOUT_TASK_SWAP_PERIOD_DEFAULT
1740  #endif
1741  #ifndef CONFIGURE_SWAPOUT_BLOCK_HOLD
1742  #define CONFIGURE_SWAPOUT_BLOCK_HOLD \
1743  RTEMS_BDBUF_SWAPOUT_TASK_BLOCK_HOLD_DEFAULT
1744  #endif
1745  #ifndef CONFIGURE_SWAPOUT_WORKER_TASKS
1746  #define CONFIGURE_SWAPOUT_WORKER_TASKS \
1747  RTEMS_BDBUF_SWAPOUT_WORKER_TASKS_DEFAULT
1748  #endif
1749  #ifndef CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
1750  #define CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY \
1751  RTEMS_BDBUF_SWAPOUT_WORKER_TASK_PRIORITY_DEFAULT
1752  #endif
1753  #ifndef CONFIGURE_BDBUF_TASK_STACK_SIZE
1754  #define CONFIGURE_BDBUF_TASK_STACK_SIZE \
1755  RTEMS_BDBUF_TASK_STACK_SIZE_DEFAULT
1756  #endif
1757  #ifndef CONFIGURE_BDBUF_CACHE_MEMORY_SIZE
1758  #define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE \
1759  RTEMS_BDBUF_CACHE_MEMORY_SIZE_DEFAULT
1760  #endif
1761  #ifndef CONFIGURE_BDBUF_BUFFER_MIN_SIZE
1762  #define CONFIGURE_BDBUF_BUFFER_MIN_SIZE \
1763  RTEMS_BDBUF_BUFFER_MIN_SIZE_DEFAULT
1764  #endif
1765  #ifndef CONFIGURE_BDBUF_BUFFER_MAX_SIZE
1766  #define CONFIGURE_BDBUF_BUFFER_MAX_SIZE \
1767  RTEMS_BDBUF_BUFFER_MAX_SIZE_DEFAULT
1768  #endif
1769  #ifndef CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
1770  #define CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY \
1771  RTEMS_BDBUF_READ_AHEAD_TASK_PRIORITY_DEFAULT
1772  #endif
1773  #ifdef CONFIGURE_INIT
1775  CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS,
1776  CONFIGURE_BDBUF_MAX_WRITE_BLOCKS,
1777  CONFIGURE_SWAPOUT_TASK_PRIORITY,
1778  CONFIGURE_SWAPOUT_SWAP_PERIOD,
1779  CONFIGURE_SWAPOUT_BLOCK_HOLD,
1780  CONFIGURE_SWAPOUT_WORKER_TASKS,
1781  CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY,
1782  CONFIGURE_BDBUF_TASK_STACK_SIZE,
1783  CONFIGURE_BDBUF_CACHE_MEMORY_SIZE,
1784  CONFIGURE_BDBUF_BUFFER_MIN_SIZE,
1785  CONFIGURE_BDBUF_BUFFER_MAX_SIZE,
1786  CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
1787  };
1788  #endif
1789
1790  #define CONFIGURE_LIBBLOCK_TASKS \
1791  (1 + CONFIGURE_SWAPOUT_WORKER_TASKS + \
1792  (CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS != 0))
1793
1794  #define CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS \
1795  (CONFIGURE_LIBBLOCK_TASKS * \
1796  (CONFIGURE_BDBUF_TASK_STACK_SIZE <= CONFIGURE_MINIMUM_TASK_STACK_SIZE ? \
1797  0 : CONFIGURE_BDBUF_TASK_STACK_SIZE - CONFIGURE_MINIMUM_TASK_STACK_SIZE))
1798
1799  #ifdef RTEMS_BDBUF_USE_PTHREAD
1800  /*
1801  * Semaphores:
1802  * o disk lock
1803  */
1804  #define CONFIGURE_LIBBLOCK_SEMAPHORES 1
1805
1806  /*
1807  * POSIX Mutexes:
1808  * o bdbuf lock
1809  * o bdbuf sync lock
1810  */
1811  #define CONFIGURE_LIBBLOCK_POSIX_MUTEXES 2
1812
1813  /*
1814  * POSIX Condition Variables:
1815  * o bdbuf access condition
1816  * o bdbuf transfer condition
1817  * o bdbuf buffer condition
1818  */
1819  #define CONFIGURE_LIBBLOCK_POSIX_CONDITION_VARIABLES 3
1820  #else
1821  /*
1822  * Semaphores:
1823  * o disk lock
1824  * o bdbuf lock
1825  * o bdbuf sync lock
1826  * o bdbuf access condition
1827  * o bdbuf transfer condition
1828  * o bdbuf buffer condition
1829  */
1830  #define CONFIGURE_LIBBLOCK_SEMAPHORES 6
1831
1832  #define CONFIGURE_LIBBLOCK_POSIX_MUTEXES 0
1833  #define CONFIGURE_LIBBLOCK_POSIX_CONDITION_VARIABLES 0
1834  #endif
1835
1836  #if defined(CONFIGURE_HAS_OWN_BDBUF_TABLE) || \
1837  defined(CONFIGURE_BDBUF_BUFFER_SIZE) || \
1838  defined(CONFIGURE_BDBUF_BUFFER_COUNT)
1839  #error BDBUF Cache does not use a buffer configuration table. Please remove.
1840  #endif
1841 #else
1842
1843  #define CONFIGURE_LIBBLOCK_TASKS 0
1844
1845  #define CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS 0
1846
1847  #define CONFIGURE_LIBBLOCK_SEMAPHORES 0
1848
1849  #define CONFIGURE_LIBBLOCK_POSIX_MUTEXES 0
1850
1854  #define CONFIGURE_LIBBLOCK_POSIX_CONDITION_VARIABLES 0
1855 #endif /* CONFIGURE_APPLICATION_NEEDS_LIBBLOCK */
1856
1875 #ifndef CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
1876  #define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK 0
1877 #endif
1878
1883 #ifndef CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER
1884  #define CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER 0
1885 #endif
1886
1887
1888 #if defined(RTEMS_MULTIPROCESSING)
1889  /*
1890  * Default Multiprocessing Configuration Table. The defaults are
1891  * appropriate for most of the RTEMS Multiprocessor Test Suite. Each
1892  * value may be overridden within each test to customize the environment.
1893  */
1894
1895  #ifdef CONFIGURE_MP_APPLICATION
1896  #define CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER 1
1897
1898  #ifndef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
1899
1900  #ifndef CONFIGURE_MP_NODE_NUMBER
1901  #define CONFIGURE_MP_NODE_NUMBER NODE_NUMBER
1902  #endif
1903
1904  #ifndef CONFIGURE_MP_MAXIMUM_NODES
1905  #define CONFIGURE_MP_MAXIMUM_NODES 2
1906  #endif
1907
1908  #ifndef CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
1909  #define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS 32
1910  #endif
1911  #define CONFIGURE_MEMORY_FOR_GLOBAL_OBJECTS(_global_objects) \
1912  _Configure_Object_RAM((_global_objects), sizeof(Objects_MP_Control))
1913
1914  #ifndef CONFIGURE_MP_MAXIMUM_PROXIES
1915  #define CONFIGURE_MP_MAXIMUM_PROXIES 32
1916  #endif
1917  #define CONFIGURE_MEMORY_FOR_PROXIES(_proxies) \
1918  _Configure_Object_RAM((_proxies) + 1, sizeof(Thread_Proxy_control) )
1919
1920  #ifndef CONFIGURE_MP_MPCI_TABLE_POINTER
1921  #include <mpci.h>
1922  #define CONFIGURE_MP_MPCI_TABLE_POINTER &MPCI_table
1923  #endif
1924
1925  #ifdef CONFIGURE_INIT
1926  rtems_multiprocessing_table Multiprocessing_configuration = {
1927  CONFIGURE_MP_NODE_NUMBER, /* local node number */
1928  CONFIGURE_MP_MAXIMUM_NODES, /* maximum # nodes */
1929  CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS, /* maximum # global objects */
1930  CONFIGURE_MP_MAXIMUM_PROXIES, /* maximum # proxies */
1931  CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK, /* MPCI stack > minimum */
1932  CONFIGURE_MP_MPCI_TABLE_POINTER /* ptr to MPCI config table */
1933  };
1934  #endif
1935
1936  #define CONFIGURE_MULTIPROCESSING_TABLE &Multiprocessing_configuration
1937
1938  #endif /* CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE */
1939
1940  #else
1941
1942  #define CONFIGURE_MULTIPROCESSING_TABLE NULL
1943
1944  #endif /* CONFIGURE_MP_APPLICATION */
1945 #endif /* RTEMS_MULTIPROCESSING */
1946  /* end of Multiprocessing Configuration */
1947
1952 #if defined(CONFIGURE_UNLIMITED_OBJECTS)
1953  #if !defined(CONFIGURE_UNIFIED_WORK_AREAS) && \
1954  !defined(CONFIGURE_EXECUTIVE_RAM_SIZE) && \
1955  !defined(CONFIGURE_MEMORY_OVERHEAD)
1956  #error "CONFIGURE_UNLIMITED_OBJECTS requires a unified work area, an executive RAM size, or a defined workspace memory overhead"
1957  #endif
1958
1959  #if !defined(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
1960
1964  #define CONFIGURE_UNLIMITED_ALLOCATION_SIZE 8
1965  #endif
1966  #if !defined(CONFIGURE_MAXIMUM_TASKS)
1967  #define CONFIGURE_MAXIMUM_TASKS \
1968  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
1969  #endif
1970  #if !defined(CONFIGURE_MAXIMUM_TIMERS)
1971  #define CONFIGURE_MAXIMUM_TIMERS \
1972  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
1973  #endif
1974  #if !defined(CONFIGURE_MAXIMUM_SEMAPHORES)
1975  #define CONFIGURE_MAXIMUM_SEMAPHORES \
1976  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
1977  #endif
1978  #if !defined(CONFIGURE_MAXIMUM_MESSAGE_QUEUES)
1979  #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES \
1980  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
1981  #endif
1982  #if !defined(CONFIGURE_MAXIMUM_PARTITIONS)
1983  #define CONFIGURE_MAXIMUM_PARTITIONS \
1984  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
1985  #endif
1986  #if !defined(CONFIGURE_MAXIMUM_REGIONS)
1987  #define CONFIGURE_MAXIMUM_REGIONS \
1988  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
1989  #endif
1990  #if !defined(CONFIGURE_MAXIMUM_PORTS)
1991  #define CONFIGURE_MAXIMUM_PORTS \
1992  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
1993  #endif
1994  #if !defined(CONFIGURE_MAXIMUM_PERIODS)
1995  #define CONFIGURE_MAXIMUM_PERIODS \
1996  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
1997  #endif
1998  #if !defined(CONFIGURE_MAXIMUM_BARRIERS)
1999  #define CONFIGURE_MAXIMUM_BARRIERS \
2000  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
2001  #endif
2002  #if !defined(CONFIGURE_MAXIMUM_POSIX_KEYS)
2003  #define CONFIGURE_MAXIMUM_POSIX_KEYS \
2004  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
2005  #endif
2006  #if !defined(CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS)
2007  #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS \
2008  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
2009  #endif
2010
2011  #ifdef RTEMS_POSIX_API
2012  #if !defined(CONFIGURE_MAXIMUM_POSIX_THREADS)
2013  #define CONFIGURE_MAXIMUM_POSIX_THREADS \
2014  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
2015  #endif
2016  #if !defined(CONFIGURE_MAXIMUM_POSIX_MUTEXES)
2017  #define CONFIGURE_MAXIMUM_POSIX_MUTEXES \
2018  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
2019  #endif
2020  #if !defined(CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES)
2021  #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES \
2022  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
2023  #endif
2024  #if !defined(CONFIGURE_MAXIMUM_POSIX_TIMERS)
2025  #define CONFIGURE_MAXIMUM_POSIX_TIMERS \
2026  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
2027  #endif
2028 /*
2029  #if !defined(CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS)
2030  #define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS \
2031  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
2032  #endif
2033 */
2034  #if !defined(CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES)
2035  #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES \
2036  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
2037  #endif
2038  #if !defined(CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS)
2039  #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS \
2040  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
2041  #endif
2042  #if !defined(CONFIGURE_MAXIMUM_POSIX_SEMAPHORES)
2043  #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES \
2044  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
2045  #endif
2046  #if !defined(CONFIGURE_MAXIMUM_POSIX_BARRIERS)
2047  #define CONFIGURE_MAXIMUM_POSIX_BARRIERS \
2048  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
2049  #endif
2050  #if !defined(CONFIGURE_MAXIMUM_POSIX_RWLOCKS)
2051  #define CONFIGURE_MAXIMUM_POSIX_RWLOCKS \
2052  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
2053  #endif
2054  #if !defined(CONFIGURE_MAXIMUM_POSIX_SPINLOCKS)
2055  #define CONFIGURE_MAXIMUM_POSIX_SPINLOCKS \
2056  rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
2057  #endif
2058  #endif /* RTEMS_POSIX_API */
2059 #endif /* CONFIGURE_UNLIMITED_OBJECTS */
2060
2061
2071 #ifndef CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
2072
2074  #ifndef CONFIGURE_MAXIMUM_TASKS
2075  #define CONFIGURE_MAXIMUM_TASKS 0
2076  #endif
2077
2084  #define CONFIGURE_TASKS \
2085  (CONFIGURE_MAXIMUM_TASKS + CONFIGURE_LIBBLOCK_TASKS)
2086
2087  /*
2088  * Classic API notepads are a deprecated feature and will be removed
2089  * in a future release of RTEMS. Warn the user who uses them.
2090  */
2091  #if defined(CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS)
2092  #warning "Classic API Notepads are deprecated and will be removed."
2093  #endif
2094  #if defined(CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS)
2095  #warning "Classic API Notepads are deprecated and will be removed."
2096  #endif
2097
2099  #ifdef CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS
2100  #define CONFIGURE_NOTEPADS_ENABLED TRUE
2101  #else
2102  #define CONFIGURE_NOTEPADS_ENABLED FALSE
2103  #endif
2104
2115  #if defined(RTEMS_SMP)
2116  #ifdef CONFIGURE_MAXIMUM_TASK_VARIABLES
2117  #warning "Per-Task Variables are deprecated and will be removed."
2118  #error "Per-Task Variables are not safe for SMP systems and disabled."
2119  #endif
2120  #define CONFIGURE_MAXIMUM_TASK_VARIABLES 0
2121  #define CONFIGURE_MEMORY_FOR_TASK_VARIABLES(_task_variables) 0
2122  #else
2123  #ifndef CONFIGURE_MAXIMUM_TASK_VARIABLES
2124
2125  #define CONFIGURE_MAXIMUM_TASK_VARIABLES 0
2126
2132  #define CONFIGURE_MEMORY_FOR_TASK_VARIABLES(_task_variables) 0
2133  #else
2134  #warning "Per-Task Variables are deprecated and will be removed."
2135  #define CONFIGURE_MEMORY_FOR_TASK_VARIABLES(_task_variables) \
2136  (_task_variables) * \
2137  _Configure_From_workspace(sizeof(rtems_task_variable_t))
2138  #endif
2139  #endif
2140
2141  #ifndef CONFIGURE_MAXIMUM_TIMERS
2142
2143  #define CONFIGURE_MAXIMUM_TIMERS 0
2144
2150  #define CONFIGURE_MEMORY_FOR_TIMERS(_timers) 0
2151  #else
2152  #define CONFIGURE_MEMORY_FOR_TIMERS(_timers) \
2153  _Configure_Object_RAM(_timers, sizeof(Timer_Control) )
2154  #endif
2155
2156  #ifndef CONFIGURE_MAXIMUM_SEMAPHORES
2157
2158  #define CONFIGURE_MAXIMUM_SEMAPHORES 0
2159  #endif
2160
2166  #ifdef RTEMS_NETWORKING
2167  #define CONFIGURE_NETWORKING_SEMAPHORES 1
2168  #else
2169  #define CONFIGURE_NETWORKING_SEMAPHORES 0
2170  #endif
2171
2179  #define CONFIGURE_SEMAPHORES \
2180  (CONFIGURE_MAXIMUM_SEMAPHORES + CONFIGURE_LIBIO_SEMAPHORES + \
2181  CONFIGURE_TERMIOS_SEMAPHORES + CONFIGURE_LIBBLOCK_SEMAPHORES + \
2182  CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS + \
2183  CONFIGURE_NETWORKING_SEMAPHORES + CONFIGURE_DRVMGR_SEMAPHORES)
2184
2192  #if !defined(RTEMS_SMP) || \
2193  !defined(CONFIGURE_MAXIMUM_MRSP_SEMAPHORES)
2194  #define CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES 0
2195  #else
2196  #define CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES \
2197  CONFIGURE_MAXIMUM_MRSP_SEMAPHORES * \
2198  _Configure_From_workspace( \
2199  RTEMS_ARRAY_SIZE(_Scheduler_Table) * sizeof(Priority_Control) \
2200  )
2201  #endif
2202
2212  #if CONFIGURE_SEMAPHORES == 0
2213  #define CONFIGURE_MEMORY_FOR_SEMAPHORES(_semaphores) 0
2214  #else
2215  #define CONFIGURE_MEMORY_FOR_SEMAPHORES(_semaphores) \
2216  _Configure_Object_RAM(_semaphores, sizeof(Semaphore_Control) ) + \
2217  CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES
2218  #endif
2219
2220  #ifndef CONFIGURE_MAXIMUM_MESSAGE_QUEUES
2221
2225  #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 0
2226
2232  #define CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(_queues) 0
2233  #else
2234  #define CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(_queues) \
2235  _Configure_Object_RAM(_queues, sizeof(Message_queue_Control) )
2236  #endif
2237
2238  #ifndef CONFIGURE_MAXIMUM_PARTITIONS
2239
2243  #define CONFIGURE_MAXIMUM_PARTITIONS 0
2244
2250  #define CONFIGURE_MEMORY_FOR_PARTITIONS(_partitions) 0
2251  #else
2252  #define CONFIGURE_MEMORY_FOR_PARTITIONS(_partitions) \
2253  _Configure_Object_RAM(_partitions, sizeof(Partition_Control) )
2254  #endif
2255
2256  #ifndef CONFIGURE_MAXIMUM_REGIONS
2257
2261  #define CONFIGURE_MAXIMUM_REGIONS 0
2262
2268  #define CONFIGURE_MEMORY_FOR_REGIONS(_regions) 0
2269  #else
2270  #define CONFIGURE_MEMORY_FOR_REGIONS(_regions) \
2271  _Configure_Object_RAM(_regions, sizeof(Region_Control) )
2272  #endif
2273
2274  #ifndef CONFIGURE_MAXIMUM_PORTS
2275
2279  #define CONFIGURE_MAXIMUM_PORTS 0
2280
2286  #define CONFIGURE_MEMORY_FOR_PORTS(_ports) 0
2287  #else
2288  #define CONFIGURE_MEMORY_FOR_PORTS(_ports) \
2289  _Configure_Object_RAM(_ports, sizeof(Dual_ported_memory_Control) )
2290  #endif
2291
2292  #ifndef CONFIGURE_MAXIMUM_PERIODS
2293
2297  #define CONFIGURE_MAXIMUM_PERIODS 0
2298
2304  #define CONFIGURE_MEMORY_FOR_PERIODS(_periods) 0
2305 #else
2306  #define CONFIGURE_MEMORY_FOR_PERIODS(_periods) \
2307  _Configure_Object_RAM(_periods, sizeof(Rate_monotonic_Control) )
2308  #endif
2309
2314  #ifndef CONFIGURE_MAXIMUM_BARRIERS
2315  #define CONFIGURE_MAXIMUM_BARRIERS 0
2316  #endif
2317
2324  #define CONFIGURE_BARRIERS \
2325  (CONFIGURE_MAXIMUM_BARRIERS + CONFIGURE_BARRIERS_FOR_FIFOS)
2326
2333  #if CONFIGURE_BARRIERS == 0
2334  #define CONFIGURE_MEMORY_FOR_BARRIERS(_barriers) 0
2335  #else
2336  #define CONFIGURE_MEMORY_FOR_BARRIERS(_barriers) \
2337  _Configure_Object_RAM(_barriers, sizeof(Barrier_Control) )
2338  #endif
2339
2340  #ifndef CONFIGURE_MAXIMUM_USER_EXTENSIONS
2341
2345  #define CONFIGURE_MAXIMUM_USER_EXTENSIONS 0
2346
2352  #define CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(_extensions) 0
2353  #else
2354  #define CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(_extensions) \
2355  _Configure_Object_RAM(_extensions, sizeof(Extension_Control) )
2356  #endif
2357  /* end of Classic API Configuration */
2358
2370  #ifndef CONFIGURE_MICROSECONDS_PER_TICK
2371  #define CONFIGURE_MICROSECONDS_PER_TICK \
2372  RTEMS_MILLISECONDS_TO_MICROSECONDS(10)
2373  #endif
2374
2376  #ifndef CONFIGURE_TICKS_PER_TIMESLICE
2377  #define CONFIGURE_TICKS_PER_TIMESLICE 50
2378  #endif
2379  /* end of General Configuration */
2381
2382 /*
2383  * Initial Extension Set
2384  */
2385
2386 #ifdef CONFIGURE_INIT
2387 #ifdef CONFIGURE_STACK_CHECKER_ENABLED
2388 #include <rtems/stackchk.h>
2389 #endif
2390 #include <rtems/libcsupport.h>
2391
2392 #if defined(BSP_INITIAL_EXTENSION) || \
2393  defined(CONFIGURE_INITIAL_EXTENSIONS) || \
2394  defined(CONFIGURE_STACK_CHECKER_ENABLED) || \
2395  (defined(RTEMS_NEWLIB) && !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY))
2396  static const rtems_extensions_table Configuration_Initial_Extensions[] = {
2397  #if !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY)
2398  RTEMS_NEWLIB_EXTENSION,
2399  #endif
2400  #if defined(CONFIGURE_STACK_CHECKER_ENABLED)
2402  #endif
2403  #if defined(CONFIGURE_INITIAL_EXTENSIONS)
2404  CONFIGURE_INITIAL_EXTENSIONS,
2405  #endif
2406  #if defined(BSP_INITIAL_EXTENSION)
2407  BSP_INITIAL_EXTENSION
2408  #endif
2409  };
2410
2411  #define CONFIGURE_INITIAL_EXTENSION_TABLE Configuration_Initial_Extensions
2412  #define CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS \
2413  RTEMS_ARRAY_SIZE(Configuration_Initial_Extensions)
2414 #else
2415  #define CONFIGURE_INITIAL_EXTENSION_TABLE NULL
2416  #define CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS 0
2417 #endif
2418
2419 #if defined(RTEMS_NEWLIB) && defined(__DYNAMIC_REENT__)
2420  struct _reent *__getreent(void)
2421  {
2422  #ifdef CONFIGURE_DISABLE_NEWLIB_REENTRANCY
2423  return _GLOBAL_REENT;
2424  #else
2426  #endif
2427  }
2428 #endif
2429
2430 #endif
2431
2440 #include <rtems/posix/key.h>
2441
2448 #ifndef CONFIGURE_MAXIMUM_POSIX_KEYS
2449  #define CONFIGURE_MAXIMUM_POSIX_KEYS 0
2450 #endif
2451
2458 #ifndef CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
2459  #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS \
2460  (CONFIGURE_MAXIMUM_POSIX_KEYS * \
2461  (CONFIGURE_MAXIMUM_POSIX_THREADS + CONFIGURE_MAXIMUM_TASKS))
2462 #endif
2463
2471 #define CONFIGURE_POSIX_KEYS \
2472  (CONFIGURE_MAXIMUM_POSIX_KEYS + CONFIGURE_LIBIO_POSIX_KEYS)
2473
2480 #define CONFIGURE_MEMORY_FOR_POSIX_KEYS(_keys, _key_value_pairs) \
2481  (_Configure_Object_RAM(_keys, sizeof(POSIX_Keys_Control) ) \
2482  + _Configure_From_workspace( \
2483  _Configure_Max_Objects(_key_value_pairs) \
2484  * sizeof(POSIX_Keys_Key_value_pair)))
2485
2486 /*
2487  * The rest of the POSIX threads API features are only available when
2488  * POSIX is enabled.
2489  */
2490 #ifdef RTEMS_POSIX_API
2491  #include <sys/types.h>
2492  #include <signal.h>
2493  #include <limits.h>
2494  #include <mqueue.h>
2495  #include <rtems/posix/barrier.h>
2496  #include <rtems/posix/cond.h>
2497  #include <rtems/posix/mqueue.h>
2498  #include <rtems/posix/mutex.h>
2499  #include <rtems/posix/psignal.h>
2500  #include <rtems/posix/pthread.h>
2501  #include <rtems/posix/rwlock.h>
2502  #include <rtems/posix/semaphore.h>
2503  #include <rtems/posix/spinlock.h>
2504  #include <rtems/posix/threadsup.h>
2505  #include <rtems/posix/timer.h>
2506
2513  #define _Configure_POSIX_Named_Object_RAM(_number, _size) \
2514  _Configure_Object_RAM( (_number), _size ) + \
2515  (_Configure_Max_Objects(_number) * _Configure_From_workspace(NAME_MAX) )
2516
2521  #ifndef CONFIGURE_MAXIMUM_POSIX_THREADS
2522  #define CONFIGURE_MAXIMUM_POSIX_THREADS 0
2523  #endif
2524
2529  #ifndef CONFIGURE_MAXIMUM_POSIX_MUTEXES
2530  #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 0
2531  #endif
2532
2539  #define CONFIGURE_MEMORY_FOR_POSIX_MUTEXES(_mutexes) \
2540  _Configure_Object_RAM(_mutexes, sizeof(POSIX_Mutex_Control) )
2541
2546  #ifndef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
2547  #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 0
2548  #endif
2549
2556  #define CONFIGURE_MEMORY_FOR_POSIX_CONDITION_VARIABLES(_condvars) \
2557  _Configure_Object_RAM(_condvars, \
2558  sizeof(POSIX_Condition_variables_Control) )
2559
2564  #ifndef CONFIGURE_MAXIMUM_POSIX_TIMERS
2565  #define CONFIGURE_MAXIMUM_POSIX_TIMERS 0
2566  #endif
2567
2574  #define CONFIGURE_MEMORY_FOR_POSIX_TIMERS(_timers) \
2575  _Configure_Object_RAM(_timers, sizeof(POSIX_Timer_Control) )
2576
2581  #ifndef CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
2582  #define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 0
2583  #endif
2584
2591  #define CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS(_queued_signals) \
2592  _Configure_From_workspace( \
2593  (_queued_signals) * (sizeof(POSIX_signals_Siginfo_node)) )
2594
2599  #ifndef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
2600  #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 0
2601  #endif
2602
2609  #ifndef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
2610  #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS \
2611  CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
2612  #endif
2613
2620  #define CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUES(_message_queues) \
2621  _Configure_POSIX_Named_Object_RAM( \
2622  _message_queues, sizeof(POSIX_Message_queue_Control) )
2623
2630  #define CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUE_DESCRIPTORS(_mqueue_fds) \
2631  _Configure_Object_RAM( \
2632  _mqueue_fds, sizeof(POSIX_Message_queue_Control_fd) )
2633
2638  #ifndef CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
2639  #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 0
2640  #endif
2641
2648  #define CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES(_semaphores) \
2649  _Configure_POSIX_Named_Object_RAM( \
2650  _semaphores, sizeof(POSIX_Semaphore_Control) )
2651
2656  #ifndef CONFIGURE_MAXIMUM_POSIX_BARRIERS
2657  #define CONFIGURE_MAXIMUM_POSIX_BARRIERS 0
2658  #endif
2659
2666  #define CONFIGURE_MEMORY_FOR_POSIX_BARRIERS(_barriers) \
2667  _Configure_Object_RAM(_barriers, sizeof(POSIX_Barrier_Control) )
2668
2673  #ifndef CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
2674  #define CONFIGURE_MAXIMUM_POSIX_SPINLOCKS 0
2675  #endif
2676
2683  #define CONFIGURE_MEMORY_FOR_POSIX_SPINLOCKS(_spinlocks) \
2684  _Configure_Object_RAM(_spinlocks, sizeof(POSIX_Spinlock_Control) )
2685
2690  #ifndef CONFIGURE_MAXIMUM_POSIX_RWLOCKS
2691  #define CONFIGURE_MAXIMUM_POSIX_RWLOCKS 0
2692  #endif
2693
2700  #define CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS(_rwlocks) \
2701  _Configure_Object_RAM(_rwlocks, sizeof(POSIX_RWLock_Control) )
2702
2703  #ifdef CONFIGURE_POSIX_INIT_THREAD_TABLE
2704
2705  #ifdef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
2706
2707  /*
2708  * The user is defining their own table information and setting the
2709  * appropriate variables for the POSIX Initialization Thread Table.
2710  */
2711
2712  #else
2713
2714  #ifndef CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
2715  #define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT POSIX_Init
2716  #endif
2717
2718  #ifndef CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
2719  #define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE \
2720  CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
2721  #endif
2722
2723  #ifdef CONFIGURE_INIT
2724  posix_initialization_threads_table POSIX_Initialization_threads[] = {
2725  { CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT, \
2726  CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE }
2727  };
2728  #endif
2729
2730  #define CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME \
2731  POSIX_Initialization_threads
2732
2733  #define CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE \
2734  RTEMS_ARRAY_SIZE(CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME)
2735
2736  #endif /* CONFIGURE_POSIX_HAS_OWN_INIT_TASK_TABLE */
2737
2738  #else /* CONFIGURE_POSIX_INIT_THREAD_TABLE */
2739
2740  #define CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME NULL
2741  #define CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE 0
2742
2743  #endif
2744
2745 #else
2746
2751  #define CONFIGURE_MAXIMUM_POSIX_THREADS 0
2752
2753 #endif /* RTEMS_POSIX_API */
2754
2759 #ifndef CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
2760  #define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE 0
2761 #endif
2762  /* end of POSIX API Configuration */
2763
2773 #ifdef CONFIGURE_GNAT_RTEMS
2774
2779  #define CONFIGURE_GNAT_MUTEXES 10
2780
2786  #ifndef CONFIGURE_MAXIMUM_ADA_TASKS
2787  #define CONFIGURE_MAXIMUM_ADA_TASKS 20
2788  #endif
2789
2793  #ifndef CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
2794  #define CONFIGURE_MAXIMUM_FAKE_ADA_TASKS 0
2795  #endif
2796
2797 #else
2798
2799  #define CONFIGURE_GNAT_MUTEXES 0
2800
2801  #define CONFIGURE_MAXIMUM_ADA_TASKS 0
2802
2806  #define CONFIGURE_MAXIMUM_FAKE_ADA_TASKS 0
2807 #endif
2808  /* end of GNAT Configuration */
2809
2819 #ifdef CONFIGURE_ENABLE_GO
2820
2821  #ifndef CONFIGURE_MAXIMUM_POSIX_THREADS
2822  #define CONFIGURE_MAXIMUM_POSIX_THREADS 1
2823  #endif
2824  #ifndef CONFIGURE_MAXIMUM_POSIX_MUTEXES
2825  #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 1
2826  #endif
2827  #ifndef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
2828  #define CONFIGURE_MAXIMUM_CONDITION_VARIABLES 1
2829  #endif
2830
2831  #define CONFIGURE_GO_INIT_MUTEXES 77
2832  #define CONFIGURE_GO_INIT_CONDITION_VARIABLES 4
2833
2834  #ifndef CONFIGURE_MAXIMUM_GOROUTINES
2835  #define CONFIGURE_MAXIMUM_GOROUTINES 400
2836  #endif
2837
2838  #define CONFIGURE_GOROUTINES_TASK_VARIABLES \
2839  (2 * CONFIGURE_MAXIMUM_GOROUTINES)
2840
2841  #ifndef CONFIGURE_MAXIMUM_GO_CHANNELS
2842  #define CONFIGURE_MAXIMUM_GO_CHANNELS 500
2843  #endif
2844
2845 #else
2846
2852  #define CONFIGURE_GO_INIT_MUTEXES 0
2853
2860  #define CONFIGURE_GO_INIT_CONDITION_VARIABLES 0
2861
2863  #define CONFIGURE_MAXIMUM_GOROUTINES 0
2864
2866  #define CONFIGURE_GOROUTINES_TASK_VARIABLES 0
2867
2869  #define CONFIGURE_MAXIMUM_GO_CHANNELS 0
2870 #endif
2871  /* end of Go Configuration */
2872
2877 #ifndef CONFIGURE_EXTRA_TASK_STACKS
2878  #define CONFIGURE_EXTRA_TASK_STACKS 0
2879 #endif
2880
2884 #define CONFIGURE_POSIX_THREADS \
2885  (CONFIGURE_MAXIMUM_POSIX_THREADS + \
2886  CONFIGURE_MAXIMUM_ADA_TASKS + \
2887  CONFIGURE_MAXIMUM_GOROUTINES)
2888
2889 #ifdef RTEMS_POSIX_API
2890
2893  #define CONFIGURE_POSIX_MUTEXES \
2894  (CONFIGURE_MAXIMUM_POSIX_MUTEXES + \
2895  CONFIGURE_LIBBLOCK_POSIX_MUTEXES + \
2896  CONFIGURE_GNAT_MUTEXES + \
2897  CONFIGURE_MAXIMUM_ADA_TASKS + \
2898  CONFIGURE_MAXIMUM_FAKE_ADA_TASKS + \
2899  CONFIGURE_GO_INIT_MUTEXES + \
2900  CONFIGURE_MAXIMUM_GO_CHANNELS)
2901
2907  #define CONFIGURE_POSIX_CONDITION_VARIABLES \
2908  (CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES + \
2909  CONFIGURE_LIBBLOCK_POSIX_CONDITION_VARIABLES + \
2910  CONFIGURE_MAXIMUM_ADA_TASKS + \
2911  CONFIGURE_MAXIMUM_FAKE_ADA_TASKS + \
2912  CONFIGURE_GO_INIT_CONDITION_VARIABLES + \
2913  CONFIGURE_MAXIMUM_GO_CHANNELS)
2914
2921  #define CONFIGURE_MEMORY_FOR_POSIX \
2922  (CONFIGURE_MEMORY_FOR_POSIX_MUTEXES(CONFIGURE_POSIX_MUTEXES) + \
2923  CONFIGURE_MEMORY_FOR_POSIX_CONDITION_VARIABLES( \
2924  CONFIGURE_POSIX_CONDITION_VARIABLES) + \
2925  CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS( \
2926  CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS) + \
2927  CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUES( \
2928  CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES) + \
2929  CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUE_DESCRIPTORS( \
2930  CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS) + \
2931  CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( \
2932  CONFIGURE_MAXIMUM_POSIX_SEMAPHORES) + \
2933  CONFIGURE_MEMORY_FOR_POSIX_BARRIERS(CONFIGURE_MAXIMUM_POSIX_BARRIERS) + \
2934  CONFIGURE_MEMORY_FOR_POSIX_SPINLOCKS( \
2935  CONFIGURE_MAXIMUM_POSIX_SPINLOCKS) + \
2936  CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS( \
2937  CONFIGURE_MAXIMUM_POSIX_RWLOCKS) + \
2938  CONFIGURE_MEMORY_FOR_POSIX_TIMERS(CONFIGURE_MAXIMUM_POSIX_TIMERS))
2939 #else
2940
2946  #define CONFIGURE_MEMORY_FOR_POSIX 0
2947 #endif
2948
2949 /*
2950  * We must be able to split the free block used for the second last allocation
2951  * into two parts so that we have a free block for the last allocation. See
2952  * _Heap_Block_split().
2953  */
2954 #define CONFIGURE_HEAP_HANDLER_OVERHEAD \
2955  _Configure_Align_up( HEAP_BLOCK_HEADER_SIZE, CPU_HEAP_ALIGNMENT )
2956
2957 /*
2958  * Calculate the RAM size based on the maximum number of objects configured.
2959  */
2960 #ifndef CONFIGURE_EXECUTIVE_RAM_SIZE
2961
2970 #define CONFIGURE_MEMORY_FOR_TASKS(_tasks, _number_FP_tasks) \
2971  ( \
2972  _Configure_Object_RAM(_tasks, sizeof(Configuration_Thread_control)) \
2973  + _Configure_Max_Objects(_number_FP_tasks) \
2974  * _Configure_From_workspace(CONTEXT_FP_SIZE) \
2975  )
2976
2983 #ifdef CONFIGURE_MP_APPLICATION
2984  #define CONFIGURE_MEMORY_FOR_MP \
2985  (CONFIGURE_MEMORY_FOR_PROXIES(CONFIGURE_MP_MAXIMUM_PROXIES) + \
2986  CONFIGURE_MEMORY_FOR_GLOBAL_OBJECTS( \
2987  CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS) + \
2988  CONFIGURE_MEMORY_FOR_TASKS(1, 1) \
2989  )
2990 #else
2991  #define CONFIGURE_MEMORY_FOR_MP 0
2992 #endif
2993
2999 #define CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(_messages, _size) \
3000  _Configure_From_workspace( \
3001  (_messages) * ((_size) + sizeof(CORE_message_queue_Buffer_control)))
3002
3010 #ifndef CONFIGURE_MESSAGE_BUFFER_MEMORY
3011  #define CONFIGURE_MESSAGE_BUFFER_MEMORY 0
3012 #endif
3013
3026 #ifndef CONFIGURE_MEMORY_OVERHEAD
3027  #define CONFIGURE_MEMORY_OVERHEAD 0
3028 #endif
3029
3034 #define CONFIGURE_API_MUTEX_MEMORY \
3035  _Configure_Object_RAM(2, sizeof(API_Mutex_Control))
3036
3041 #if defined(RTEMS_SMP)
3042  #define CONFIGURE_IDLE_TASKS_COUNT CONFIGURE_SMP_MAXIMUM_PROCESSORS
3043 #else
3044  #define CONFIGURE_IDLE_TASKS_COUNT 1
3045 #endif
3046
3051 #if CPU_IDLE_TASK_IS_FP == TRUE
3052  #define CONFIGURE_MEMORY_FOR_IDLE_TASK \
3053  CONFIGURE_MEMORY_FOR_TASKS( \
3054  CONFIGURE_IDLE_TASKS_COUNT, CONFIGURE_IDLE_TASKS_COUNT)
3055 #else
3056  #define CONFIGURE_MEMORY_FOR_IDLE_TASK \
3057  CONFIGURE_MEMORY_FOR_TASKS(CONFIGURE_IDLE_TASKS_COUNT, 0)
3058 #endif
3059
3063 #define CONFIGURE_MEMORY_FOR_SYSTEM_OVERHEAD \
3064  ( CONFIGURE_MEMORY_FOR_IDLE_TASK + /* IDLE and stack */ \
3065  CONFIGURE_INTERRUPT_STACK_MEMORY + /* interrupt stack */ \
3066  CONFIGURE_API_MUTEX_MEMORY /* allocation mutex */ \
3067  )
3068
3073 #define CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS \
3074  (CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS == 0 ? 0 : \
3075  _Configure_From_workspace( \
3076  CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS \
3077  * sizeof(User_extensions_Switch_control) \
3078  ))
3079
3084 #define CONFIGURE_MEMORY_FOR_CLASSIC \
3085  (CONFIGURE_MEMORY_FOR_TASK_VARIABLES(CONFIGURE_MAXIMUM_TASK_VARIABLES + \
3086  CONFIGURE_GOROUTINES_TASK_VARIABLES) + \
3087  CONFIGURE_MEMORY_FOR_TIMERS(CONFIGURE_MAXIMUM_TIMERS + \
3088  CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER ) + \
3089  CONFIGURE_MEMORY_FOR_SEMAPHORES(CONFIGURE_SEMAPHORES) + \
3090  CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(CONFIGURE_MAXIMUM_MESSAGE_QUEUES) + \
3091  CONFIGURE_MEMORY_FOR_PARTITIONS(CONFIGURE_MAXIMUM_PARTITIONS) + \
3092  CONFIGURE_MEMORY_FOR_REGIONS( CONFIGURE_MAXIMUM_REGIONS ) + \
3093  CONFIGURE_MEMORY_FOR_PORTS(CONFIGURE_MAXIMUM_PORTS) + \
3094  CONFIGURE_MEMORY_FOR_PERIODS(CONFIGURE_MAXIMUM_PERIODS) + \
3095  CONFIGURE_MEMORY_FOR_BARRIERS(CONFIGURE_BARRIERS) + \
3096  CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(CONFIGURE_MAXIMUM_USER_EXTENSIONS) \
3097  )
3098
3104 #if defined(RTEMS_SMP)
3105  #define CONFIGURE_MEMORY_FOR_SMP \
3106  (CONFIGURE_SMP_MAXIMUM_PROCESSORS * \
3107  _Configure_From_workspace( CONFIGURE_INTERRUPT_STACK_SIZE ) \
3108  )
3109 #else
3110  #define CONFIGURE_MEMORY_FOR_SMP 0
3111 #endif
3112
3118 #define CONFIGURE_EXECUTIVE_RAM_SIZE \
3119 ( \
3120  CONFIGURE_MEMORY_FOR_SYSTEM_OVERHEAD + \
3121  CONFIGURE_MEMORY_FOR_TASKS( \
3122  CONFIGURE_TASKS, CONFIGURE_TASKS) + \
3123  CONFIGURE_MEMORY_FOR_TASKS( \
3124  CONFIGURE_POSIX_THREADS, CONFIGURE_POSIX_THREADS) + \
3125  CONFIGURE_MEMORY_FOR_CLASSIC + \
3126  CONFIGURE_MEMORY_FOR_POSIX_KEYS( \
3127  CONFIGURE_POSIX_KEYS, \
3128  CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS ) + \
3129  CONFIGURE_MEMORY_FOR_POSIX + \
3130  CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS + \
3131  CONFIGURE_MEMORY_FOR_MP + \
3132  CONFIGURE_MEMORY_FOR_SMP + \
3133  CONFIGURE_MESSAGE_BUFFER_MEMORY + \
3134  (CONFIGURE_MEMORY_OVERHEAD * 1024) + \
3135  CONFIGURE_HEAP_HANDLER_OVERHEAD \
3136 )
3137
3138 /*
3139  * Now account for any extra memory that initialization tasks or threads
3140  * may have requested.
3141  */
3142
3149 #if (CONFIGURE_INIT_TASK_STACK_SIZE > CONFIGURE_MINIMUM_TASK_STACK_SIZE)
3150  #define CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART \
3151  (CONFIGURE_INIT_TASK_STACK_SIZE - CONFIGURE_MINIMUM_TASK_STACK_SIZE)
3152 #else
3153  #define CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART 0
3154 #endif
3155
3162 #if defined(RTEMS_POSIX_API) && \
3163  (CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE > \
3164  CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE)
3165  #define CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART \
3166  (CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE - \
3167  CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE)
3168 #else
3169  #define CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART 0
3170 #endif
3171
3178 #define CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS \
3179  (CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART + \
3180  CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART)
3181
3188 #define CONFIGURE_IDLE_TASKS_STACK \
3189  (CONFIGURE_IDLE_TASKS_COUNT * \
3190  _Configure_From_stackspace( CONFIGURE_IDLE_TASK_STACK_SIZE ) )
3191
3198 #define CONFIGURE_TASKS_STACK \
3199  (_Configure_Max_Objects( CONFIGURE_TASKS ) * \
3200  _Configure_From_stackspace( CONFIGURE_MINIMUM_TASK_STACK_SIZE ) )
3201
3208 #define CONFIGURE_POSIX_THREADS_STACK \
3209  (_Configure_Max_Objects( CONFIGURE_MAXIMUM_POSIX_THREADS ) * \
3210  _Configure_From_stackspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) )
3211
3218 #define CONFIGURE_ADA_TASKS_STACK \
3219  (_Configure_Max_Objects( CONFIGURE_MAXIMUM_ADA_TASKS ) * \
3220  _Configure_From_stackspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) )
3221
3228 #define CONFIGURE_GOROUTINES_STACK \
3229  (_Configure_Max_Objects( CONFIGURE_MAXIMUM_GOROUTINES ) * \
3230  _Configure_From_stackspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) )
3231
3232 #else /* CONFIGURE_EXECUTIVE_RAM_SIZE */
3233
3234 #define CONFIGURE_IDLE_TASKS_STACK 0
3235 #define CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS 0
3236 #define CONFIGURE_TASKS_STACK 0
3237 #define CONFIGURE_POSIX_THREADS_STACK 0
3238 #define CONFIGURE_GOROUTINES_STACK 0
3239 #define CONFIGURE_ADA_TASKS_STACK 0
3240
3241 #if CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK != 0
3242  #error "CONFIGURE_EXECUTIVE_RAM_SIZE defined with request for CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK"
3243 #endif
3244
3245 #if CONFIGURE_EXTRA_TASK_STACKS != 0
3246  #error "CONFIGURE_EXECUTIVE_RAM_SIZE defined with request for CONFIGURE_EXTRA_TASK_STACKS"
3247 #endif
3248
3249 #endif /* CONFIGURE_EXECUTIVE_RAM_SIZE */
3250
3257 #define CONFIGURE_STACK_SPACE_SIZE \
3258  ( \
3259  CONFIGURE_IDLE_TASKS_STACK + \
3260  CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS + \
3261  CONFIGURE_TASKS_STACK + \
3262  CONFIGURE_POSIX_THREADS_STACK + \
3263  CONFIGURE_GOROUTINES_STACK + \
3264  CONFIGURE_ADA_TASKS_STACK + \
3265  CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK + \
3266  CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS + \
3267  CONFIGURE_EXTRA_TASK_STACKS + \
3268  CONFIGURE_HEAP_HANDLER_OVERHEAD \
3269  )
3270
3271 #ifdef CONFIGURE_INIT
3272  typedef struct {
3273  Thread_Control Control;
3274  #if CONFIGURE_MAXIMUM_USER_EXTENSIONS > 0
3275  void *extensions[ CONFIGURE_MAXIMUM_USER_EXTENSIONS + 1 ];
3276  #endif
3277  union {
3278  Scheduler_Node Base;
3279  #ifdef CONFIGURE_SCHEDULER_CBS
3280  Scheduler_CBS_Node CBS;
3281  #endif
3282  #ifdef CONFIGURE_SCHEDULER_EDF
3283  Scheduler_EDF_Node EDF;
3284  #endif
3285  #ifdef CONFIGURE_SCHEDULER_PRIORITY
3286  Scheduler_priority_Node Priority;
3287  #endif
3288  #ifdef CONFIGURE_SCHEDULER_SIMPLE_SMP
3289  Scheduler_SMP_Node Simple_SMP;
3290  #endif
3291  #ifdef CONFIGURE_SCHEDULER_PRIORITY_SMP
3292  Scheduler_priority_SMP_Node Priority_SMP;
3293  #endif
3294  #ifdef CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
3295  Scheduler_priority_affinity_SMP_Node Priority_affinity_SMP;
3296  #endif
3297  #ifdef CONFIGURE_SCHEDULER_USER_PER_THREAD
3298  CONFIGURE_SCHEDULER_USER_PER_THREAD User;
3299  #endif
3300  } Scheduler;
3301  RTEMS_API_Control API_RTEMS;
3302  #if defined(CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS)
3304  #endif
3305  #ifdef RTEMS_POSIX_API
3306  POSIX_API_Control API_POSIX;
3307  #endif
3308  #if !defined(RTEMS_SCHEDSIM) \
3309  && defined(RTEMS_NEWLIB) \
3310  && !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY)
3311  struct _reent Newlib;
3312  #else
3313  struct { /* Empty */ } Newlib;
3314  #endif
3315  } Configuration_Thread_control;
3316
3317  const size_t _Thread_Control_size = sizeof( Configuration_Thread_control );
3318
3320  {
3321  offsetof( Configuration_Thread_control, Control.Scheduler.node ),
3322  offsetof( Configuration_Thread_control, Scheduler )
3323  }, {
3324  offsetof(
3325  Configuration_Thread_control,
3326  Control.API_Extensions[ THREAD_API_RTEMS ]
3327  ),
3328  offsetof( Configuration_Thread_control, API_RTEMS )
3329  }, {
3330  offsetof(
3331  Configuration_Thread_control,
3332  Control.libc_reent
3333  ),
3334  offsetof( Configuration_Thread_control, Newlib )
3335  }
3336  #ifdef RTEMS_POSIX_API
3337  , {
3338  offsetof(
3339  Configuration_Thread_control,
3340  Control.API_Extensions[ THREAD_API_POSIX ]
3341  ),
3342  offsetof( Configuration_Thread_control, API_POSIX )
3343  }
3344  #endif
3345  };
3346
3347  const size_t _Thread_Control_add_on_count =
3348  RTEMS_ARRAY_SIZE( _Thread_Control_add_ons );
3349
3366  };
3367
3368  #ifdef RTEMS_POSIX_API
3369
3372  posix_api_configuration_table Configuration_POSIX_API = {
3374  CONFIGURE_POSIX_MUTEXES,
3375  CONFIGURE_POSIX_CONDITION_VARIABLES,
3376  CONFIGURE_MAXIMUM_POSIX_TIMERS,
3377  CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS,
3378  CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES,
3379  CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS,
3380  CONFIGURE_MAXIMUM_POSIX_SEMAPHORES,
3381  CONFIGURE_MAXIMUM_POSIX_BARRIERS,
3382  CONFIGURE_MAXIMUM_POSIX_RWLOCKS,
3383  CONFIGURE_MAXIMUM_POSIX_SPINLOCKS,
3384  CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE,
3385  CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME
3386  };
3387  #endif
3388
3397  uint32_t rtems_minimum_stack_size =
3399
3411
3416  CONFIGURE_EXECUTIVE_RAM_SIZE, /* required RTEMS workspace */
3417  CONFIGURE_STACK_SPACE_SIZE, /* required stack space */
3418  CONFIGURE_MAXIMUM_USER_EXTENSIONS, /* maximum dynamic extensions */
3419  CONFIGURE_POSIX_KEYS, /* POSIX keys are always */
3421  CONFIGURE_MICROSECONDS_PER_TICK, /* microseconds per clock tick */
3422  1000 * CONFIGURE_MICROSECONDS_PER_TICK, /* nanoseconds per clock tick */
3423  CONFIGURE_TICKS_PER_TIMESLICE, /* ticks per timeslice quantum */
3424  CONFIGURE_IDLE_TASK_BODY, /* user's IDLE task */
3425  CONFIGURE_IDLE_TASK_STACK_SIZE, /* IDLE task stack size */
3426  CONFIGURE_INTERRUPT_STACK_SIZE, /* interrupt stack size */
3427  CONFIGURE_TASK_STACK_ALLOCATOR_INIT, /* stack allocator init */
3428  CONFIGURE_TASK_STACK_ALLOCATOR, /* stack allocator */
3429  CONFIGURE_TASK_STACK_DEALLOCATOR, /* stack deallocator */
3430  CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY, /* true to clear memory */
3431  #ifdef CONFIGURE_UNIFIED_WORK_AREAS /* true for unified work areas */
3432  true,
3433  #else
3434  false,
3435  #endif
3436  #ifdef CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE /* true to avoid
3437  work space for thread stack
3438  allocation */
3439  true,
3440  #else
3441  false,
3442  #endif
3443  #ifdef RTEMS_SMP
3444  #ifdef CONFIGURE_SMP_APPLICATION
3445  true,
3446  #else
3447  false,
3448  #endif
3449  #endif
3450  CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS, /* number of static extensions */
3451  CONFIGURE_INITIAL_EXTENSION_TABLE, /* pointer to static extensions */
3452  #if defined(RTEMS_MULTIPROCESSING)
3453  CONFIGURE_MULTIPROCESSING_TABLE, /* pointer to MP config table */
3454  #endif
3455  #ifdef RTEMS_SMP
3456  CONFIGURE_SMP_MAXIMUM_PROCESSORS,
3457  #endif
3458  };
3459 #endif
3460
3461 #endif /* CONFIGURE_HAS_OWN_CONFIGURATION_TABLE */
3462
3463 #if defined(RTEMS_SMP)
3464  /*
3465  * Instantiate the Per CPU information based upon the user configuration.
3466  */
3467  #if defined(CONFIGURE_INIT)
3468  Per_CPU_Control_envelope _Per_CPU_Information[CONFIGURE_SMP_MAXIMUM_PROCESSORS];
3469  #endif
3470
3471 #endif
3472
3473 /*
3474  * If the user has configured a set of Classic API Initialization Tasks,
3475  * then we need to install the code that runs that loop.
3476  */
3477 #ifdef CONFIGURE_INIT
3478  #if defined(CONFIGURE_RTEMS_INIT_TASKS_TABLE) || \
3479  defined(CONFIGURE_HAS_OWN_INIT_TASK_TABLE)
3480  void (*_RTEMS_tasks_Initialize_user_tasks_p)(void) =
3482  #else
3483  void (*_RTEMS_tasks_Initialize_user_tasks_p)(void) = NULL;
3484  #endif
3485 #endif
3486
3487 /*
3488  * If the user has configured a set of POSIX Initialization Threads,
3489  * then we need to install the code that runs that loop.
3490  */
3491 #ifdef RTEMS_POSIX_API
3492  #ifdef CONFIGURE_INIT
3493  #if defined(CONFIGURE_POSIX_INIT_THREAD_TABLE) || \
3494  defined(CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE)
3497  #else
3498  void (*_POSIX_Threads_Initialize_user_threads_p)(void) = NULL;
3499  #endif
3500  #endif
3501 #endif
3502
3503 /*
3504  * Select PCI Configuration Library
3505  */
3506 #ifdef RTEMS_PCI_CONFIG_LIB
3507  #ifdef CONFIGURE_INIT
3508  #define PCI_LIB_NONE 0
3509  #define PCI_LIB_AUTO 1
3510  #define PCI_LIB_STATIC 2
3511  #define PCI_LIB_READ 3
3512  #define PCI_LIB_PERIPHERAL 4
3513  #if CONFIGURE_PCI_LIB == PCI_LIB_AUTO
3514  #define PCI_CFG_AUTO_LIB
3515  #include <pci/cfg.h>
3516  struct pci_bus pci_hb;
3517  #define PCI_LIB_INIT pci_config_auto
3518  #define PCI_LIB_CONFIG pci_config_auto_register
3519  #elif CONFIGURE_PCI_LIB == PCI_LIB_STATIC
3520  #define PCI_CFG_STATIC_LIB
3521  #include <pci/cfg.h>
3522  #define PCI_LIB_INIT pci_config_static
3523  #define PCI_LIB_CONFIG NULL
3524  /* Let user define PCI configuration (struct pci_bus pci_hb) */
3525  #elif CONFIGURE_PCI_LIB == PCI_LIB_READ
3526  #define PCI_CFG_READ_LIB
3527  #include <pci/cfg.h>
3528  #define PCI_LIB_INIT pci_config_read
3529  #define PCI_LIB_CONFIG NULL
3530  struct pci_bus pci_hb;
3531  #elif CONFIGURE_PCI_LIB == PCI_LIB_PERIPHERAL
3532  #define PCI_LIB_INIT pci_config_peripheral
3533  #define PCI_LIB_CONFIG NULL
3534  /* Let user define PCI configuration (struct pci_bus pci_hb) */
3535  #elif CONFIGURE_PCI_LIB == PCI_LIB_NONE
3536  #define PCI_LIB_INIT NULL
3537  #define PCI_LIB_CONFIG NULL
3538  /* No PCI Configuration at all, user can use/debug access routines */
3539  #else
3540  #error NO PCI LIBRARY DEFINED
3541  #endif
3542
3543  const int pci_config_lib_type = CONFIGURE_PCI_LIB;
3544  int (*pci_config_lib_init)(void) = PCI_LIB_INIT;
3545  void (*pci_config_lib_register)(void *config) = PCI_LIB_CONFIG;
3546  #endif
3547 #endif
3548
3549 #ifdef __cplusplus
3550 }
3551 #endif
3552
3553 /******************************************************************
3554  ******************************************************************
3555  ******************************************************************
3556  * CONFIGURATION WARNINGS AND ERROR CHECKING *
3557  ******************************************************************
3558  ******************************************************************
3559  ******************************************************************
3560  */
3561
3562 #if defined(CONFIGURE_CONFDEFS_DEBUG) && defined(CONFIGURE_INIT)
3563
3570  typedef struct {
3571  uint32_t SYSTEM_OVERHEAD;
3572  uint32_t STATIC_EXTENSIONS;
3573  uint32_t INITIALIZATION_THREADS_STACKS;
3574
3575  uint32_t PER_INTEGER_TASK;
3576  uint32_t FP_OVERHEAD;
3577  uint32_t CLASSIC;
3578  uint32_t POSIX;
3579
3580  /* System overhead pieces */
3581  uint32_t INTERRUPT_STACK_MEMORY;
3582  uint32_t MEMORY_FOR_IDLE_TASK;
3583
3584  /* Classic API Pieces */
3585  uint32_t CLASSIC_TASKS;
3586  uint32_t TASK_VARIABLES;
3587  uint32_t TIMERS;
3588  uint32_t SEMAPHORES;
3589  uint32_t MESSAGE_QUEUES;
3590  uint32_t PARTITIONS;
3591  uint32_t REGIONS;
3592  uint32_t PORTS;
3593  uint32_t PERIODS;
3594  uint32_t BARRIERS;
3595  uint32_t USER_EXTENSIONS;
3596
3597  /* POSIX API managers that are always enabled */
3598  uint32_t POSIX_KEYS;
3599
3600 #ifdef RTEMS_POSIX_API
3601  /* POSIX API Pieces */
3602  uint32_t POSIX_MUTEXES;
3603  uint32_t POSIX_CONDITION_VARIABLES;
3604  uint32_t POSIX_TIMERS;
3605  uint32_t POSIX_QUEUED_SIGNALS;
3606  uint32_t POSIX_MESSAGE_QUEUES;
3607  uint32_t POSIX_SEMAPHORES;
3608  uint32_t POSIX_BARRIERS;
3609  uint32_t POSIX_SPINLOCKS;
3610  uint32_t POSIX_RWLOCKS;
3611 #endif
3612
3613  /* Stack space sizes */
3614  uint32_t IDLE_TASKS_STACK;
3615  uint32_t INITIALIZATION_THREADS_EXTRA_STACKS;
3616  uint32_t TASKS_STACK;
3617  uint32_t POSIX_THREADS_STACK;
3618  uint32_t GOROUTINES_STACK;
3619  uint32_t ADA_TASKS_STACK;
3620  uint32_t EXTRA_MPCI_RECEIVE_SERVER_STACK;
3621  uint32_t EXTRA_TASK_STACKS;
3622  } Configuration_Debug_t;
3623
3624  Configuration_Debug_t Configuration_Memory_Debug = {
3625  /* General Information */
3633
3634  /* System overhead pieces */
3637
3638  /* Classic API Pieces */
3653
3654 #ifdef RTEMS_POSIX_API
3655  /* POSIX API Pieces */
3656  CONFIGURE_MEMORY_FOR_POSIX_MUTEXES( CONFIGURE_POSIX_MUTEXES ),
3657  CONFIGURE_MEMORY_FOR_POSIX_CONDITION_VARIABLES(
3658  CONFIGURE_POSIX_CONDITION_VARIABLES ),
3659  CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS(
3660  CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS ),
3661  CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUES(
3662  CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES ),
3663  CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( CONFIGURE_MAXIMUM_POSIX_SEMAPHORES ),
3664  CONFIGURE_MEMORY_FOR_POSIX_BARRIERS( CONFIGURE_MAXIMUM_POSIX_BARRIERS ),
3665  CONFIGURE_MEMORY_FOR_POSIX_SPINLOCKS( CONFIGURE_MAXIMUM_POSIX_SPINLOCKS ),
3666  CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS( CONFIGURE_MAXIMUM_POSIX_RWLOCKS ),
3667  CONFIGURE_MEMORY_FOR_POSIX_TIMERS( CONFIGURE_MAXIMUM_POSIX_TIMERS ),
3668 #endif
3669
3670  /* Stack space sizes */
3679  };
3680 #endif
3681
3682 /*
3683  * Make sure a task/thread of some sort is configured.
3684  *
3685  * When analyzing RTEMS to find the smallest possible of memory
3686  * that must be allocated, you probably do want to configure 0
3687  * tasks/threads so there is a smaller set of calls to _Workspace_Allocate
3688  * to analyze.
3689  */
3690 #if !defined(CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION)
3691  #if (CONFIGURE_MAXIMUM_TASKS == 0) && \
3692  (CONFIGURE_MAXIMUM_POSIX_THREADS == 0) && \
3693  (CONFIGURE_MAXIMUM_ADA_TASKS == 0) && \
3694  (CONFIGURE_MAXIMUM_GOROUTINES == 0)
3695  #error "CONFIGURATION ERROR: No tasks or threads configured!!"
3696  #endif
3697 #endif
3698
3699 #ifndef RTEMS_SCHEDSIM
3700 /*
3701  * Make sure at least one of the initialization task/thread
3702  * tables was defined.
3703  */
3704 #if !defined(CONFIGURE_RTEMS_INIT_TASKS_TABLE) && \
3705  !defined(CONFIGURE_POSIX_INIT_THREAD_TABLE) && \
3706  !defined(CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION)
3707 #error "CONFIGURATION ERROR: No initialization tasks or threads configured!!"
3708 #endif
3709 #endif
3710
3711 /*
3712  * If the user is trying to configure a multiprocessing application and
3713  * RTEMS was not configured and built multiprocessing, then error out.
3714  */
3715 #if defined(CONFIGURE_MP_APPLICATION) && \
3716  !defined(RTEMS_MULTIPROCESSING)
3717 #error "CONFIGURATION ERROR: RTEMS not configured for multiprocessing!!"
3718 #endif
3719
3720 /*
3721  * If an attempt was made to configure POSIX objects and
3722  * the POSIX API was not configured into RTEMS, error out.
3723  *
3724  * @note POSIX Keys are always available so the parameters
3725  * CONFIGURE_MAXIMUM_POSIX_KEYS and
3726  * CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS are not in this list.
3727  */
3728 #if !defined(RTEMS_POSIX_API)
3729  #if ((CONFIGURE_MAXIMUM_POSIX_THREADS != 0) || \
3730  (CONFIGURE_MAXIMUM_POSIX_MUTEXES != 0) || \
3731  (CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES != 0) || \
3732  (CONFIGURE_MAXIMUM_POSIX_TIMERS != 0) || \
3733  (CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS != 0) || \
3734  (CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES != 0) || \
3735  (CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS != 0) || \
3736  (CONFIGURE_MAXIMUM_POSIX_SEMAPHORES != 0) || \
3737  (CONFIGURE_MAXIMUM_POSIX_BARRIERS != 0) || \
3738  (CONFIGURE_MAXIMUM_POSIX_SPINLOCKS != 0) || \
3739  (CONFIGURE_MAXIMUM_POSIX_RWLOCKS != 0) || \
3740  defined(CONFIGURE_POSIX_INIT_THREAD_TABLE))
3741  #error "CONFIGURATION ERROR: POSIX API support not configured!!"
3742  #endif
3743 #endif
3744
3745 #if !defined(RTEMS_SCHEDSIM)
3746  #if !defined(CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE)
3747  /*
3748  * You must either explicity include or exclude the clock driver.
3749  * It is such a common newbie error to leave it out. Maybe this
3750  * will put an end to it.
3751  *
3752  * NOTE: If you are using the timer driver, it is considered
3753  * mutually exclusive with the clock driver because the
3754  * drivers are assumed to use the same "timer" hardware
3755  * on many boards.
3756  */
3757  #if !defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) && \
3758  !defined(CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER) && \
3759  !defined(CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER)
3760  #error "CONFIGURATION ERROR: Do you want the clock driver or not?!?"
3761  #endif
3762
3763  /*
3764  * Only one of the following three configuration parameters should be
3765  * defined at a time.
3766  */
3767  #if ((defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) + \
3768  defined(CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER) + \
3769  defined(CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER)) > 1)
3770  #error "CONFIGURATION ERROR: More than one clock/timer driver configuration parameter specified?!?"
3771  #endif
3772  #endif /* !defined(CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE) */
3773 #endif /* !defined(RTEMS_SCHEDSIM) */
3774
3775 /*
3776  * These names have been obsoleted so make the user application stop compiling
3777  */
3778 #if defined(CONFIGURE_TEST_NEEDS_TIMER_DRIVER) || \
3779  defined(CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER) || \
3780  defined(CONFIGURE_TEST_NEEDS_CLOCK_DRIVER) || \
3781  defined(CONFIGURE_TEST_NEEDS_RTC_DRIVER) || \
3782  defined(CONFIGURE_TEST_NEEDS_STUB_DRIVER)
3783 #error "CONFIGURATION ERROR: CONFIGURE_TEST_XXX constants are obsolete"
3784 #endif
3785
3786 /*
3787  * Validate the configured maximum priority
3788  */
3789 #if ((CONFIGURE_MAXIMUM_PRIORITY != 3) && \
3790  (CONFIGURE_MAXIMUM_PRIORITY != 7) && \
3791  (CONFIGURE_MAXIMUM_PRIORITY != 15) && \
3792  (CONFIGURE_MAXIMUM_PRIORITY != 31) && \
3793  (CONFIGURE_MAXIMUM_PRIORITY != 63) && \
3794  (CONFIGURE_MAXIMUM_PRIORITY != 127) && \
3795  (CONFIGURE_MAXIMUM_PRIORITY != 255))
3796  #error "Maximum priority is not 1 less than a power of 2 between 4 and 256"
3797 #endif
3798
3799 #if (CONFIGURE_MAXIMUM_PRIORITY > PRIORITY_DEFAULT_MAXIMUM)
3800  #error "Maximum priority configured higher than supported by target."
3801 #endif
3802
3803 /*
3804  * If you have fewer POSIX Message Queue Descriptors than actual
3805  * POSIX Message Queues, then you will not be able to open all the
3806  * queues.
3807  */
3808 #if (CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS < \
3809  CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES)
3810  #error "Fewer POSIX Message Queue descriptors than Queues!"
3811 #endif
3812
3813 /*
3814  * POSIX Key pair shouldn't be less than POSIX Key, which is highly
3815  * likely to be error.
3816  */
3817 #if (CONFIGURE_MAXIMUM_POSIX_KEYS != 0) && \
3818  (CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS != 0)
3819  #if (CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS < CONFIGURE_MAXIMUM_POSIX_KEYS)
3820  #error "Fewer POSIX Key pairs than POSIX Key!"
3821  #endif
3822 #endif
3823
3824 /*
3825  * IMFS block size for in memory files (memfiles) must be a power of
3826  * two between 16 and 512 inclusive.
3827  */
3828 #if ((CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 16) && \
3829  (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 32) && \
3830  (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 64) && \
3831  (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 128) && \
3832  (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 256) && \
3833  (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 512))
3834  #error "IMFS Memfile block size must be a power of 2 between 16 and 512"
3835 #endif
3836
3837
3838 #endif
3839 /* end of include file */
Frame Buffer Device Driver for all Boards.
Thread control add-on count.
void rtems_filesystem_initialize(void)
Base File System Initialization.
Definition: base_fs.c:32
void * _Thread_Idle_body(uintptr_t ignored)
This routine is the body of the system idle thread.
int rtems_filesystem_default_utime(const rtems_filesystem_location_info_t *loc, time_t actime, time_t modtime)
Definition: default_utime.c:24
MPCI Layer API.
#define CONFIGURE_INTERRUPT_STACK_SIZE
Interrupt stack size configuration.
Definition: confdefs.h:1226
This file describes the Watchdog Driver for all boards.
The following records define the POSIX Configuration Table.
Definition: posix/include/rtems/posix/config.h:58
#define CONFIGURE_IDLE_TASK_BODY
Idle task body configuration.
Definition: confdefs.h:1162
bool rtems_filesystem_default_are_nodes_equal(const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
Tests if the node access pointer of one location is equal to the node access pointer of the other loc...
Definition: default_are_nodes_equal.c:28
This macro is calculated to specify the memory required for the POSIX API in its entirety.
Definition: confdefs.h:2946
uint8_t rtems_maximum_priority
This variable contains the configured number of priorities.
Definition: deflate.c:116
This macro is calculated to specify the memory required for task variables.
Definition: confdefs.h:2132
This macro is calculated to specify the memory required for Classic API User Extensions.
Definition: confdefs.h:2352
This defines the formula used to compute the amount of memory reserved for IDLE task control structur...
Definition: confdefs.h:3052
int rtems_filesystem_default_link(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Definition: default_link.c:23
Definition: imfs.h:384
This specifies the maximum number of Classic API timers.
Definition: confdefs.h:2143
#define CONFIGURE_IDLE_TASK_STACK_SIZE
Idle task stack size configuration.
Definition: confdefs.h:1209
This macro is calculated to specify the memory required for the stacks of all POSIX threads...
Definition: confdefs.h:3208
SCORE_EXTERN Heap_Control _Workspace_Area
Executive workspace control.
Definition: wkspace.h:46
Scheduler control.
Definition: score/include/rtems/score/scheduler.h:192
int IMFS_link(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Create a new IMFS link node.
Definition: imfs_link.c:25
This is the stack size of the Initialization Task when none is configured.
Definition: confdefs.h:1557
This macro calculates the memory required for task variables.
Definition: confdefs.h:2125
This configuration parameter specifies the maximum number of Classic API Dual-Ported Memory Ports...
Definition: confdefs.h:2279
This is the API specific information required by each thread for the RTEMS API to function correctly...
Definition: tasks.h:661
#define CONFIGURE_TASK_STACK_ALLOCATOR
This specifies the task stack allocator method.
Definition: confdefs.h:1259
This macro is calculated to specify the memory required for Classic API timers.
Definition: confdefs.h:2150
Scheduler node specialization for EDF schedulers.
Definition: scheduleredf.h:96
const rtems_filesystem_table_t rtems_filesystem_table[]
Static table of file systems.
int rtems_filesystem_default_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_unmount.c:21
int IMFS_mount(rtems_filesystem_mount_table_entry_t *mt_entry)
Mount an IMFS.
Definition: imfs_mount.c:26
This configuration parameter specifies the maximum number of Classic API Regions. ...
Definition: confdefs.h:2261
This macro is calculated to specify the memory required for the stacks of all Go routines.
Definition: confdefs.h:3228
void rtems_task
The following defines the "return type" of an RTEMS task.
Definition: tasks.h:161
This specifies the maximum number of device drivers that can be installed in the system at one time...
Definition: confdefs.h:1633
void IMFS_node_free(const rtems_filesystem_location_info_t *loc)
Free an IMFS node.
Definition: imfs_initsupp.c:157
This macro provides a summation of the various POSIX thread requirements.
Definition: confdefs.h:2884
void rtems_filesystem_default_unlock(const rtems_filesystem_mount_table_entry_t *mt_entry)
Releases the IO library mutex.
Definition: default_lock_and_unlock.c:35
#define CONFIGURE_MAXIMUM_PTYS
This macro specifies the number of PTYs that can be concurrently active.
int rtems_telnetd_maximum_ptys
This variable contains the maximum number of PTYs that can be concurrently active.
The following records define the Configuration Table.
Definition: rtems/include/rtems/rtems/config.h:49
#define CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
Should the RTEMS Workspace and C Program Heap be cleared automatically at system start up...
Definition: confdefs.h:1286
Heap_Control * RTEMS_Malloc_Heap
C program heap control.
#define CONSOLE_DRIVER_TABLE_ENTRY
This macro defines the standard device driver table entry for a console device driver.
Definition: console.h:38
This calculates the memory required for the executive workspace.
Definition: confdefs.h:3118
This macro is calculated to specify the memory required for the stacks of all Ada tasks...
Definition: confdefs.h:3218
File system table entry.
Definition: libio.h:1594
POSIX Threads Private Support.
rtems_api_configuration_table Configuration_RTEMS_API
RTEMS API Configuration Table.
const rtems_configuration_table Configuration
This is the configuration table generated by confdefs.h.
void rtems_malloc_dirty_memory(void *start, size_t size)
Dirty Memory Function.
Definition: malloc_dirtier.c:28
Buffering configuration definition.
Definition: bdbuf.h:367
ssize_t rtems_filesystem_default_readlink(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Definition: default_readlink.c:24
Account for allocating the following per object.
Definition: confdefs.h:2970
This value is for the Classic RTEMS API.
Definition: thread.h:427
int rtems_filesystem_default_fchmod(const rtems_filesystem_location_info_t *loc, mode_t mode)
Definition: default_fchmod.c:23
The configures the number of microseconds per clock tick.
Definition: confdefs.h:2371
POSIX Thread API Support.
This configures the maximum number of Classic API tasks.
Definition: confdefs.h:2075
#define RTEMS_STACK_CHECKER_EXTENSION
Stack Checker Extension Set Definition.
Definition: stackchk.h:135
Definition: imfs.h:389
const uint32_t _Scheduler_CBS_Maximum_servers
Maximum number of simultaneous servers.
Internal Information about POSIX Signals.
POSIX MUTEX Support.
This macro provides a summation of the memory required by the Classic API as configured.
Definition: confdefs.h:3084
This macro accounts for general RTEMS system overhead.
Definition: confdefs.h:3063
This macro is calculated to specify the memory required for the Idle tasks(s) stack.
Definition: confdefs.h:3188
void IMFS_eval_path(rtems_filesystem_eval_path_context_t *ctx)
IMFS evaluation node support.
Definition: imfs_eval.c:175
#define CONFIGURE_SCHEDULER_CONTROLS
Configure the controls for this scheduler instance.
Definition: confdefs.h:854
POSIX Timers Internal Support.
Definition: sapi/include/rtems/io.h:52
Definition: percpu.h:381
int IMFS_node_clone(rtems_filesystem_location_info_t *loc)
Clone an IMFS node.
Definition: imfs_initsupp.c:141
This macro is calculated to specify the number of Classic API semaphores required by the application ...
Definition: confdefs.h:2179
#define NULL_DRIVER_TABLE_ENTRY
This is an empty device driver slot.
Definition: confdefs.h:1578
#define WATCHDOG_DRIVER_TABLE_ENTRY
This macro defines the watchdog device driver entry points.
Definition: watchdogdrv.h:30
#define CONFIGURE_SCHEDULER_CONTEXT
Configure the context needed by the scheduler instance.
Definition: confdefs.h:847
#define CONFIGURE_MINIMUM_TASK_STACK_SIZE
By default, use the minimum stack size requested by this port.
Definition: confdefs.h:1189
void _RTEMS_tasks_Initialize_user_tasks_body(void)
Definition: taskinitusers.c:44
Definition: sapi/include/rtems/config.h:128
Priority_Control rtems_task_priority
Define the type for an RTEMS API task priority.
Definition: tasks.h:79
This include file defines the per CPU information required by RTEMS.
Public Interface to the NFS Client Library for RTEMS.
This macro is calculated to specify the memory required for Classic API Barriers. ...
Definition: confdefs.h:2334
RTEMS Benchmark Timer API for all Boards.
This structure defines the Thread Control Block (TCB).
Definition: thread.h:671
Definition: cfg.h:229
void(* _POSIX_Threads_Initialize_user_threads_p)(void)
When the user configures a set of POSIX API initialization threads, This variable will point to the m...
This macro is calculated to specify the memory required for Classic API Rate Monotonic Periods...
Definition: confdefs.h:2304
This configuration parameter specifies the maximum number of Classic API Partitions.
Definition: confdefs.h:2243
#define CONFIGURE_INIT_TASK_TABLE
This is the name of the Initialization Task when none is configured.
Definition: confdefs.h:1543
Information Related to the RAM Workspace.
This macro is calculated to specify the memory required for the stacks of all tasks.
Definition: confdefs.h:3198
Thread control add-on.
Definition: thread.h:857
This is calculated to account for the maximum number of Classic API tasks used by the application and...
Definition: confdefs.h:2084
Constants and Structures Associated with the POSIX Barrier Manager.
#define CONFIGURE_INTERRUPT_STACK_MEMORY
This reserves memory for the interrupt stack if it is to be allocated by RTEMS rather than the BSP...
Definition: confdefs.h:1238
struct _reent * libc_reent
This field points to the newlib reentrancy structure for this thread.
Definition: thread.h:795
This configuration parameter specifies the maximum number of Classic API User Extensions.
Definition: confdefs.h:2345
int rtems_filesystem_default_symlink(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Definition: default_symlink.c:24
API Mutex Handler API.
void _POSIX_Threads_Initialize_user_threads_body(void)
POSIX threads initialize user threads body.
Definition: pthreadinitthreads.c:39
int IMFS_mknod(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Create an IMFS node.
Definition: imfs_mknod.c:43
int rtems_filesystem_default_rmnod(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
Definition: default_rmnod.c:24
This defines the timers required for the shared memory driver in a multiprocessing configuration...
Definition: confdefs.h:1884
int IMFS_fchmod(const rtems_filesystem_location_info_t *loc, mode_t mode)
Change the IMFS file mode.
Definition: imfs_fchmod.c:23
Control block used to manage a heap.
Definition: heap.h:342
Scheduler node specialization for SMP schedulers.
Definition: schedulersmp.h:98
This macro is calculated to specify the memory required for Classic API.
Definition: confdefs.h:2250
Scheduler node specialization for Deterministic Priority schedulers.
Definition: schedulerpriority.h:90
Scheduler_CBS_Server _Scheduler_CBS_Server_list[]
List of servers.
This macro is calculated to specify the RTEMS Workspace required for the Classic API Message Queues...
Definition: confdefs.h:2232
POSIX Message Queues Private Private Support.
int IMFS_chown(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Change the owner of IMFS.
Definition: imfs_chown.c:27
Per Device Node Control Structure.
Definition: devfs.h:33
int IMFS_symlink(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Create a new IMFS symbolic link node.
Definition: imfs_symlink.c:27
This variable contains the the minimum stack size;.
void rtems_libio_init(void)
RTEMS LibIO Initialization.
Definition: libio_init.c:43
This structure represents a time server.
Definition: schedulercbs.h:107
#define CONFIGURE_INIT_TASK_TABLE_SIZE
This is the size of the Initialization Task when none is configured.
Definition: confdefs.h:1550
POSIX Spinlock Support.
Standard C Library Support.
void(* _RTEMS_tasks_Initialize_user_tasks_p)(void)
When the user configures a set of Classic API initialization tasks, This variable will point to the m...
#define RTEMS_COMPILER_DEPRECATED_ATTRIBUTE
Instructs the compiler to issue a warning whenever a variable or function with this attribute will be...
Definition: basedefs.h:186
#define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
This defines the extra stack space required for the MPCI server thread.
Definition: confdefs.h:1876
This macro is calculated to specify the memory required for Classic API Dual-Ported Memory Ports...
Definition: confdefs.h:2286
#define CONFIGURE_TASK_STACK_DEALLOCATOR
This specifies the task stack deallocator method.
Definition: confdefs.h:1263
int IMFS_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Unmount an IMFS.
Definition: imfs_unmount.c:26
const rtems_bdbuf_config rtems_bdbuf_configuration
External reference to the configuration.
Private Support Information for POSIX Semaphores.
File system operations table.
Definition: libio.h:471
Definition: libio.h:1797
This value is for the POSIX API.
Definition: thread.h:429
This macro is calculated to specify the number of Classic API Barriers required by the application an...
Definition: confdefs.h:2324
LibIO Internal Interface.
int IMFS_rmnod(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
IMFS node removal handler.
Definition: imfs_rmnod.c:26
int rtems_filesystem_default_mount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_mount.c:21
This defines the POSIX API support structure associated with each thread in a system with POSIX confi...
Definition: threadsup.h:44
ssize_t IMFS_readlink(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Put IMFS symbolic link into buffer.
Definition: imfs_symlink.c:56
File Transfer Protocol file system (FTP client).
int IMFS_utime(const rtems_filesystem_location_info_t *loc, time_t actime, time_t modtime)
Set IMFS file access and modification times.
Definition: imfs_utime.c:25
#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT
Configure the very much optional task stack allocator initialization.
Definition: confdefs.h:1248
Definition: devfs.h:46
Definition: imfs.h:377
void rtems_filesystem_default_fsunmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_fsunmount.c:20
#define RTEMS_NUMBER_NOTEPADS
This is used to indicate the number of notepads available.
Definition: tasks.h:151
This macro is calculated to specify the memory required for Classic API Regions.
Definition: confdefs.h:2268
This is so we can account for tasks with stacks greater than minimum size.
Definition: confdefs.h:2878
Thread_Entry_numeric_type rtems_task_argument
The following defines the argument to an RTEMS task.
Definition: tasks.h:166
rtems_initialization_tasks_table Initialization_tasks[]
This is the Classic API initialization tasks table.
int rtems_filesystem_default_statvfs(const rtems_filesystem_location_info_t *loc, struct statvfs *buf)
Definition: default_statvfs.c:23
Scheduler node for per-thread data.
Definition: score/include/rtems/score/scheduler.h:281
Scheduler node specialization for Deterministic Priority SMP schedulers.
Definition: schedulerprioritysmp.h:64
const Scheduler_Control _Scheduler_Table[]
Registered schedulers.
The configures the number of clock ticks per timeslice.
Definition: confdefs.h:2377
An open file data structure.
Definition: libio.h:1281
POSIX API configuration table.
User extension table.
Definition: userext.h:232
This macro is calculated to specify the memory required for POSIX API keys.
Definition: confdefs.h:2480
This macro is calculated to specify the memory required for POSIX API key/value pairs.
Definition: confdefs.h:2459
int rtems_filesystem_default_rename(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Definition: default_rename.c:24
Size of the thread control block of a particular application.
POSIX Condition Variables Private Support.
This file defines the interface to RTEMS extensions to the Malloc Family.
This specifies the maximum number of Go per-task variables required.
Definition: confdefs.h:2866
This structure handles CBS specific data of a thread.
Definition: schedulercbs.h:130
This configuration parameter specifies the maximum number of Classic API Rate Monotonic Periods...
Definition: confdefs.h:2297
void * rtems_heap_extend_via_sbrk(Heap_Control *heap, size_t alloc_size)
RTEMS Extend Heap via Sbrk.
Definition: rtems_heap_extend_via_sbrk.c:34
This macro provides a summation of the various initialization task and thread stack requirements...
Definition: confdefs.h:3178
POSIX Key Private Support.
#define RTC_DRIVER_TABLE_ENTRY
Device driver table entry.
Definition: rtc.h:43
The following records define the Initialization Tasks Table.
Definition: tasks.h:181
This macro is calculated to specify the memory required for Classic API Semaphores.
Definition: confdefs.h:2215
This macro is calculated to specify the memory required for all tasks and threads of all varieties...
Definition: confdefs.h:3257
Constants and Structures Associated with the POSIX RWLock Manager.
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
This macro defines the number of POSIX file descriptors allocated and managed by libio.
Definition: confdefs.h:152
int rtems_filesystem_default_mknod(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Definition: default_mknod.c:24
const Thread_Control_add_on _Thread_Control_add_ons[]
Thread control add-ons.
This configuration parameter enables/disables Classic API notepads.
Definition: confdefs.h:2102
This macro reserves the memory required by the statically configured user extensions.
Definition: confdefs.h:3073
int rtems_filesystem_default_chown(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Definition: default_chown.c:23
For now, we are only allowing the user to specify the entry point and stack size for POSIX initializa...
Definition: posix/include/rtems/posix/config.h:42
void rtems_filesystem_default_lock(const rtems_filesystem_mount_table_entry_t *mt_entry)
Obtains the IO library mutex.
Definition: default_lock_and_unlock.c:28
Scheduler Configuration API.
#define CONFIGURE_MAXIMUM_PRIORITY
Maximum priority configuration.
Definition: confdefs.h:776
Scheduler node specialization for Deterministic Priority Affinity SMP schedulers. ...
Definition: schedulerpriorityaffinitysmp.h:173
int IMFS_rename(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Rename the IMFS.
Definition: imfs_rename.c:26
Block Device Buffer Management.
#define FRAME_BUFFER_DRIVER_TABLE_ENTRY
This macro defines the standard device driver table entry for a frame buffer device driver...
Definition: framebuffer.h:45
This configuration parameter specifies the maximum number of Classic API Message Queues.
Definition: confdefs.h:2225
#define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
IMFS.
Definition: confdefs.h:387
RTEMS_INLINE_ROUTINE struct Thread_Control * _Thread_Get_executing(void)
Returns the thread control block of the executing thread.
Definition: percpu.h:614
This macro is calculated to specify the total number of POSIX API keys required by the application an...
Definition: confdefs.h:2471
#define _Scheduler_Count
Count of registered schedulers.
Definition: score/include/rtems/score/scheduler.h:352
