This macro specifies that the user wants to use unlimited objects for any classic or posix objects that have not already been given resource limits. More...
#define | CONFIGURE_MAXIMUM_TASKS 0 |
This configures the maximum number of Classic API tasks. More... | |
#define | CONFIGURE_TASKS (CONFIGURE_MAXIMUM_TASKS + CONFIGURE_LIBBLOCK_TASKS) |
This is calculated to account for the maximum number of Classic API tasks used by the application and configured RTEMS capabilities. More... | |
#define | CONFIGURE_NOTEPADS_ENABLED FALSE |
This configuration parameter enables/disables Classic API notepads. More... | |
#define | CONFIGURE_MAXIMUM_TASK_VARIABLES 0 |
This macro calculates the memory required for task variables. More... | |
#define | CONFIGURE_MEMORY_FOR_TASK_VARIABLES(_task_variables) 0 |
This macro is calculated to specify the memory required for task variables. More... | |
#define | CONFIGURE_MAXIMUM_TIMERS 0 |
This specifies the maximum number of Classic API timers. More... | |
#define | CONFIGURE_MEMORY_FOR_TIMERS(_timers) 0 |
This macro is calculated to specify the memory required for Classic API timers. More... | |
#define | CONFIGURE_MAXIMUM_SEMAPHORES 0 |
This specifies the maximum number of Classic API semaphores. More... | |
#define | CONFIGURE_NETWORKING_SEMAPHORES 0 |
This specifies the number of Classic API semaphores required. More... | |
#define | CONFIGURE_SEMAPHORES |
This macro is calculated to specify the number of Classic API semaphores required by the application and configured RTEMS capabilities. More... | |
#define | CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES 0 |
This macro is calculated to specify the memory required for Classic API Semaphores using MRSP. More... | |
#define | CONFIGURE_MEMORY_FOR_SEMAPHORES(_semaphores) |
This macro is calculated to specify the memory required for Classic API Semaphores. More... | |
#define | CONFIGURE_MAXIMUM_MESSAGE_QUEUES 0 |
This configuration parameter specifies the maximum number of Classic API Message Queues. | |
#define | CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(_queues) 0 |
This macro is calculated to specify the RTEMS Workspace required for the Classic API Message Queues. More... | |
#define | CONFIGURE_MAXIMUM_PARTITIONS 0 |
This configuration parameter specifies the maximum number of Classic API Partitions. | |
#define | CONFIGURE_MEMORY_FOR_PARTITIONS(_partitions) 0 |
This macro is calculated to specify the memory required for Classic API. More... | |
#define | CONFIGURE_MAXIMUM_REGIONS 0 |
This configuration parameter specifies the maximum number of Classic API Regions. | |
#define | CONFIGURE_MEMORY_FOR_REGIONS(_regions) 0 |
This macro is calculated to specify the memory required for Classic API Regions. More... | |
#define | CONFIGURE_MAXIMUM_PORTS 0 |
This configuration parameter specifies the maximum number of Classic API Dual-Ported Memory Ports. | |
#define | CONFIGURE_MEMORY_FOR_PORTS(_ports) 0 |
This macro is calculated to specify the memory required for Classic API Dual-Ported Memory Ports. More... | |
#define | CONFIGURE_MAXIMUM_PERIODS 0 |
This configuration parameter specifies the maximum number of Classic API Rate Monotonic Periods. | |
#define | CONFIGURE_MEMORY_FOR_PERIODS(_periods) 0 |
This macro is calculated to specify the memory required for Classic API Rate Monotonic Periods. More... | |
#define | CONFIGURE_MAXIMUM_BARRIERS 0 |
This configuration parameter specifies the maximum number of Classic API Barriers. | |
#define | CONFIGURE_BARRIERS (CONFIGURE_MAXIMUM_BARRIERS + CONFIGURE_BARRIERS_FOR_FIFOS) |
This macro is calculated to specify the number of Classic API Barriers required by the application and configured capabilities. More... | |
#define | CONFIGURE_MEMORY_FOR_BARRIERS(_barriers) 0 |
This macro is calculated to specify the memory required for Classic API Barriers. More... | |
#define | CONFIGURE_MAXIMUM_USER_EXTENSIONS 0 |
This configuration parameter specifies the maximum number of Classic API User Extensions. | |
#define | CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(_extensions) 0 |
This macro is calculated to specify the memory required for Classic API User Extensions. More... | |
This module contains the parameters related to configuration of the Classic API services.
#define CONFIGURE_BARRIERS (CONFIGURE_MAXIMUM_BARRIERS + CONFIGURE_BARRIERS_FOR_FIFOS) |
This is an internal parameter.
#define CONFIGURE_MAXIMUM_SEMAPHORES 0 |
#define CONFIGURE_MAXIMUM_TASK_VARIABLES 0 |
Each task variable is individually allocated from the Workspace. Hence, we do the multiplication on the configured size.
#define CONFIGURE_MAXIMUM_TASKS 0 |
#define CONFIGURE_MAXIMUM_TIMERS 0 |
#define CONFIGURE_MEMORY_FOR_BARRIERS | ( | _barriers | ) | 0 |
#define CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES | ( | _queues | ) | 0 |
#define CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES 0 |
This is only available in SMP configurations.
#define CONFIGURE_MEMORY_FOR_PARTITIONS | ( | _partitions | ) | 0 |
#define CONFIGURE_MEMORY_FOR_PERIODS | ( | _periods | ) | 0 |
#define CONFIGURE_MEMORY_FOR_PORTS | ( | _ports | ) | 0 |
#define CONFIGURE_MEMORY_FOR_REGIONS | ( | _regions | ) | 0 |
#define CONFIGURE_MEMORY_FOR_SEMAPHORES | ( | _semaphores | ) |
If there are no user or support semaphores defined, then we can assume that no memory need be allocated at all for semaphores.
#define CONFIGURE_MEMORY_FOR_TASK_VARIABLES | ( | _task_variables | ) | 0 |
#define CONFIGURE_MEMORY_FOR_TIMERS | ( | _timers | ) | 0 |
#define CONFIGURE_MEMORY_FOR_USER_EXTENSIONS | ( | _extensions | ) | 0 |
#define CONFIGURE_NETWORKING_SEMAPHORES 0 |
#define CONFIGURE_NOTEPADS_ENABLED FALSE |
#define CONFIGURE_SEMAPHORES |
#define CONFIGURE_TASKS (CONFIGURE_MAXIMUM_TASKS + CONFIGURE_LIBBLOCK_TASKS) |
