Console Driver for all Boards. More...
#include <rtems/io.h>
#define | CONSOLE_DEVICE_NAME "/dev/console" |
This macro defines the standard name for the console device that is available to applications. | |
#define | CONSOLE_DRIVER_TABLE_ENTRY |
This macro defines the standard device driver table entry for a console device driver. More... | |
rtems_device_driver | console_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
Console initialization entry point. More... | |
rtems_device_driver | console_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
Console open entry point. More... | |
rtems_device_driver | console_close (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
Console close entry point. More... | |
rtems_device_driver | console_read (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
Console read entry point. More... | |
rtems_device_driver | console_write (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
Console write entry point. More... | |
rtems_device_driver | console_control (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
Console IO control entry point. More... | |
This file describes the Console Device Driver for all boards. This driver provides support for the standard C Library.
#define CONSOLE_DRIVER_TABLE_ENTRY |
rtems_device_driver console_close | ( | rtems_device_major_number | major, |
rtems_device_minor_number | minor, | ||
void * | arg | ||
This method closes a specific device supported by the console device driver.
[in] | major | is the device driver major number |
[in] | minor | is the device driver minor number |
[in] | arg | is the parameters to this call |
RTEMS_SUCCESSFUL | The device driver is successfully closed. |
rtems_device_driver console_control | ( | rtems_device_major_number | major, |
void * | arg | ||
This method performs an IO Control operation on a specific device supported by the console device driver.
RTEMS_SUCCESSFUL | the device driver IO control operation is successfully performed. |
rtems_device_driver console_initialize | ( | rtems_device_major_number | major, |
void * | arg | ||
This method initializes the console device driver.
[in] | major | is the device driver major number. |
[in] | minor | is the device driver minor number. |
[in] | arg | is the parameters to this call. |
RTEMS_SUCCESSFUL | The device driver is successfully initialized. |
rtems_device_driver console_open | ( | rtems_device_major_number | major, |
void * | arg | ||
This method opens a specific device supported by the console device driver.
RTEMS_SUCCESSFUL | The device driver is successfully opened. |
rtems_device_driver console_read | ( | rtems_device_major_number | major, |
void * | arg | ||
This method reads from a specific device supported by the console device driver.
RTEMS_SUCCESSFUL | The device is successfully read from. |
rtems_device_driver console_write | ( | rtems_device_major_number | major, |
void * | arg | ||
This method writes to a specific device supported by the console device driver.
RTEMS_SUCCESSFUL | The device is successfully written. |
